| Register | Home | FAQ | Active Topics | Garage | MTF Gallery | Search | Today's Posts | Mark Forums Read | Store | Chat Room |
Thread Tools | Display Modes |
#1 |
MTF Member
I do not own a manual for my 1968 Ford 2000 diesel so i need to know what type of fluids go into the rear axle housing and the gear shift housing. I was told that hydralic fluid will go into the rear axle housing because that is where the hydralic pump fluid comes from. I do not know what type of fluid goes into the gearbox. Thanks in advance....Tom....."Go Kentucky WildCats"....
| Sponsored Links | |||
Advertisement | |||
#2 | |
Not a restorer
Quote:
Look for square-head plugs on the right side for the fill level.
__________________
Ford 4500 diesel TLB (740/753) Ford 4500 gas 740 Loader/3-point (no pto) |
#3 |
2000 Posts and climbing!!!
The rear end needs UTF (which really stands for Universal Tractor Hydraulic Fluid, but they leave out the H when they abbreviate it) that meets the Ford 134D specification. If it has the Select-O-Speed transmission then it needs the 134D UTF as well. If it has a manual transmission, it can take standard gear oil (80w90), or 134D UTF. Most folks use the 134D in the manual transmission for a couple of reasons, 1. to avoid cross-contamination with the 134D in the rear if a seal leaks, and 2. it's simpler to have a single fluid for everything.
If it has power steering, use 134D in the power steering pump as well.
__________________
Nouveau Redneck Sean in PA 1973 Ford 4000 3-cyl gas w/Select-o-Speed & 60 inch Woods rotary mower 2008 John Deere X500 w/54c deck, 48" snow blade and 48" shovel 2010 John Deere X304 w/42" deck You know you might be a Nouveau Redneck if... 1. You use the cup holder on your tractor to hold your cosmopolitan instead of a beer 2. You're "Santa on a tractor" Christmas yard decoration is actually a high tech digital hologram. 3. Your deer camp cuisine is better than most 3 star restaurants. |
#5 |
Senior MTF Member
MTF Member # 33054
I'm planning to change the oils on my 3000 8speed pretty soon; since we're on the subject, does anyone know how many gallons the rear, and transmission on an 8speed take? It would be very helpful to know how many gallons one needs to change out both the rear and transmission oils so you don't buy too much or you don't find yourself short having to go back into town for more oil. Thanks!
#6 |
Senior MTF Member
MTF Member # 54578
#7 |
Senior MTF Member
MTF Member # 33054
Thanks for the Data sheet! Looks like with a 8spd Transmission you're looking at 3.3 Gallons-trans, and 6.3 gallons in the the rear end/hydraulic. 9.6gallons Total; so if you plan on using the same type of oil you're looking at 2 5gallon buckets.
#8 |
Senior MTF Member
MTF Member # 54578
\\fastback4
It's the same volumes for your 2000 for the engine and rear axle as the 3000. I didn't find any 2000 data sheet in english, this one is in swedish: http://www.fordson.se/phpBB2/viewtopic.php?t=5739 Converting the units can be done here: http://www.calculatoredge.com/index.htm#general Volumes for Ford 2000 Engine (incl. filter) = 6.6 liters = 1.6 gallons Trans (8-speed) = 12.5 liters = 3.3 gallons Rear axle = 23.9 liters = 6.3 gallons Fuel tank = 49 liters = 13 gallons Radiator = 12.5 liters = 3.3 gallons |
#9 |
Proud Member of the 1K Club
![]() Join Date: Mar 2005
MTF Member # 94
the 2000 and 3000 are virtually identical machines.
a lil extra oil on hand is great for topping off.. etc. soundguy |
#10 |
Senior MTF Member
MTF Member # 54578
By the way, if the tractor is equipped with external cylinders of some kind, for instance a loader, fed by the tractors pump the extra volume they need is added to the given volume for the rear axle.
Oil change procedure: A. Lower the lifting arms fully down. B. All external cylinders fully in. C. Remove drain plug and drain the rear axle. D. Replace drain plug and remove filler and level plugs. E. Fill rear axle to level plug hole. F. Start engine and lift arms fully up. G. All external cylinders fully out. H. Fill rear axle to level plug hole. |
#11 |
MTF Member # 94
however if they are DA cyls.. you won't see half that fluid though, as it will be tied up on one sode of the piston always..
I always fill.. exercise all cyls, then top off to nominal level. soundguy |
| Sponsored Links | |
Advertisement |
#12 |
TexasFire
MTF Member # 55242
I drained my trans today & got about 6 gallons of a very thin oil out, definitely not gear oil so I am suspecting that a previous owner already put UTF in the front & back. It continued to drain real slow for a long time so I suspect the internal seal was leaking from the back to the front. I haven't drained the back end yet.... I had planned to use gear oil in the trans & UTF in the back end but I guess I'll just put UTF in both.
The fluids looked pretty good, but I have no prior history on the machine except that it sat for over 2 years without being run. I don't want to work the girl until she has fresh fluids! TexasFire
__________________
1968 Ford 2000 Bush Hog 72" finish mower Rhino 60" brush hog 4' J-Bar Junior box blade 3 point scoop bucket 2001 Scotts 25HP 54" Hydro Lawn Tractor 1998 Sears 15HP / 42" Hydro Lawn Tractor Stihl Farm Boss 18" chain saw Echo SRM-230 weed eater Echo PBH-410 back pack blower Columbia Par Car golf / utility cart 1976 Ford Fire Truck Boneyard: Ground Hog T4 Trencher Swisher 60" 15HP Trail Mower Huskee 38" cut 13HP Lawn Tractor Murray 42" cut 15HP lawn tractor Dynamark 5HP tiller |
| Sponsored Links | |
Advertisement | |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | |
