Lawn vacuum / mulchers- how much suction do they have? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 03-31-2011, 09:36 AM   post #1 of 7
ryker
Senior MTF Member
MTF Member # 36692
Question Lawn vacuum / mulchers- how much suction do they have?
These items are all over craigslist for decent prices. I know the primary reason is the homeowner just doesn't have a need for it or wants to deal with the labor involved when using it as a chipper/mulcher.
I'm looking to use it as a method to such up large shredded mulch (free) grind it up while discharging it in my truck bed. Can these lawn vacuum work on such or are they just for twigs and acorns? This free mulch is from a highway expansion project. Mixture of tree types shredder into 3-5" long slim pieces. I've manhandled 4 longbed truck loads already. Would like to get about 3-4 more free loads.
I'm looking at an 8hp snapper for 225.00 then need to buy the hose kit.
ryker is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 03-31-2011, 11:20 AM   post #2 of 7
APinNY
I didn't do it!
APinNY's Avatar
MTF Member # 22011
Images: 5
Default Re: Lawn vacuum / mulchers- how much suction do they have?
It should work as long as the mulch is fairly dry and you don't try to force feed it. Moisture can lead to clogging, mainly in the hose where it bends.
__________________
Al
Kubota BX1860, 48" fine cut mulching MMM, FEL, snow thrower, cab, Heavy Hitch
TroyBilt LTX 15.5, snow thrower, cab (sold)
TroyBilt LTX 13, (given away)
Craftsman DYT 4000 Special Edition, 21 HP Briggs Twin (sold)
DR Lawn Vacuum. Review here
1978 Craftsman 7 1/2 HP snow blower (backup machine-never use it)
"You will find out what that extra part is for as soon as you throw it away"
APinNY is online now   Reply With Quote Quick reply to this message
Old 03-31-2011, 12:21 PM   post #3 of 7
ryker
Senior MTF Member
MTF Member # 36692
I too think it should work if I feed it slowly. Just wanted to confirm before I drop the cash on the mulcher and fabricating the suction hose.
Old 03-31-2011, 10:53 PM   post #4 of 7
mla2ofus
Old Stonebreaker
MTF Member # 138
If those chips are 3" to 5" I think you'll have lots of trouble w/ them bridging in the hose.
Mike
mla2ofus is online now   Reply With Quote Quick reply to this message
Old 03-31-2011, 11:42 PM   post #5 of 7
Toolin
Tech Nerd Tractor Convert
Toolin's Avatar
MTF Member # 18867
Images: 1
Quote:
Sounds like you're talking about a walk-behind.. I used a much bigger tow-behind vaccuum for a similar "blow mulch into pickup" task and it didn't really work all that well, so I'd assume a smaller walk-behind will have an even tougher time of it.
Here's my thread on the experience. Worked, but very slowly, and did clog up quite a bit in the process. After all was said and done, I would have gotten the job done faster and with less effort if I just shoveled the mulch into a bunch of 55 gal trash cans and put those in the pickup bed.
Also it didn't really grind it up much.. came out the other end pretty much same as it went in. But I was ok with that because I wasn't trying to make it smaller.. just get it off the ground into the truck.
__________________
Paul.
i1050|Maint|Gov|Tach:ind,laser|Deck|Blade|JBJr|SBlow:Fit,Winch,Act|Chain|Cyclone|Sweep|Gators|Aerator|Cart|Knob|Hoist|Cab|Trailer|PC|Bits
"Grass is the cheapest plant to install and the most expensive to maintain." ~Pat Howell
Toolin is offline   Reply With Quote Quick reply to this message
Old 04-01-2011, 09:14 AM   post #6 of 7
ryker
Senior MTF Member
MTF Member # 36692
Thanks guys. That's the advice I wanted to hear.
I can manual load my 8ft longbed in about 1hr. So it's not worth my money to buy a walk behind vacuum.
Sponsored Links
Advertisement
Old 04-01-2011, 10:39 AM   post #7 of 7
APinNY
I didn't do it!
APinNY's Avatar
MTF Member # 22011
Images: 5
I ***-umed you meant a towable machine with a pickup hose, but for a walk-behind I would not recommend it either. Sorry for the confusion.
__________________
Al
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
