How many gallons per hour do you use? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Backyard Round Table - L & G Tractor Related Topics Lawn and Garden Tractor Related Topics General Discussion Board
Reply
Thread Tools Display Modes
Old 04-08-2011, 10:12 PM   #1
mbrun
Senior MTF Member
mbrun's Avatar
MTF Member # 57036
Default How many gallons per hour do you use?
Anybody out there keep track of how many hours of runtime per gallon of gas you get when using your lawn or garden tractor?
My previous tractor did not have an hour meter so I never really knew how much run time per gallon I was gettting. Now I have an hour meter I am going to keep track for a while.
Will be interesting to see if different tasks have noticably different results.
__________________
~~~~~~~ 2010 JD x500 ~~~~~~~~
..Brush Guard, 48" Snow Blade, Electric Blade Lift
..Custom Blade Squeegee & Dollie
..P796 Halogens
..JP Electric Sleeve Hitch
..RimGuard Loaded Tires (+92lbs extra, each)
..DR Power Grader
..Dual 50lb Wheel Weights, Chains
..PrecisionFit/Agri-Fab 45-0299 48" Core Aerator
..Brinly Aerator/Seeder, Moldboard Plow,
..Box Scraper, Dethatcher (On Loan)
..Craftsman 48" x 18" Roller
..Brinly 25-Gallon Tank Sprayer
mbrun is offline   Reply With Quote
Sponsored Links
Advertisement
Old 04-08-2011, 10:22 PM   #2
Jon318
Senior MTF Member
Jon318's Avatar
MTF Member # 18785
Images: 1
Default Re: How many gallons per hour do you use?
Well, using a single cylinder 14 hp kohler, I used just under a gallon mowing at full throttle for just over an hour. Now that Ive throttled back to half throttle, it takes me about an hour and a half, but now Im only using half a gallon.
Jon318 is offline   Reply With Quote
Old 04-09-2011, 01:49 AM   #3
Boyd
3K Poster!!!!
Boyd's Avatar
MTF Member # 19439
Images: 8
Many riders will use just over 1 gallon per hour up to 1.50. Some diesel mowers will be as low as .90 gallons per hour.
__________________
http://www.youtube.com/watch?v=mHVFE02NTgU http://www.youtube.com/watch?v=nv9Tx29-ZTQ http://www.youtube.com/watch?v=6zdO4JuKEiw http://www.youtube.com/watch?v=yJMEDJVDro0 http://www.youtube.com/watch?v=cI-O3mIzq_Uhttp://www.youtube.com/watch?v=yy0B7M03U-E
Pictured:79 Mustang Pace car 5.0 4sp sold in 90. 79 Case 448 8th one made. Toro: 520xi 60"& Berco 40" blower, 266-H 48", 266-H 52", 117 GM 52", 52" wb made into pull type. Thinking outside of the box.
Ingersoll 60" RH deck for sale.
Boyd is offline   Reply With Quote
Old 04-09-2011, 04:36 AM   #4
TUDOR
5000 Strong & Climbing
MTF Member # 28463
Full throttle snowblowing with my 16 hp Onan twin cost me 1.25 gal/hr. Half to 2/3 throttle with the loader, that same engine used 3/4 gal./hr. It takes horsepower to run a snowblower, even just blowing air.
Rough fuel consumption for small engines is 0.4 - 0.6 lb/hr/hp, and I use 0.5 as a general calculator. Thats the brake specific fuel consumption (BSFC)and is dependent on the actual power generated by the engine. Backing up between passes while snow blowing doesn't require the engine to make max hp at full throttle. Gasoline weighs 6.0 lb/ gal.
A specific job will use a specific amount of fuel. Throttle position is not all that relevent except for how fast you want to do the job and if the engine can actually do the job at lower rpm and therefore lower horsepower.
My diesel does a little better. Half throttle loader work costs a little over a half gallon per hour. BSFC is around 0.35 - 0.45.
__________________
Bob
Click for The Hydraulics Forum!
Sometimes you get on a roll, sometimes the roll gets on you.
In Service
MF GC2310, Husqvarna YTH20B42T
Down for Repairs
MF1655 w/ FEL, MF1655, MF12H, MF8H, MF7H
Spending too much time on MTF to work on my toys.
TUDOR is offline   Reply With Quote
Old 04-09-2011, 11:07 AM   #5
davidg
The Travelin' Mod
davidg's Avatar
MTF Member # 807
Images: 2
about 1 per hour on my X500 and my L130. my craftsman GT i never fill the tank all the way and i usually only run it about 1/3 throttle since it is just pulling a self powered tiller.
__________________
Check out our new HOMEPAGE
davidg is offline   Reply With Quote
Old 04-09-2011, 11:45 AM   #6
jim335
Senior MTF Member
MTF Member # 45576
Images: 1
My GX335, 20hp Kawa. mowing or blowing uses 1 gal. per hour.
__________________
2004 GX335, 48C mower, powerflow 7 bu. bagger, 42 snowthrower, 30 mech. tiller, 80 dump cart.
jim335 is offline   Reply With Quote
Old 04-09-2011, 04:20 PM   #7
gburnett
2000 Posts and climbing!!!
MTF Member # 9399
I'm amazed at how much gas some of the twin cylinders gassers can use over a gal/hr while some of my small diesel tractors burn very little.16HP Yanmar 1300d can't use much over a pint/hr. 31HP Yanmar 330 uses about 1/2 gal/hr.Even my 70HP Cockshutt/Oliver 1650D
only uses about 1 1/2 gal/hr while pulling a large round baler.
gburnett is offline   Reply With Quote
Old 04-09-2011, 04:33 PM   #8
Kingwood990
Kingwood990's Avatar
MTF Member # 35659
Garage
The John Deere X520 26hp Kawasaki V-twin uses about a gallon and a half per hour at full throttle. The MTD 990 16hp Brigg and Stratton single cylinder uses about two gallons per hour. Does not matter the throttle setting. Its a thirsty machine.
__________________
1977 MTD 990 with 3pt hitch
1974 MTD 990 with 3pt hitch, 42'' mower, 10'' sleeve hitch bottom plow (Sears/Brinly)
1991 Toro Wheel Horse 244-H with 38'' mower and mulch kit (grampa's tractor)
2006 John Deere X520 with 54'' mower, HDAP's front and rear, 10'' sleeve hitch bottom plow (Sears/Brinly)
19?? John Deere 214 with 46'' mower, 43'' blade, Dads project/money pit
year unknown IH Cub Cadet 100 thanks Jon318
1973 Homelite RM-7E 30'' mower
198? Yamaha XS1100
Stihl FS55R
Stihl FS55RC
Kingwood990 is offline   Reply With Quote
Old 04-09-2011, 05:05 PM   #9
wizzo
MTF Tractor Nut
wizzo's Avatar
MTF Member # 32657
Haven't tried to calculate it, but some tasks just take more fuel. If I had a bigger place, I'd surely go with a diesel X748...
How old is your X500? I've heard rumors on the Deere forum that after about 50-60 hrs the fuel consumption of the Kawa's drops off a bit. I guess we'll see...
__________________
2010 John Deere X500
  • 48X w/ Mulch Kit, Gators & HDAPs
  • Brinly Plug Aerator, JD Spreader & 10p Cart
  • 48" Front Blade, Wheel Weights & Suitcase Weights
  • 30" Mechanical Tiller
1994 John Deere 14SB
1993 John Deere 14SB
Stihl KM 90R Kombi System
2005 Lawn Boy 10684 Insight Mower
wizzo is offline   Reply With Quote
Old 04-09-2011, 05:12 PM   #10
PurplDodge
Proud Member of the 1K Club
PurplDodge's Avatar
MTF Member # 30647
I burn 5 gallons of gas in 12 hours while mowing in my Cub Cadet.
__________________
1986 John Deere 316 P218 18 hp Onan 50'' deck looking for 54 blade
1992 Cub Cadet 1440 44" deck, 2,300 hours, B&S Vanguard, Gator Blades, 42'' IH Dozer Blade, Custom Light Bar, Custom hole in side of engine
2001 Chevrolet S-10 4.3 V6 5-Speed ZQ8
PurplDodge is offline   Reply With Quote
Old 04-09-2011, 05:52 PM   #11
evo803
Senior MTF Member
evo803's Avatar
MTF Member # 39797
OP did not state a specific vehicle so
At wide open throttle ( 75 mph ) 60 gallons an hour , at a cruise(45mph) about 30 gallons per hour. Unfortunately I had to sell it because of my accident that disabled me.
__________________
Chris
" Friends don't let friends drive stock ! "
evo803 is offline   Reply With Quote
Old 04-09-2011, 06:02 PM   #12
PurplDodge
PurplDodge's Avatar
MTF Member # 30647
In that case...10 gallons per minute:
__________________
Old 04-09-2011, 09:51 PM   #13
davidg
The Travelin' Mod
davidg's Avatar
MTF Member # 807
Images: 2
mine's an '08 and has about 130 hours on it now. it did burn a little more initially, then after the first oil change it seemed to level on out.
__________________
Old 04-09-2011, 10:03 PM   #14
PA318Guy
Badge Crew Member
PA318Guy's Avatar
MTF Member # 31960
Garage
I would guess the 318 at WOT was using about 1.5 gallons. I was able to snowblow about three times per tank and was out 45 - 60 minutes per event.
__________________
Current Machine JD 322
Former Machines: JD 318, JD 216, JD 212, 1965 JD 110
My videos: www.youtube.com/user/tkelley16341
PA318Guy is offline   Reply With Quote
Sponsored Links
Advertisement
Old 04-09-2011, 10:19 PM   #15
Carl
3K Poster!!!!
Carl's Avatar
MTF Member # 249
Images: 1
My MTD 990 with 16 HP Briggs uses about 1 gallon per hour with disking and leveling ground.
My new Powerking with K361 uses a little more but haven't worked it enough to really tell.
My New Holland TC 24 DA uses about 1 gallon per hour working with the FEL. Next time am subsoiling will check cause that works it to the limit.
__________________
Believe
Carl is offline   Reply With Quote
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
