Is there a "fix" for the B&S 18.5 HP Head Gasket? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Small Engines and Repair
Midwest Mower Pro
Reply
Thread Tools Display Modes
Old 04-22-2011, 09:17 PM   post #1 of 6
jerry_nj
2000 Posts and climbing!!!
jerry_nj's Avatar
MTF Member # 1077
Images: 1
Default Is there a "fix" for the B&S 18.5 HP Head Gasket?
A couple of days back I resurrected a thread I started in 2009 when I replaced the Head Gasket in my 2005 (about 200 hours) B&S 18.5 Intek cylinder engine. It was burning oil badly. It started by blowing smoke when I engaged the mower. In the end it blew visible smoke all the time. The head gasket replacement cured the problem, if only temporarily. The replacement now has about 100 hours on it and it started blowing smoke when the mower deck is engaged. I restate the problem here under a subject that may attract the knowledge/experience that I need.
I have read this engine has a history of head gasket failures. It seems to me that B&S would come up with a stronger gasket or something to protect its "good name". Has anyone seen anything on a repair that would last more that a few tens of hours?
Is there any advice on how to check the web (B&S Web Support) to see if the company has taken any steps to mitigate this very poor design?
__________________
1989 Craftsman LT 12 HP 38" 2-blade deck - Retired
1993 Craftsman GT6000 18 HP B&S twin L-head 44" 3-blade deck, - Avatar and duty GT
2005 Craftsman DYT4000 42" 2-blade deck - B&S 18.5 Intek - new head gasket twice in 500 hr. Was hit by a Pine tree blown down by Hurricane Sandy Oct.2012. But I now have the PYT9000 and a real mowing machine
2011 Craftsman PYT9000 B&S 26 HP Professional and 46" 2-blade deck. Wife said "ANOTHER TRACTOR?"
I replied "Yep"
jerry_nj is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 04-22-2011, 10:08 PM   post #2 of 6
larrybl
5000 Strong & Climbing
larrybl's Avatar
MTF Member # 37470
Images: 32
Garage
Default Re: Is there a "fix" for the B&S 18.5 HP Head Gasket?
Not sure about the 18.5 Intek or B&S Web Support. I took both my 18's to a machine shop to have the cyl's bored. I don't see why not let a machine shop check the Cyl and head fit, and make sure you torque to spec, then run the engine up to operating temp, let cool and re-torque.
larrybl is offline   Reply With Quote Quick reply to this message
Old 04-22-2011, 10:40 PM   post #3 of 6
ben2go
MTF New Poster
ben2go's Avatar
MTF Member # 11920
A check to see how true the surfaces are would help.Years ago,when I was in vocational school,we used something to coat the head gasket on an old big single Wisconsin engine.
Ahhhh,here it is.
ben2go is offline   Reply With Quote Quick reply to this message
Old 04-23-2011, 07:45 AM   post #4 of 6
DTLMG
Master Service Technician
MTF Member # 42277
Images: 2
Proper Torque specs and torqueing sequence is essential. This should take care of the problem
__________________
DTLMG
Make sure your red wire goes to positive, and your black to ground
Master Senior Service Technician
30+yrs in Outdoor Power Equip Industry
DTLMG is offline   Reply With Quote Quick reply to this message
Old 04-23-2011, 11:55 AM   post #5 of 6
jerry_nj
jerry_nj's Avatar
MTF Member # 1077
Images: 1
I did take some care to torque in sequence, but I never checked again after running the engine. I thought I'd check it a day back (ya, gasket is likely already destroyed) but noted I have to remove the exhaust pipe to get to some of the bolts. That and the fact I couldn't fine the torque sequence or correct torque lead me to just "test" the bolts I could reach and all seemed tight.
Remember, the engine gasket failed out of the factory with about 200 hours on it. I have head this is common with this particular engine. i.e., a bad/weak design. Or, the factory isn't installing the head correctly on some engines in this line.
__________________
I replied "Yep"
Sponsored Links
Advertisement
Old 04-24-2011, 12:45 AM   post #6 of 6
38racing
Proud Member of the 1K Club
MTF Member # 25899
Proper torque is essential but it won't make up for a faulty design. It's the bolt pattern that results in the failure.
38racing is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
