Homemade Suburban mid mount grader blade - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 04-26-2011, 05:51 PM   post #1 of 173
VWJake
Senior MTF Member
VWJake's Avatar
MTF Member # 51877
Default Homemade Suburban mid mount grader blade
I've been eyeballing the owner's manuals for the original mid mounts for some time now. No matter how long I stare at the pictures one never appears in the garage so...
I'm going to use a rusted out 46" dozer blade and a bunch of salvaged steel to build my own mid-mount grader blade to fit my ST/12.
4 weeks ago I pulled the dozer blade from the lean-to and cut it half.
A few weeks back I removed the skin from the top half of the blade. ( I'll use this to skin the new blade. I also cut off the remaining curved sections from the top rib to use for added support for the remaining blade.
This morning I cut up a few chunks of 1/4" plate to approximate the original mounting tabs. I used 1/2" bar and 2 washers to make the upper locating pins. I'll dress up the brackets a bit once the build is further along.
Only one is pictured, but both mounts are done and on.
I'm planing to use the remains of the tongue jack in the last 2 pics for this build as well.
I'm going to be busier than I'd like with other things for the next week or so, but I'll post updates as often as possible. I can already see the ground piling up in front of this thing. I can't wait.
__________________
'74 Sears SS/16- Smokey (drowned in the flood of '93 in St.Louis and still running) w/ Sears F.E.L.
'73 Sears ST/12- Oliver the Original - The tractor that started it all (my dad's first sears)
'66 Sears Custom 6- Roberta
Barstool Gokart- NCK BRAKR
'55 International Harvester R-122 pickup- Trusty Rusty
'64 Porsche 356 C- Little Red
VWJake is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 04-26-2011, 06:01 PM   post #2 of 173
Slow Crawler
Proud Member of the 1K Club
Slow Crawler's Avatar
MTF Member # 52174
Images: 1
Default Re: Homemade Suburban mid mount grader blade
Great Idea !! I can't wait to see more.
__________________
66 Suburban 10
73 ST/10 For parts
73 ST/12 Frankinburban
77 Sears 16/6 twin
88 Craftsman III Sold
84,86 Murray 18/42 gt mowing tractors Sold the 86
85 Murray 18/42 The Slow Crawler
96 Craftsman 917.251560, 22.5 Hp 50" cut
03 Huskee, MTD 18.5/ 42
Slow Crawler is offline   Reply With Quote Quick reply to this message
Old 04-26-2011, 06:06 PM   post #3 of 173
Small Fry
5000 Strong & Climbing
Small Fry's Avatar
MTF Member # 8155
Looks like you have a good start.
__________________
Small Fry is offline   Reply With Quote Quick reply to this message
Old 04-27-2011, 10:21 AM   post #4 of 173
69l46vert
That there's worth fixin'
69l46vert's Avatar
MTF Member # 17151
Those brackets you made look really close to factory.
69l46vert is offline   Reply With Quote Quick reply to this message
Old 04-27-2011, 11:44 AM   post #5 of 173
VWJake
Senior MTF Member
VWJake's Avatar
MTF Member # 51877
Thanks Guys. The brackets will look even closer to factory when I'm done. I didn't want to put too much time into them in case I scrapped them for something else before the project was finished.
__________________
Old 04-27-2011, 01:26 PM   post #6 of 173
Silvercreek Farmer
Formerly Tractor #2
Silvercreek Farmer's Avatar
MTF Member # 37172
Images: 2
What's the advantage of a mid-mount blade, or is it just cool?
Silvercreek Farmer is offline   Reply With Quote Quick reply to this message
Old 04-27-2011, 01:31 PM   post #7 of 173
GT_80
Cranky Motorsports
GT_80's Avatar
MTF Member # 35886
Images: 32
Garage
Quote:
The factory Mid Mount allowed you to not only angle side to side, but grade on an angle like a regular road grader did. They look cool, and work well, the only disadvantage I had with mine was that the lift mechanism got hung up when I was driving over rocks and or sticks etc.
I have been thinking about making one recently as well after I traded mine, but a much more simple design, and maybe something that the lift would tuck up into the frame.
I can't wait to see your progress!!
__________________
MTF Addict #35886
Hugh-SS/16 fan #0001
Tractors:
1968 Super12 "Miss Emma Lee"
1967 Suburban 12 "The 679"
1973 SS16/ 18/6 hybrid "Mighty Mongrel"
1976 SS18 "Trusty"
1978 GT18 with Hard cab - home again!
Attachments:As many as I can get
My YouTubeMy Ebay
Sears Manuals
GT_80 is offline   Reply With Quote Quick reply to this message
Old 04-27-2011, 02:04 PM   post #8 of 173
Cable70
Senior MTF Member
Cable70's Avatar
MTF Member # 29386
Very Nice Jake!
I am putting in my order for serial # 000002 please.....he he
__________________
'68 Custom7(Was Gramp's Since New); '67 Suburban10; '72 SS15; '06 Snapper Hi-Vac RER; '07 Snapper Snowthower; '88 Snapper LT12; '96 Snapper Walk-behind
Cable70 is offline   Reply With Quote Quick reply to this message
Old 04-27-2011, 03:05 PM   post #9 of 173
69l46vert
69l46vert's Avatar
MTF Member # 17151
Supposedly easier to do a nice job too because of being between the wheels. With a back blade, if the front wheels go up a slight rise, then the back blade goes down, digging a low spot, so you have to control it with the 3 point handle.
That and as James mentioned, the ability to crown a drive. They adjust for more or less crown.
Old 04-27-2011, 06:12 PM   post #10 of 173
VWJake
Senior MTF Member
VWJake's Avatar
MTF Member # 51877
Tractor#2- I've always thought that you could get a more even grade between the axles than in front of/behind. I'm also building it for the cool factor, for more welding experience, using up scrap that I've amassed before we move this summer.
James- you bring up a good point about sticking in the up position. I'll have to ponder that one for a bit. Was there anything else that you would have changed given the chance? Eventually I want to add a couple of linear actuators for lift/downforce and blade angle. I'll still tilt the blade by hand I think... Unless...
Keith- Let's see how #0001 goes first.
I should have a few new pics tomorrow.
__________________
Old 04-27-2011, 06:43 PM   post #11 of 173
Small Fry
Small Fry's Avatar
MTF Member # 8155
The model I have has a lift handle like the mower decks. They are made to spread stone or dirt, not grade hard packed ground. You can set the height unlike the rear grader with a manual hitch. The blade is also 1/2 thick steel unlike the graders.
Like most of the other attachments, you should take it off if it's not being used. The brackets say on.
I used the eathcavator with the elec. hitch today. That works nice as you can feather the switch to set the height while your moving.
__________________
Old 04-27-2011, 07:28 PM   post #12 of 173
eveled
2000 Posts and climbing!!!
eveled's Avatar
MTF Member # 28747
Images: 8
I've used all three and the midmount is much nicer to use for grading than the rear or the front. It is much more consistent between the axles than 2 or 3feet infront or behind the axle, if you hit a hole with a front tire the rear blade goes way up because it is so far away from the axle. It also makes for a shorter rig wich makes it easier to manuver. The rear blade is better for pulling material away from an obsruction, like pulling snow away from a garage door, and the front blade is better for clearing snow. So if you could only have 1 the front blade can do it all but for grading the midmount is far superior. On my mid mount blade I can push down with my feet on either side to take a bigger bite of the material. Ed
__________________
Here's to our veterans past present and future
Machine of The Month link
eveled is offline   Reply With Quote Quick reply to this message
Old 04-27-2011, 08:16 PM   post #13 of 173
Hugh-SS/16
Onan Lover
Hugh-SS/16's Avatar
MTF Member # 31282
Images: 15
Garage
ive always thought that an easy way to make a midmount would be to make a reverse A-frame, with the double end on the lower holes of the front axle. on the single end, you have the blade, then an electric actuator to lift and lower it.
i like your work so far jake, ill be interested to see how it works out, i might put in an order for number 00003
__________________
GT_80 Fan Club Member: #0001
Need Tires?Click Here!
Tractors: '68 Custom 8XL, '73 SS/16, '73 SS/16, '78 GT/18H, '78 GT/19.9
Attachments: Kwik-Way Loader, 48" Haban Sickle Bar, 42" Mid-Mount Grader, 42" 3pt Grader, 46" Snow Blade, 42" Mower, 4000w PTO Generator, 3pt 10" Moldboard, 3pt Cultivator, 42" Haban Snowblower, 46" Dozer Blade
John Deere, Mahindra CUT, Gravely, Stihl
Ellington Agway Power Equipment
74 West Rd (Rt 83)
Ellington, CT
860-875-0690
The above opinions are solely mine and do not reflect that of my employer
Hugh-SS/16 is offline   Reply With Quote Quick reply to this message
Old 04-28-2011, 05:56 PM   post #14 of 173
VWJake
Senior MTF Member
VWJake's Avatar
MTF Member # 51877
I got about 2 1/2hrs in today. I'm happy with the progress considering I'm working with hand tools and each one of these pieces is cut from a 4'x6"x1/4" plate.
All of the holes line up so it'll hang straight without pin bind.
The outer bars keep the blade frame stable and square to the tractor. The framework that locates the lift mechanism will attach to them as well. The inner bars will reinforce the connection to the "C" frame that will attach to the blade pivot tube.
The more I look at it the more I don't like the ears that attach to the tractor frame. I feel that 1-1/4"x1/4" tabs will bend if the blade gets hung up on something. I'm debating constructing stronger tabs.
Tomorrow I'll start constructing the frame that the blade pivot tube will attach to.
I've just started restoring a Pennsylvania tow behind 3 gang reel mower for my Custom 6 so you'll see a thread start for that soon. I'm also waiting for an electric assist 3pt hitch plate to arrive as well- yet another project I want to get started on. See ADD can be a good thing- sometimes...
__________________
Sponsored Links
Advertisement
Old 04-28-2011, 06:28 PM   post #15 of 173
Slow Crawler
MTF Member # 52174
Images: 1
Looking good!!!!!
__________________
66 Suburban 10
73 ST/10 For parts
77 Sears 16/6 twin
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
