Homemade Suburban mid mount grader blade - Page 3 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 05-01-2011, 11:02 PM   post #31 of 173
VWJake
Senior MTF Member
VWJake's Avatar
MTF Member # 51877
Default Re: Homemade Suburban mid mount grader blade
Expenses so far are only about $5 for blades/cut off wheels. As for time I'm at about 12hrs now. Not having plans to work from and using scrap steel on hand means I'm staring at things quite a bit with no work being done.
__________________
'74 Sears SS/16- Smokey (drowned in the flood of '93 in St.Louis and still running) w/ Sears F.E.L.
'73 Sears ST/12- Oliver the Original - The tractor that started it all (my dad's first sears)
'66 Sears Custom 6- Roberta
Barstool Gokart- NCK BRAKR
'55 International Harvester R-122 pickup- Trusty Rusty
'64 Porsche 356 C- Little Red
VWJake is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 05-02-2011, 02:05 AM   post #32 of 173
K108Cub
GrandPa
K108Cub's Avatar
MTF Member # 39881
Images: 10
Looking good, Jake. I will keep this thread for future reference.
__________________
KennyP
Proud Member of the 800 Posts Club
U.S. Army, RVN, 1968-1969
5th Battalion, 16th Artillery, Battery C
1971 Cub Cadet 108
1977 Ford LGT 165
1981 Craftsman GTV/16
198? Craftsman II
K108Cub is offline   Reply With Quote Quick reply to this message
Old 05-02-2011, 03:00 AM   post #33 of 173
stripmine
Member: Special K Club
stripmine's Avatar
MTF Member # 26454
Images: 5
Garage
Quote:
Originally Posted by eveled View Post
On my mid mount blade I can push down with my feet on either side to take a bigger bite of the material. Ed
I use my buddy's Mid Mount grader to dress up the tire ruts in his gravel towing lot. with the weight of the trucks packing it down, the grader just bounces across the surface.
I just put the tractor in first high, then put my feet on the blade.. there have been a few times, when i was standing on the blade to break it up.
you have to be careful when the blade is angled, because the rear tires keep trying to grab your boot.
kids.. don't try this at home LOL
dave
stripmine is offline   Reply With Quote Quick reply to this message
Old 05-02-2011, 10:51 AM   post #34 of 173
GT_80
Cranky Motorsports
GT_80's Avatar
MTF Member # 35886
Images: 32
Garage
Looking good! That design is almost the same as the factory one, except the factory one had something more like 3" diameter pipe, but a trailer jack should be strong enough to take some abuse
__________________
MTF Addict #35886
Hugh-SS/16 fan #0001
Tractors:
1968 Super12 "Miss Emma Lee"
1967 Suburban 12 "The 679"
1973 SS16/ 18/6 hybrid "Mighty Mongrel"
1976 SS18 "Trusty"
1978 GT18 with Hard cab - home again!
Attachments:As many as I can get
My YouTubeMy Ebay
Sears Manuals
GT_80 is offline   Reply With Quote Quick reply to this message
Old 05-02-2011, 01:24 PM   post #35 of 173
VWJake
Senior MTF Member
VWJake's Avatar
MTF Member # 51877
Thanks folks. It's basically a copy of the original sears blade with modifications as needed based on materials on hand / perceived design improvements.
Here's what I accomplished today:
I cut the other rib and welded both to the blade frame.
I ground off the pivot frame on the jack and welded it to the "C" frame. I welded it in "quarters" on both sides to ensure the two pieces are as "stuck together" as I can make them.
The angled braces for the spine tube are cut and fitted. The angle is 1/8" so I think I'm going to weld a plate across them tying into the C frame as well. I don't want that thin agle to twist if the edge of the blade grabs something.
__________________
Old 05-03-2011, 12:24 AM   post #36 of 173
GT_80
Cranky Motorsports
GT_80's Avatar
MTF Member # 35886
Images: 32
Garage
Coming along fast! Can't wait to see it done!
__________________
MTF Addict #35886
Tractors:
1976 SS18 "Trusty"
My YouTubeMy Ebay
Sears Manuals
Old 05-03-2011, 12:46 AM   post #37 of 173
Small Fry
5000 Strong & Climbing
Small Fry's Avatar
MTF Member # 8155
Your going right along.
__________________
Small Fry is offline   Reply With Quote Quick reply to this message
Old 05-03-2011, 01:30 AM   post #38 of 173
K108Cub
GrandPa
K108Cub's Avatar
MTF Member # 39881
Images: 10
Thanks for posting pics as you go. Helps to understand what you have done.
__________________
KennyP
1971 Cub Cadet 108
1977 Ford LGT 165
198? Craftsman II
Old 05-03-2011, 01:50 PM   post #39 of 173
VWJake
Senior MTF Member
VWJake's Avatar
MTF Member # 51877
Quote:
My pleasure. I'm happy you guys are enjoying this. Rest assured I'll keep posting pics as I move on with this.
__________________
Old 05-04-2011, 02:10 PM   post #40 of 173
VWJake
Senior MTF Member
VWJake's Avatar
MTF Member # 51877
Not much to report today.
I tacked the angle irons to the C-frame/spine tube.
I've got the blade pivots all worked out. The top plate is 1/4" material. I made it 20-1/2" wide to spread the load better across the blade. It'll get bolted to the blade with 7/16" hardware. The outer 2 holes are the original holes that the blade angle arc bar bolted to. I'll trim the excess from the trailing edge of the top plate tonight. The lower pivot is a chunk of 1/4" angle iron. I'll weld it to the ribs for added strength. I trimmed about 3/8" off of the pivot end of the tube so I could move the pivot point closer to the blade. I'll probably weld in a sleeve for that pivot to add strength.
I hope to have the brackets attached to the blade and blade skinned this weekend. Once that's done I'll start sorting out the blade angle system. It'll probably mimic the original. I am temped to use a turnbuckle though
__________________
Old 05-04-2011, 05:26 PM   post #41 of 173
GT_80
Cranky Motorsports
GT_80's Avatar
MTF Member # 35886
Images: 32
Garage
wow! I like it!!
Now I think you got me wanting to make one... It will be pretty simple, mount to the two front mower mounts, have a pivot on top of the blade, and a simple (hopefully) lift system utilizing the back mower deck mount. no end to end tilt though... I don't really think I would need it.
__________________
MTF Addict #35886
Tractors:
1976 SS18 "Trusty"
My YouTubeMy Ebay
Sears Manuals
Old 05-04-2011, 05:37 PM   post #42 of 173
Slow Crawler
Proud Member of the 1K Club
Slow Crawler's Avatar
MTF Member # 52174
Images: 1
Looking GOOD , I like it.
__________________
66 Suburban 10
73 ST/10 For parts
73 ST/12 Frankinburban
77 Sears 16/6 twin
88 Craftsman III Sold
84,86 Murray 18/42 gt mowing tractors Sold the 86
85 Murray 18/42 The Slow Crawler
96 Craftsman 917.251560, 22.5 Hp 50" cut
03 Huskee, MTD 18.5/ 42
Slow Crawler is offline   Reply With Quote Quick reply to this message
Old 05-04-2011, 08:27 PM   post #43 of 173
Small Fry
Small Fry's Avatar
MTF Member # 8155
Your having way to much fun for one guy. Looks good !
__________________
Old 05-04-2011, 09:37 PM   post #44 of 173
Fastdirt
MTF Junior Poster
MTF Member # 57050
Man, that's a good design. I like that it's a pull design. Can't wait to see this thing done, but the progress pics are just as good too me. Looks like a lot of fun too.
__________________
74 Roper Hydro with Onan twin 24HP in the works
74 ST/16 Suburban
Front and rear blades, plow, harrow, front bucket
www.youtube.com/Fastdirt505
Fastdirt is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 05-04-2011, 09:40 PM   post #45 of 173
Cable70
Senior MTF Member
Cable70's Avatar
MTF Member # 29386
Great work Jake, Your hired!!!!!!!!
__________________
'68 Custom7(Was Gramp's Since New); '67 Suburban10; '72 SS15; '06 Snapper Hi-Vac RER; '07 Snapper Snowthower; '88 Snapper LT12; '96 Snapper Walk-behind
Cable70 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
