| Register | Home | FAQ | Active Topics | Garage | MTF Gallery | Search | Today's Posts | Mark Forums Read | Store | Chat Room |
| John Deere Forum John Deere Garden Tractor talk |
Thread Tools | Display Modes |
#1 |
MTF Member
MTF Member # 4898
I have a 1995 425 that has the shorter seat on it. I'd like to know if I could purchase a seat for a 445 (taller back seat) and put it on my 425. Is it a direct bolt up or does it take different mounting hardware?
| Sponsored Links | |||
Advertisement | |||
#2 |
Senior MTF Member
MTF Member # 28946
There is a different mounting bracket, on the 445 and 455 there is just a cotter key to remove and then the seat pulls off, it has a couple of brackets on bottom for a rod to go thru. I don't believe the 425 has these, not that you couldn't replace the whole seat bracket though.
__________________
bvp2000JD 455/40 Loader JD 755, JD 425, and JD 7 Cart JD's not hidden from the wife well enough! JD 425, JD 425AWS, JD 322, JD 318, JD 317, JD 425 JD G100, JD 318, JD 445, JD 445, JD 265, JD 455, JD 332, JD 455, JD 430, JD 318, JD 777 and JD X495 |
#3 |
Deere Guru
Is the 445/455 seat that much better? I need a new 425 seat . . . and I've thought about the whole bracket and seat from a 445/455, but wasn't sure if it was really worth it.
__________________
1996 John Deere 455 AWS 1996 John Deere 425 - w/ upgraded tire size, rear PTO, and 3PT Hitch #40 Loader, 54 and 48" MMM Deck, 46" Snow-Thrower, 54" Front Blade, Agri-Fab 3PT Core Aerator, Agri-Fab Chip-n-Vac, and #80 Cart |
#4 |
MTF Member
MTF Member # 4898
It's got a higher back to it which I like. I like the seat on my 2305 a LOT better than my 425 due to the taller back on it. I might make you a great deal on a like new original 425 seat....
#5 | |
Deere Guru
Quote:
__________________
#6 |
Senior MTF Member
MTF Member # 37543
You can just change your seat, did it on Dad's 425 when he had it. But if you what to upgrade the suspension don't get the one for the 445/455 way to much money get one for the x595 that is what I did. Only ting I could see between the two was the 455 suspension had bolts build into it and the x595 suspension just had the holes.
Link to what I did http://www.mytractorforum.com/showthread.php?t=151159
__________________
1997 John Deere 455 ![]() |
#7 |
MTF Member
MTF Member # 21317
98ramtough, I put the deluxe seat and suspension from an X748SE on my X748 and kept the original suspension. The deluxe suspension was put on when I bought the new tractor so the original suspension is new. I sold the original seat but have a seat from an X595 that has a crack or two but is still very usable.
If you have some interest send me a personal message. Thanks, Terry, |
| Sponsored Links | |
Advertisement |
#8 |
Just John Deere
98ramtough,
I have a high back seat like the one on a 445, but it has a bolt pattern that should fit your 425. It came off a 322 that I bought but was installed using only 2 bolts. I never knew exactly what it was designed for, but it may fit. I will take a picture of the bolt pattern Monday and post it. I have two 455's with the high back seat and it is SOOOO... nice for my back. GotDeeres
__________________
Just John Deere John Deere 318 Garden Tractor John Deere 322 Garden Tractor John Deere 332 Diesel Garden Tractor with Compact Loader John Deere 345 Garden Tractor with Piranah Deck John Deere 425 Garden Tractor with 54C Deck John Deere 455 Diesel Garden Tractor with Compact Loader John Deere 455 Diesel Garden Tractor 3 Point and 540 PTO John Deere 455 Diesel Garden Tractor with a 450 Tiller John Deere 2210 CUT with Compact Loader John Deere TS Gator |
| Sponsored Links | |
Advertisement | |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | |
