Belly Blade - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 04-22-2011, 01:56 PM   post #1 of 19
dweber85rc
Senior MTF Member
MTF Member # 57671
Default Belly Blade
Did case ever make a belly blade for their GT's? I am in the process of making one for my 220 and thought it would be nice to see an example to try and work off of.
dweber85rc is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 04-22-2011, 02:10 PM   post #2 of 19
Caseman2
2000 Posts and climbing!!!
Caseman2's Avatar
MTF Member # 9276
Images: 8
Default Re: Belly Blade
The standard mower for all Case/Ingersoll tractors are the belly type.
Go to www.ingersolltractors.com
Caseman2 is offline   Reply With Quote Quick reply to this message
Old 04-22-2011, 02:37 PM   post #3 of 19
dweber85rc
Senior MTF Member
MTF Member # 57671
Blade-as in grader blade not mower blade lol!
Old 04-22-2011, 03:15 PM   post #4 of 19
wurkenman
Proud Member of the 1K Club
wurkenman's Avatar
MTF Member # 26288
I have a home made one for my 446. It is not connected at the moment, so I don't have pics. There are no factory belly blades that I know of.
wurkenman is offline   Reply With Quote Quick reply to this message
Old 04-22-2011, 03:18 PM   post #5 of 19
dweber85rc
Senior MTF Member
MTF Member # 57671
Any pics you could provide would be helpful, even if it isn't connected to the tractor.
Old 04-22-2011, 05:41 PM   post #6 of 19
eBoyDog
Senior MTF Member
eBoyDog's Avatar
MTF Member # 50228
Images: 14
Garage
There was someone that build up a 448 with newer Kohler engine repower that made a grader blade for his. (he extended the frame, made a custom hood)
His webpages are out there, they start with page 1, Page 2 and so on as he walked though the re-build. I thought I had it bookmarked but it must be on the home pc.
eBoyDog is offline   Reply With Quote Quick reply to this message
Old 04-22-2011, 08:58 PM   post #7 of 19
RestMyCase
RestMyCase's Avatar
MTF Member # 20465
To answer your question, No , Case/Ingersoll never made a belly blade but many like yourself have fabricated their own. I may be wrong but I thought MagnumRT made a very nice mid-mount grader blade. He has fabricated some useful attachments ...
RestMyCase is offline   Reply With Quote Quick reply to this message
Old 04-23-2011, 12:03 AM   post #8 of 19
eBoyDog
Senior MTF Member
eBoyDog's Avatar
MTF Member # 50228
Images: 14
Garage
This what I saw awhile back... Can someone help me out, who did this????
http://www.data-cut.com/case448c.htm
They made a mule bracket for it and the lift ties into the standard lift on the tractor.
(WOW those pictures are huge!)
Old 04-23-2011, 10:46 AM   post #9 of 19
Magnum RT
Magnum RT's Avatar
MTF Member # 4746
Images: 10
Those pictures belong to "Grummy" of Manitowoc, WI He has done far more than I on mods and special equipment. I don't have the link to his projects, but know it is available on the forum.
I converted an AC blade to fit my Ingy, with side tilt, but lost my hard drive last week, and have not been able to recover my pictures yet. So much for a new Dell remote HD, "quick click" back up! They might be in the MTF photos, not sure.
I think the ground clearance would limit the lift on a belly blade on the small wheel tractor. May not be practical.
__________________
Rol
Extreme S.W. Michigan
Ingersoll Fan
Green Bay Packers Fan
A lazy mind finds easier solutions!
Magnum RT is offline   Reply With Quote Quick reply to this message
Old 04-23-2011, 12:42 PM   post #10 of 19
dweber85rc
Senior MTF Member
MTF Member # 57671
That is the design I had in mind. I may not have a lot of lift clearance, if I get a couple of inches I"ll be happy enough. I'm only going to use it on the driveway anyways so I don't need much clearance. I was working on it this morning a bit and had to stop because I started my pants on fire from molten metal that shot back from the blade when I was using my cutting torch. Thats what I get for wearing khaki pants... Need to change pants and will be back out!
Old 04-23-2011, 02:23 PM   post #11 of 19
CP7
CP7's Avatar
MTF Member # 5785
Images: 11
I thought hot pants went out in the seventies dw.
I've always wondered what Grummy does for a hobby. The way he goes about projects is closer to prototype r&d work than us just playing around. The best thing is he's just as great of a writer and photographer and we sure appreciate him the way he shares his experiences.
CP7 is offline   Reply With Quote Quick reply to this message
Old 04-23-2011, 06:56 PM   post #12 of 19
dweber85rc
Senior MTF Member
MTF Member # 57671
I just about have it finished. Just need to finish bracing some things up and then make a couple of lift straps for it and it will be good to go. I'll get some pics of it when I am done. I used an old 48" snow plow blade off of who knows what and cut it in half lengthwise and then bolted on a used cutting edge from a CAT road grader. Used some brackets and piece from a cub cadet mower subframe too. Like most of my projects it has parts from a little bit of everything
Old 04-23-2011, 10:21 PM   post #13 of 19
wurkenman
wurkenman's Avatar
MTF Member # 26288
Here are a couple of pics. The PO made the blade and it bots to holes drilled in the snapfast brackets. When the blade is all the way down, it is even with the tires on the bottom. Won't allow too much down pressure, but works pretty good for clipping off the high spots when rolling over bumps ruts etc. I have another deck mule drive bracket that I plan on fitting to the blade this summer.
ID:	154434   Click image for larger version
ID:	154435   Click image for larger version
Old 04-23-2011, 10:29 PM   post #14 of 19
poncho62
National Mower Guy
poncho62's Avatar
MTF Member # 19374
Images: 7
I built this one for my Ford a while back, was out using it today to smooth the driveway. Does a nice job.
__________________
That National Mower guy
National Reel Mower
Ford LGT100
Ford LGT125
M-F 10
John Deere STX38
Ontario Rodders
poncho62 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 04-24-2011, 07:40 PM   post #15 of 19
kdursus
Tractorhead
kdursus's Avatar
MTF Member # 3241
dweber85rc - Now I'm not saying anything negative about the center grader blades that have been posted here but when you fabricate yours make sure you incorporate a removable/replaceable cutting edge into your design! You'll thank me 5 years from now.
John Deere's Center Blade struts mount to the rear of the tractor so the tractor more or less pushes the blade verses pulling the blade. This may be another design to think about? Too bad you can't see the design better in this picture.
__________________
kdursus is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
