| Register | Home | FAQ | Active Topics | Garage | MTF Gallery | Search | Today's Posts | Mark Forums Read | Store | Chat Room |
Thread Tools | Display Modes |
#16 |
Senior MTF Member
MTF Member # 54578
From Operators manual:
Transmission PTO The transmission type of PTO (available on Ford 2000, 3000 and 4000 tractors) is operated by engaging the clutch, and will stop turning when the clutch pedal is depressed. The drive to the PTO is engaged by depressing the clutch pedal and moving the PTO lever situated on the left-hand side of the rear transmission, fully rearwards. To disengage the PTO depress the clutch and move the lever to the forward position. The table below shows the recommended engine speeds to obtain the PTO speed of 540±10 rpm. Trans--------Model------Engine rpm 6/7 speed...Ford 2/3000....1800 8 speed......Ford 2/3000....1600 8 speed......Ford 4000.......1800 Live PTO Live PTO (available on Ford 2000 and 3000 tractors) operates in a similar manner to 'Transmission' PTO except that an intermediate clutch pedal position stops the tractor without stopping the PTO shaft. To operate the PTO shaft, depress the clutch pedal completely and move the PTO shift lever fully rearwards. Engage the PTO by slowly releasing the clutch pedal until the shaft begins to turn. Allow the PTO shaft to reach the desired speed then slowly engage power to the rear wheels by releasing the clutch for the remainder of its travel. Control the PTO speed and tractor forward travel by use of the throttle and by selecting the right gear. The clutch operating rod clevis pin can be used in two positions. Select the rear position in the clevis to operate and control the drive to the PTO and the tractor. When the PTO is not in use put the pin in the forward position. To obtain a PTO speed of 540±10 rpm an engine speed setting of 1800 rpm is required. Independent PTO (Available only on Ford 4000 and 5000) |
| Sponsored Links | |||
Advertisement | |||
#17 |
Senior MTF Member
MTF Member # 33054
Thanks for all the info. It looks as if I'll be needing to adjust my clutch or separate the tractor to investigate further.
#18 |
Senior MTF Member
MTF Member # 33054
If adjustment doesn't work, will I have to replace the pressure plate too or just the clutch disc?
It's weird because my transmission works great and my clutch engages pretty normal, doesn't engage high on the pedal travel, nor does it slip under heavy load. I'm crossing my fingers it's just mal-adjusted or a worn linkage or something. So I want to adjust so my pedal is at the highest point?--or how do I make sure I adjust it properly? Thanks. |
#19 | |
Senior MTF Member
MTF Member # 21690
Quote:
That is a fairly common problem with dual clutch setups. Engine clutch works OK but PTO clutch is stuck in "engaged" position. Sometimes it's just and adjustment, but often it's just plain stuck. Like I said, if your wheel-drive works well and you can shift fine when the clutch is down - that same clutch cannot be your PTO problem. So, it sounds like you've got two clutches. Now if you had a wheel-drive PTO, it is supposed to clash IF you try to shift while the tractor is rollling. But, I'm not even sure it was available on your tractor. It's a common feature on many other British tractors though, as well on many USA Deere and Henry (AKA Harry) Ferguson tractors. Is your tractor a hi-low range trans model? By the way, I find non-live PTOs to be near useless in Ford tractors. They often come with the four-speed trans setup which is also useless for certain tasks. Way too fast in 1st and reverse. Four speed was dropped mid-70s, and a 3 speed with a hi-low range took its place. Similar to what the Ferguson TO-35s had. 2000s and 3000s before July of 1968 came with four speeds or eight speeds. 2000s and 3000s mid 1968 up to 1975 came with four, six, and eight speeds along with 10 speed hydraulic-clutch transmissions. After 1975, I'm not sure. My 1964 4000 Ford does have a wheel-drive PTO. Ford called it a "ground speed" PTO. |
#20 | |
Senior MTF Member
MTF Member # 33054
Quote:
#21 | |
Senior MTF Member
MTF Member # 21690
Quote:
I assume you've got the 4 X 2, i.e. four speed box against a two speed box that yields 8 speeds forward and 2 speeds in reverse. If you have a single-clutch "tranmssion driven" PTO, that PTO is disconnected from the engine - just as the wheel drive is when the clutch pedal is down. So, if I understand your description of events properly, something here does not make sense. If the trans gears shift fine and don't drag or clash when the pedal is down, the PTO can't clash. Now, if the PTO is generally hard to engage or disaengage anytime - clutch in or out, that's a different story. If the PTO DOES clash, and the trans does NOT, then the PTO is getting rotational power even when that trans-input is not moving. That cannot happen unless you've got a dual-clutch, twin-input shaft tractor. Does the clutch pedal feel smooth all the way when you push it in? If a live PTO setup with a dual clutch, the pedal should feel the same for only about half-way down, and then you feel increased resistance as the pedal starts to disengage the second clutch. |
#22 | |
Senior MTF Member
MTF Member # 33054
Quote:
#23 | |
MTF Junior Poster
MTF Member # 56410
Quote:
What happens is that the inertia of the implement begins providing torque from the inertia of the rotating parts to the drive wheels by the pto shaft through the driveline. Stepping on the clutch does not stop the process but the orc will. It only allows torque to be transmitted from the pto to the implement and not vice versa. It's kind of a torque diode.
__________________
Jerry |
#24 | |
Senior MTF Member
MTF Member # 33054
Quote:
#25 |
Senior MTF Member
MTF Member # 33054
I tried adjusting the clutch today by making the linkage shorter. I'm not sure if this is correct but it didn't help anything. I am starting to think I need a clutch. The tractor does NOT have two seperate holes for adjustment. I was reading on a seperate post that it's better to have someone re line and rebuild my clutch disc and pressure plate instead of buying an aftermarket? Any tips on splitting the tractor? Thanks...
#26 |
2000 Posts and climbing!!!
According to your model number you do not have live PTO. If you can shift the PTO lever without grinding when the PTO has nothing connected to it, but it grinds when you have the brush hog connected, I suspect something is loose in the PTO drive line allowing the weight of the brush hog to cause the engagement gears to go out of alignment. With the engine off, try to move the PTO shaft in and out, up and down and left to right by hand. If it has any play in it then you may need to go inside to correct whatever is allowing the free play.
__________________
Nouveau Redneck Sean in PA 1973 Ford 4000 3-cyl gas w/Select-o-Speed & 60 inch Woods rotary mower 2008 John Deere X500 w/54c deck, 48" snow blade and 48" shovel 2010 John Deere X304 w/42" deck You know you might be a Nouveau Redneck if... 1. You use the cup holder on your tractor to hold your cosmopolitan instead of a beer 2. You're "Santa on a tractor" Christmas yard decoration is actually a high tech digital hologram. 3. Your deer camp cuisine is better than most 3 star restaurants. |
#27 |
3K Poster!!!!
#28 |
Senior MTF Member
MTF Member # 33054
I checked the pto shaft yesterday for play. It has no side to side play, and in and out play it has like an 1/16 of an inch if that. When I engage the pto and it is turning, shouldn't depressing the clutch stop the pto when no implements are on the pto?
#29 | |
MTF Junior Poster
MTF Member # 56410
Quote:
The early Fords(9N, 2N, 8N) and the early Ferguson's (TO-20, TE-20 and TO-30) all had transmission driven pto's. I believe the non DeLuxe models of the TO-35 also had them. So this is a common issue for them. Ther were probably other. I'm surprised your 3000 has that. I thought the "newer" 1000 Series Fords had live pto. The Pto is driven through the transmission not through a second shaft from the engine like a live or independent pto. It "hard linked" to the drive line that drives the rear wheels so disconnecting the engine from the transmission via the clutch doesn't do any thing to that part of the drive line. Only an ORC will keep the inertia of a pto implement from driving the machine forward. it's just a sprag clutch that transmits torque one way to the implment and ratchets when torque from the implement tries to drive the rear wheels.
__________________
Jerry |
| Sponsored Links | |
Advertisement |
#30 | ||
Quote:
Quote:
__________________
| Sponsored Links | |
Advertisement | |
| Currently Active Users Viewing This Thread: 4 (0 members and 4 guests) | |
| Thread Tools | |
| Display Modes | |
