How does a Trans PTO work? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 03-18-2011, 08:49 AM   post #1 of 53
krazymatt
Senior MTF Member
krazymatt's Avatar
MTF Member # 33054
Default How does a Trans PTO work?
I recently got a 1974 Ford 3000 Diesel English model, and according to the serial number it has a "Trans PTO". I'm just curious how it's supposed to properly work? I've had a independent and live pto, but never a trans pto. It's the only thing I don't like about this tractor but it was a great deal. I've noticed it seems to always be on or off and is difficult to shift. If I press the clutch in it doesn't stop. I'd appreciate some explanation as to how it was designed to work and that way I can see if it has problems that I'll need to address. Thanks...
krazymatt is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 03-18-2011, 08:59 AM   post #2 of 53
raytasch
Old Guy With Old Toys
raytasch's Avatar
MTF Member # 4585
Images: 2
Default Re: How does a Trans PTO work?
IMo, they named it wrong. Should have been called a clutch driven PTO. Assuming the "Britts" built it like Henry and Harry designed it, the PTO is driven through the clutch, to the transmission, through the transmission, and toward the rear of the tractor where the PTO engagement lever is, and then out the rear. If the PTO engagement lever is on and the clutch is engaged the PTo turns. "Tractor won't stop", you need an overrun coupler at the PTO. Short version, got to go.
__________________
ray
Ford Jubilee-- restored, pulls a finish mower once in a while
Ford 850 -- the workhorse--does it all
IH CC 122--semi retired-awaiting restoration
JD 4300HST FWDA W/Loader--- another workhorse
Sears DGS6500
raytasch is offline   Reply With Quote Quick reply to this message
Old 03-18-2011, 11:25 AM   post #3 of 53
krazymatt
Senior MTF Member
krazymatt's Avatar
MTF Member # 33054
Quote:
So if the clutch is depressed it should stop the pto?
What is a overrun coupler?
Old 03-18-2011, 11:48 AM   post #4 of 53
Nouveau Redneck
3K Poster!!!!
Nouveau Redneck's Avatar
MTF Member # 19566
Images: 1
I think that transmission driven PTO is the correct name for it. The PTO is connected directly to a gear in the transmission. The clutch drives the transmission, and the transmission drives the PTO.
Not necessarily. If the tractor is still rolling when you press in the clutch, like when you're coasting down a hill, the PTO will still be getting power from the transmission. If you have a heavy implement attached to the PTO, like a brush hog or a roto-tiller, the implement's momentum can force the PTO to continue to rotate even when you push in the clutch and press on the brakes, and that momentum can actually overcome the power of the brakes and cause the tractor to keep driving forward because the PTO is directly coupled to the transmission.
An overrun coupler (ORC) is basically a one-way ratcheting mechanism that you connect to the PTO shaft on the tractor that has an output shaft that is the same as the PTO output shaft. It is made to transfer power from the PTO on the tractor to the attachment when the PTO is supplying power to the implement, but when the PTO stops supplying power and tries to spin slower than the implement, like when you put in the clutch and apply the brakes, the ORC ratchets and allows the implement's momentum to keep it spinning without having that momentum come back up the PTO shaft into the transmission so that you can stop or slow down when you need to without being driven forward out of control.
__________________
Nouveau Redneck
Sean in PA
1973 Ford 4000 3-cyl gas w/S-O-S & 60 inch Woods rotary mower
2008 John Deere X500
2010 John Deere X304
2014 Kubota BX25D w/50" snow blower
You know you might be a Nouveau Redneck if...
1. You use the cup holder on your tractor to hold your cosmopolitan instead of a beer
2. Your "Santa on a tractor" Christmas yard decoration is actually a high tech digital hologram.
3. Your deer camp cuisine is better than most 3 star restaurants.
Nouveau Redneck is offline   Reply With Quote Quick reply to this message
Old 03-18-2011, 12:16 PM   post #5 of 53
krazymatt
Senior MTF Member
krazymatt's Avatar
MTF Member # 33054
So the ORC is basically a solution for the crappy design of the trans pto?
How much is a ORC?
Yesterday I noticed with a brush hog, I was having trouble shifting the PTO lever into gear with the clutch depressed and the tractor stopped; it was grinding. Did I have to have the tractor in gear? Perhaps I need a clutch adjustment or clutch replacement? The clutch itself is in great condition and doesn't slip or engage high as far as normal operation of the tractor without PTO operation.
Old 03-18-2011, 02:00 PM   post #6 of 53
raytasch
raytasch's Avatar
MTF Member # 4585
Images: 2
Quote:
How much is a ORC?
The Transmission driven PTO is a 60 year old design. I doubt if Harry or Henry had any visions of how useful the PTO would become. Crappy design? Basic no frills low cost 60 YO engineering but I would not say crappy. PTOs have evolved. Thousand and thousands of them working every day.
ORC, about $50. many places. Check the vendor supporters of this fine site.
The problem getting into gear with the 'hog' installed is typical. Install the ORC and then adjust the clutch if needed.
__________________
ray
Sears DGS6500
Old 03-18-2011, 04:07 PM   post #7 of 53
krazymatt
Senior MTF Member
krazymatt's Avatar
MTF Member # 33054
I don't mean it's a crappy design in that it doesn't work. I just thought that by 1974 they would've installed independent or live PTO's on all their machines and done away with the early 1900's technology. You would think that it would be more costly to the manufacturer to offer so many PTO options in those days. If it's normal to have trouble getting it into gear with the hog on is good in that I hopefully don't have to do any costly repairs. Thanks
Old 03-18-2011, 04:10 PM   post #8 of 53
krazymatt
Senior MTF Member
krazymatt's Avatar
MTF Member # 33054
So if say one would want to convert a Trans PTO to a indepedent or Live PTO would you need the whole rear half of the tractor as a donor or is it even possible? Thanks...
Old 03-18-2011, 05:20 PM   post #9 of 53
Nouveau Redneck
3K Poster!!!!
MTF Member # 19566
Images: 1
They sold them with the various PTO options at different price points. Just like you can get a car with manual or power windows and/or door locks, etc. Some people bought them without a PTO at all because they didn't need one, they just pulled plows and wagons, others used the PTO to drive irrigation pumps. Heck, some people bought tractors and parked them next to their irrigation water source and left them connected to a PTO driven irrigation pump for their entire lives, and the tractor only got driven that first time just to get to that spot where it spent the rest of its life driving a pump. If it's going to sit with the gear shifter in neutral all the time, simply running a pump whenever the engine was running, why bother with live or independent PTO?
There are a few on here who could give you the exact list of parts you would need to swap out to get live or independent PTO. It would probably be cheaper, and definitely much easier, to sell that tractor and buy one that already has the live or independent PTO.
__________________
Nouveau Redneck
Sean in PA
Old 03-18-2011, 06:41 PM   post #10 of 53
JohnW
3K Poster!!!!
JohnW's Avatar
MTF Member # 1445
Images: 3
Garage
It is possible but you need everything from the flywheel on the engine back to make the conversion. As said sell the tractor and buy one with the PTO you want.
I have never been really bothered by the type of PTO a tractor has, just always made sure to have the ORC no matter what type the PTO. Now live hydraulics THAT's a different story.
JohnW is offline   Reply With Quote Quick reply to this message
Old 03-18-2011, 07:20 PM   post #11 of 53
krazymatt
Senior MTF Member
krazymatt's Avatar
MTF Member # 33054
Yeah, It doesn't bother me much as long as it works. The only thing I'll use the PTO for is bush hogging. A ORC will take care of any safety issues. Does the ORC usually stay with the bush hog or implement when it's off or on the tractor? Come to think of it I need to check and see if there' s not one on the bush hog that came with the tractor. I haven't used it yet and I noticed it had a very different drive shaft hookup. It didn't have the spring with pin; it had a round colar looking mechanism. I've never seen a driveshaft hookup like it. Maybe if I'm lucky there's one on that bush hog drive shaft.
Old 03-18-2011, 09:28 PM   post #12 of 53
JohnW
3K Poster!!!!
JohnW's Avatar
MTF Member # 1445
Images: 3
Garage
No the ORC is attached to the tractor, the slip clutch is usually attached to the bush hog.
Old 03-18-2011, 10:35 PM   post #13 of 53
JRC0528
Proud Member of the 1K Club
JRC0528's Avatar
MTF Member # 21688
Yeah, the ORC usually is pinned to the PTO shaft of the tractor using a roll pin. Consider it a semi-permanent attachment to the tractor; the only time you'll likely remove it is for maintenance. Once installed, you'll connect all PTO driven implements to it.
__________________
Jim C.
Many a man in love with a dimple makes the mistake of marrying the whole girl!
-- Stephen Leacock on the danger of infatuation
JRC0528 is online now   Reply With Quote Quick reply to this message
Old 03-19-2011, 01:38 AM   post #14 of 53
souNdguy
souNdguy's Avatar
MTF Member # 94
i'd like to add that with the tractor stopped and implement stopped, it should not be hard to engage the pto and it should not grind. if it does.. clutch may be dragging.
might check to see if pto shaft has in / out "thrust' play this could have damaged the 'dog' clutch..
soundguy
souNdguy is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 03-19-2011, 06:27 PM   post #15 of 53
jdemaris
Senior MTF Member
MTF Member # 21690
There are three basic types of PTOs on farm tractors. Live, transmission driven, and wheel driven. I'm not sure what exactly your 3000 has.
Live means the PTO can be turned "on" or "off" with no effect on the wheel drive -and the wheel drive can be "engaged" or "disengaged" without affecting the PTO operation. Often done with a dual-clutch setup, but can also be done via a separate hydraulic system for the PTO and often marketed as "Independent." To be technical, the very first dual-clutch PTOs were patented as "independent."
Transmission-driven usually means the PTO get's it power from the transmission side of the main engine clutch via the trans-input shaft. So, when that clutch is used to disengage the wheel drive, the PTO stops also.
Wheel driven is a PTO that is, in-part, powered by transmission gears - but only turns when the wheels are actually turning. My Deere 1020 and Ferguson TO35 have three-way PTOs - with live, trans, and wheel drive.
jdemaris is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
