Rustoleum truck bed lining on a mower deck - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Backyard Round Table - L & G Tractor Related Topics Lawn and Garden Tractor Related Topics General Discussion Board
Reply
Thread Tools Display Modes
Old 03-30-2011, 12:36 PM   post #1 of 23
bgkast
MTF Member
MTF Member # 57396
Default Rustoleum truck bed lining on a mower deck
Through a search I came across a few threads where members have used truck bed liner to protect mower decks from chipping and rusting, with varying results. Has anybody tried the rustoleum brand rattle can liner, and if so how has it worked out? A quick Google search showed that the off-roader guys say it sticks better than the other off the shelf type bed liners. It also seems to have a finer texture than other bed liners I have seen which will hopefully help grass not stick like crazy to it. I'm thinking about using it top and bottom on my MTDs deck that I am rebuilding, what do you guys think?
bgkast is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 03-30-2011, 01:12 PM   post #2 of 23
TooTall999
MTF Member # 45132
Default Re: Rustoleum truck bed lining on a mower deck
I'd think the fact that it has texture at all would be a problem. On a mower deck you'd want as smooth and slippery a surface as possible. I'm looking at some Eastwood chassis black gloss paint for my mower. Tough enough to maintain a glossy black finish and prevent rust on a car or truck frame...should hold up to mowing...
TooTall999 is offline   Reply With Quote Quick reply to this message
Old 03-30-2011, 01:31 PM   post #3 of 23
locknut
Senior MTF Member
locknut's Avatar
MTF Member # 6727
Images: 1
Bought the quart can and brushed it on under deck.Sticks and stones will chip it off,but it will protect the metal where stuff normally hangs and causes deck rot,so not all bad.
locknut is online now   Reply With Quote Quick reply to this message
Old 03-30-2011, 01:48 PM   post #4 of 23
Ken N Tx
Retired MTF Admin
Ken N Tx's Avatar
MTF Member # 117
Images: 60
Garage
Many many paints and stuff have been tried (underside)...If you come up with a remedy you will be richer than Bill Gates!!
Everything that I have tried have been "sand blasted" off the underside of my decks..
__________________
Ken N Tx is offline   Reply With Quote Quick reply to this message
Old 03-30-2011, 01:56 PM   post #5 of 23
mistavp05
Addicted to seat time!
mistavp05's Avatar
MTF Member # 34972
You said it Ken. Each season I do another coat of whatever color paint I have hanging around in the shed on the underside of the deck, and after the season is over, there is no trace of that paint at all.
mistavp05 is offline   Reply With Quote Quick reply to this message
Old 03-30-2011, 02:49 PM   post #6 of 23
Onan18
2000 Posts and climbing!!!
Onan18's Avatar
MTF Member # 40653
I got this Industrial grade metal primer from a metal fabrication shop that was going out of business, 100 gallons of it! When I re-built the deck for my suburban after all welding and grinding/sanding was done I mixed this primer 50/50 with thinner, (it is a gooey thick paste right out of the can) and after I chemically treated the bare metal with rust converter I brushed on this stuff THICK! I applied three coats and then painted my deck with Valspar Anti-Rust white (wasn't concerned about correctness) and three seasons later I am very pleased with how well it has held up.
Joe
Onan18 is online now   Reply With Quote Quick reply to this message
Old 03-31-2011, 12:10 PM   post #7 of 23
JRJ
The owners manual
JRJ's Avatar
MTF Member # 28174
Ken N Tx; yes look where you live, lots of sand in the ground, having your own sand blaster, I know for I lived in Ft.Worth for 5 yrs.
Dick
JRJ is offline   Reply With Quote Quick reply to this message
Old 03-31-2011, 12:52 PM   post #8 of 23
hodge
Proud Member of the 1K Club
MTF Member # 52532
I have used the different spray bedliner coatings (although, not the Rustoleum), and have been disappointed in how it holds up. They chip easy, and they do have texture. Also, I made some battery hold downs for my truck, and painted them with spray bedliner coating, thinking that this would resist corrosion, and it hasn't. Both metal bars have corroded within months. I plan to use POR 15 on the underside of the deck of my B80. It may not hold up over time, but as has been stated, not much will. Perhaps you should test the Rustoleum on something besides the deck, to see how tough it is, and the texture, before applying it to the deck.
__________________
Romans 1:16 "For I am not ashamed of the Gospel of Christ..."
hodge is offline   Reply With Quote Quick reply to this message
Old 03-31-2011, 12:56 PM   post #9 of 23
zelda
zelda's Avatar
MTF Member # 33532
Images: 14
Friend of mine treated his with KBS on the underside of his Deer mower. He is very pleased with that results. I use POR 15, There were a couple spots it didn't hold up. I didn't sand blast it either. I would do it again.
__________________
149 Cub Cadet
990 Farm King
C-141 Wheel Horse (Sold)
Host of the "MTF Michigan Meet 2011"
zelda is offline   Reply With Quote Quick reply to this message
Old 03-31-2011, 01:06 PM   post #10 of 23
esnb74
Desk by Day/Shop by Night
esnb74's Avatar
MTF Member # 43409
Images: 8
Quote:
It holds up great on car frames quite well. Used it many times.
__________________
JD 318 H3
JD 140 H1 Mods coming slowly: http://www.mytractorforum.com/showthread.php?t=290386
CC 124 (Future Mini Farmall build)
CC 1250 (Future IHC 966 Tribute build)
Farmall H (One of the many Farmall's I grew up with)
Ford Mustang (64.5)
Past Equipment: JD 316, JD 318, JD 757 Ztrak, IHC 1100A Pickup, CC 3235
Remember: Freedom Isn't Free!
esnb74 is offline   Reply With Quote Quick reply to this message
Old 03-31-2011, 01:22 PM   post #11 of 23
bgkast
MTF Member
MTF Member # 57396
Thanks for the input. I am still preping the deck, so I will try painting some scrap with the liner material tonight and see how tough it seems.
Old 03-31-2011, 03:18 PM   post #12 of 23
sloweather
Senior MTF Member
sloweather's Avatar
MTF Member # 45060
Shiny, hard, smooth, abrasion resistant...
Get it chromed!
__________________
sloweather is offline   Reply With Quote Quick reply to this message
Old 03-31-2011, 08:22 PM   post #13 of 23
Kbeitz
Collector of many tractors
Kbeitz's Avatar
MTF Member # 86
Images: 4
I use slip-plate
__________________
Kbeitz is offline   Reply With Quote Quick reply to this message
Old 04-02-2011, 11:53 AM   post #14 of 23
butchs_hobby
MTF Member # 1189
Six years ago when I redid the mower under my 1650MF I painted the underside of the deck with the same paint (PPG) loaded with gloss hardner as I used on the tractor, so far it's holding up pretty well. Probably need to repaint it after this season, I noticed that the clover tends to stick to the mower now. Usually run over a few tree limbs (1"-2") and that keeps it pretty well cleaned out.
butchs_hobby is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 04-02-2011, 12:30 PM   post #15 of 23
AMCJavelin74
Old Iron 1%er
MTF Member # 43316
what about getting a good 'base' paint (whatever you have, or choose to buy), then a couple coats of that graphite paint that some guys use in their snowthrowers?
http://www.agspecialty.com/EZslide.htm
AMCJavelin74 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
