JD 30" Hydro Rototiller fo 318 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 04-25-2011, 07:13 PM   post #1 of 12
Juniors
Senior MTF Member
Juniors's Avatar
MTF Member # 52078
Garage
Default JD 30" Hydro Rototiller fo 318
I came across a rototiller today. the guy wanted $500 for it. It looked pretty complete for a 317. However, I'm looking to fit it on a 318.
Is the $500 a good deal? Also, does anyone have pics of how it connects and the associated hardware I would need. Thanks!
__________________
IH Farmall Cub
JD x495 with 45 FEL and BH
JD 445
JD 430
JD LX277 AWS
Previously owned:
455 aws, 445, 430, 420, 345, 332, 330, 318, 317, 316, 40 FEL, 44 FEL, 314, 300, 212, 210, 140 h3, 140 h1, 110, x500, x300r, x300, Lx266, LX277, lx255, Lt180, LX176, LX178, 180, STX38, STX30, Gt235, l130, La 118, Kubota g4200
Juniors is online now   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 04-25-2011, 08:25 PM   post #2 of 12
TNTFarms
Senior MTF Member
TNTFarms's Avatar
MTF Member # 39999
Default Re: JD 30" Hydro Rototiller fo 318
The tiller for the 317 will not fit the 318 without major modifications. The tiller for a 317 is a model 33 where as the tiller for the 316 onan, 318,322,332 is a model 30 hydraulic. here is a picture of the tiller that would fit you 318 one with factor hookup, the other with 3 point conversion. Aslo 500 for a model 33 is fair depending on what all it comes with. on the other hand 500 is a steal on a model 30 hydraulic.
factory original way
Three point conversion
And last here is a picture of a model 33 that fits the closed frame 312,314,316 Kohler and 317
__________________
07 Hustler Z, Deere -87 - 332, 88 - 322, 90 - 318, 68 - 140 H3, 67 - 112 round fender, , Power flow belt drive, model 30 tiller, model 49 snow blower, 54 blade, Brinly - 2 3pt plows and 1 3pt disc, 79 Troybilt horse, 86 Troybilt pony, 68 - Wheel Horse commando 8
TNTFarms is offline   Reply With Quote Quick reply to this message
Old 04-25-2011, 08:54 PM   post #3 of 12
jmt1271
Senior MTF Member
jmt1271's Avatar
MTF Member # 1877
Excellent info TNT.
I am trying to learn about the differences between tillers myself.
I dont even understand how the hydraulic tillers work, as I have never seen one.
Maybe I will start a new thread, so as not to hijack.
__________________
1983 318, 475 original hrs.
1980 314, 48" deck, very nice, dealer restored about 5-6 years ago, runs/mows great. For sale shortly
jmt1271 is offline   Reply With Quote Quick reply to this message
Old 04-26-2011, 06:41 AM   post #4 of 12
Juniors
Senior MTF Member
Juniors's Avatar
MTF Member # 52078
Garage
Thanks for the info. Very helpful. The one I found is like the first one. However, the owner said there was an extension piece that I could fit on to extend it to over 40 inches. I"m also curious about how it works. Best Regards
__________________
IH Farmall Cub
JD 445
JD 430
JD LX277 AWS
Previously owned:
Old 04-26-2011, 05:14 PM   post #5 of 12
TNTFarms
Senior MTF Member
TNTFarms's Avatar
MTF Member # 39999
Your welcome and here is some more information.
Yes there is an extension you can buy to make it 42" however good luck finding one at a reasonable price I have been looking for one my self an have seen them go over 300 just for the extension. The 30" tiller will dig 7" deep and it does an awesome job, I love mine. Once you add the extension the manual says it will only dig 5" deep. Also with the hydraulic models you can put the tiller on either direction to have forward rotating tine or counter rotating tine. I have mine in forward as does most of the people I have talked to. There are also 2 versions one has a belly mount pump and one has a rear mount pump. The rear mount pump requires a rear pto, where as the belly mount uses you mule drive and deck belt to run.
__________________
Old 04-27-2011, 08:45 PM   post #6 of 12
Juniors
Senior MTF Member
Juniors's Avatar
MTF Member # 52078
Garage
Well I bought it. It's missing some mount and lift brackets, needs some new tines, and the back panel. But otherwise looks complete. I hope I didn't pay too much. I took some photos of the other one that was there too. It was set up for a 212. I figured I send the photos of the belly brackets in case anyone else was interested. [IMG]
__________________
IH Farmall Cub
JD 445
JD 430
JD LX277 AWS
Previously owned:
Old 04-27-2011, 09:28 PM   post #7 of 12
Cberan
Senior MTF Member
Cberan's Avatar
MTF Member # 46260
You stole that if you only paid 500.00 for it. Great job!!!
__________________
317 w/49 thrower
318 w/ 54" blade
67 RF 110
Cberan is offline   Reply With Quote Quick reply to this message
Old 04-27-2011, 11:05 PM   post #8 of 12
Dakotaskustoms
MTF Junior Poster
MTF Member # 58883
For reference here is the parts list for mounting... I just got mine all mounted up today. Just make sure you put the pump assembly under the tractor BEFORE you hook up the lift points ... otherwise you will not be able to fit the pump in between the tiller and and frame . trust me
and the mounting holes variations and digging depths:
EDIT: And here is the Spec Sheet.
Dakotaskustoms is offline   Reply With Quote Quick reply to this message
Old 04-28-2011, 06:36 PM   post #9 of 12
TNTFarms
Senior MTF Member
TNTFarms's Avatar
MTF Member # 39999
I would go with the 3 point hitch mount that Jim Briney sells, for one it is way easier to hook up and for 2 it will be way cheaper than getting the correct mounts for it. I sold my factory mounts for 200.00 and the mount on the tiller for another 75.00. Jim's 3 point conversion cost 180.00 shipped. You will also need a bracket for the pump for a 300 series he may make those also I am not sure.
__________________
Old 05-04-2011, 08:31 PM   post #10 of 12
Juniors
Senior MTF Member
Juniors's Avatar
MTF Member # 52078
Garage
Thanks all. I need a good 3pt to support it. Any thoughts on aftermarket vs. facotry? Probably a lot on this topic over the years....
__________________
IH Farmall Cub
JD 445
JD 430
JD LX277 AWS
Previously owned:
Old 05-04-2011, 11:54 PM   post #11 of 12
PA318Guy
Winter returned!
PA318Guy's Avatar
MTF Member # 31960
Garage
Reugg makes a very good 3 ph for the 318! I have a JD OEM on mine and I've been impressed with the ones from Reugg!
__________________
Current Machine JD 322
Former Machines: JD 318, JD 216, JD 212, 1965 JD 110
My videos: www.youtube.com/user/tkelley16341
PA318Guy is online now   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 05-14-2011, 06:07 PM   post #12 of 12
Juniors
Senior MTF Member
Juniors's Avatar
MTF Member # 52078
Garage
I went with Jim Briney's factory replacement brackets. Would have loved the 3pt, but I can't justify the cost of the whole set up for my use.
__________________
IH Farmall Cub
JD 445
JD 430
JD LX277 AWS
Previously owned:
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
