stalls going uphill - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Small Engines and Repair
Midwest Mower Pro
Reply
Thread Tools Display Modes
Old 03-31-2011, 09:20 AM   post #1 of 20
merc525sc
MTF Junior Poster
MTF Member # 57442
Default stalls going uphill
I have a Craftsman DYT4000 with a new 17.5 HP B&S engine. The engine runs great all day except when going uphill. It starts to run rough and then stalls. I have removed the fuel tank and lines, and the carb bowl and cleaned them thoroughly. This happens regardless of how much fuel is in the tank. When it stalls, I roll it to level ground and it starts and runs great. Any suggestions would be very appreciated.
merc525sc is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 03-31-2011, 02:44 PM   post #2 of 20
RamHD
Jack of (some) Trades...
RamHD's Avatar
MTF Member # 54281
Default Re: stalls going uphill
It might be a float problem...i.e. busted, or needle sticking...You might try taking the carb off and cleaning it really well, maybe even a rebuild kit.
Post your engine model and type #'s ?
__________________
John Deere L110 John Deere216 Cub Cadet 86 Cub Cadet 108 Cub Cadet 126 Mahindra Max 28 4x4 w/FEL....
The majority as to numbers, wealth,and political influence are often wrong. If in such cases a person would do right, he must not be governed by public opinion, however it may be expressed, but by the law of God. {see Proverbs 4:14}
RamHD is online now   Reply With Quote Quick reply to this message
Old 03-31-2011, 06:26 PM   post #3 of 20
merc525sc
MTF Junior Poster
MTF Member # 57442
The engine is a Briggs & Stratton, 17.5 HP, family # 7BSXS.5012VP
Old 03-31-2011, 08:51 PM   post #4 of 20
RamHD
RamHD's Avatar
MTF Member # 54281
Quote:
There should be more numbers, on the engine itself there will be a Model#, Type#, and Code#. These numbers will help us find exactly which engine and the exact carb, etc. that you have....which will help us in troubleshooting your problem.
Numbers should look similar this...
.Model......Type........Code
021032 - 0111-E2...040211ZE
__________________
Old 03-31-2011, 08:51 PM   post #5 of 20
bstrucker
Proud Member of the 1K Club
bstrucker's Avatar
MTF Member # 18659
Usually if you have a problem with the engine running bad on a grade,uphill,downhill or side hill,it's either a float or fuel delivery problem.I didn't look the engine up to see what carb is on it,is isa gravity feed engine or is there a fuel pump?
__________________
Butch
http://beau5278.blogspot.com/
bstrucker is online now   Reply With Quote Quick reply to this message
Old 04-01-2011, 12:59 PM   post #6 of 20
Shryp
Senior MTF Member
Shryp's Avatar
MTF Member # 49725
Does your engine have a low oil sensor?
That is a common complaint I have seen with Honda clones and steep angles / bouncing.
I know nothing about your engine though, just guessing.
Shryp is offline   Reply With Quote Quick reply to this message
Old 04-01-2011, 07:01 PM   post #7 of 20
Oldphil
Senior MTF Member
MTF Member # 33500
Drop the float bowl readjust the float it is to high, very little else could cause that condition.
Oldphil is offline   Reply With Quote Quick reply to this message
Old 04-01-2011, 11:26 PM   post #8 of 20
merc525sc
MTF Junior Poster
MTF Member # 57442
RamHD-- the only other numbers I could find on the engine are 277274 these are right after the above mentioned #'s
Old phil-- thanks for the advice. I will certainly try that, this whole thing has me perplexed
Old 04-02-2011, 05:52 PM   post #9 of 20
RamHD
RamHD's Avatar
MTF Member # 54281
None of those numbers you provided will pull up under Briggs & Stratton or Craftsman.
if your engine is a Briggs, there are numbers on your engine that look like what I posted above.
__________________
Old 04-03-2011, 09:19 PM   post #10 of 20
merc525sc
MTF Junior Poster
MTF Member # 57442
the only numbers I could find are
model 3C707
type 0026G1
code 071025ZA
I hope this helps, lawn season is fast approaching
Old 04-05-2011, 12:08 PM   post #11 of 20
RamHD
RamHD's Avatar
MTF Member # 54281
model 3C707
type 0026G1
code 071025ZA
Need one more number in that model..??? verify all numbers carefully.
With the correct numbers we can get you a parts diagram of your carb and help you work on the issue.
The symptoms you have are classic of float/needle/seat problems.
__________________
Old 04-05-2011, 10:20 PM   post #12 of 20
merc525sc
MTF Junior Poster
MTF Member # 57442
RamHD- my mistake, should no better than to try and read it in low light conditions.
The correct # is... 31C707
Old 04-05-2011, 10:30 PM   post #13 of 20
Grand Sierra
2000 Posts and climbing!!!
Grand Sierra's Avatar
MTF Member # 26788
Im leaning towards float out of adjustment also. Float should sit level.
__________________
Grand Sierra is online now   Reply With Quote Quick reply to this message
Old 04-05-2011, 10:58 PM   post #14 of 20
mowerflipper
MTF Member
mowerflipper's Avatar
MTF Member # 56915
Garage
Had this very thing happen to me yesterday my issue was a stuck float when i took mine off i sanded the float down a little bit cleaned it back up and blew air all the way through all the crevices put it back together worked liked a brand new one good luck
__________________
1978 sears19.9 gt
1980 snapper
1995 huskee 18.5 I/C gt
2009 craftsman 21 hp plat with ag tires
2006 scag turf tiger 300 hrs need i say more
6.5 kids from 1997 to 2009 one due in oct
I have worked for so long with with so little I can do almost anything with nothing!!!!
mowerflipper is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 04-06-2011, 09:18 AM   post #15 of 20
RamHD
RamHD's Avatar
MTF Member # 54281
You have one of these carbs. Hopefully the Walbro..the Nikki is a piece of junk IMO....Here is a IPL blow up of the carbs....
you can look here for part #'s if needed
Carb parts @ Jack's
__________________
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
