3 Point Hitch Stabilizer Bar Question - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Register Home FAQ Garage MTF Gallery Search Today's Posts Mark Forums Read Store Chat Room [1]
The Barn General discussion of Full size tractors and accessories
Reply
Thread Tools Display Modes
Old 03-16-2011, 01:00 PM   post #1 of 12
weekend_warrior
Senior MTF Member
weekend_warrior's Avatar
MTF Member # 26885
Images: 1
Default 3 Point Hitch Stabilizer Bar Question
Is there any 3PH attachment that you should NOT use the lower link stabilizer bars with?
__________________
1940 Ford 9N
1955 Ferguson TO-35 Deluxe
1974 Model D Harley Davidson 3-wheel golf cart
1985 Craftsman 18HP lawn tractor
2010 Cub Cadet Z-Force S
weekend_warrior is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 03-16-2011, 01:06 PM   post #2 of 12
bryan
MTF Member
MTF Member # 28014
Default Re: 3 Point Hitch Stabilizer Bar Question
I use various cutters, boom and plows and use the stabilizer chains on all of these. I always leave a little play to allow the attachment to move slightly to reduce stress in the event I bump something while working.
bryan is offline   Reply With Quote Quick reply to this message
Old 03-16-2011, 03:36 PM   post #3 of 12
weekend_warrior
Senior MTF Member
MTF Member # 26885
Images: 1
Just to clarify, I'm asking about the extra stabilizer bar you can attach to the lower arms of the 3PH, like this:
http://www.tractorsupply.com/agricul...versal-0267903
__________________
1940 Ford 9N
Old 03-16-2011, 09:43 PM   post #4 of 12
walterboatwright
Senior MTF Member
walterboatwright's Avatar
MTF Member # 21679
Images: 5
They are ok for side sway reduction unless your mowing. then only use 1.
walterboatwright is offline   Reply With Quote Quick reply to this message
Old 03-17-2011, 10:47 AM   post #5 of 12
weekend_warrior
Senior MTF Member
MTF Member # 26885
Images: 1
Why would you just use one stabilizer when mowing?
__________________
1940 Ford 9N
Old 03-17-2011, 07:38 PM   post #6 of 12
walterboatwright
Senior MTF Member
MTF Member # 21679
Images: 5
It still allows lateral movement arond fence or trees.Brush cutters need some lateral movement especially in thick grass to help buildup on the skid plates to discharge or recut.
Old 03-17-2011, 11:15 PM   post #7 of 12
fastback4
MTF Member
fastback4's Avatar
MTF Member # 19868
Images: 1
Quote:
That's interesting.....Thanks
fastback4 is offline   Reply With Quote Quick reply to this message
Old 03-19-2011, 09:23 PM   post #8 of 12
bryan
MTF Member
MTF Member # 28014
The stabilizer bar serves the basically the same funtion as the chains on my ford, limit the side to side play. I leave them with a slight amount of free play to serve the same funtion as Walterboatwright using one stabilizer bar. Sorry I wasn't very clear in my original posting.
Old 03-20-2011, 11:27 PM   post #9 of 12
RDR
3K Poster!!!!
RDR's Avatar
MTF Member # 4731
Images: 1
If you're mowing with any of my tractors with only one sway chain hooked up you would have the lift arm rubbing against the tire if you are an a bank and the chain is on the low side. I keep both of mine on all of the time. When I'm putting up rows or cultivating they are also tight. If they had any slack I would be digging up whatever crop I'm working.
__________________
Tractors have ag tires. Construction equipment have R-4 tires. If it has turf tires it is a lawnmower.
RDR is offline   Reply With Quote Quick reply to this message
Old 03-27-2011, 01:23 PM   post #10 of 12
harburn
MTF Junior Poster
MTF Member # 35199
Images: 4
Hi, the bar type stabilizer should normally be used in pairs for all implements other than ground engaging ones,ie plows cultivators,ect. Only one exception I've seen was on a MF cutterbar mower (732) it had a mechanism which rested on the left lift arm leaving the right side stabilizer in use, which was ok because it was acting to prevent the mower from moving to the left, the only force when cutting as the cutterbar was to the right thus pulling the stabilizer only, hope this helps.
harburn is offline   Reply With Quote Quick reply to this message
Old 04-06-2011, 01:41 PM   post #11 of 12
MF Poor
MTF Member
MF Poor's Avatar
MTF Member # 57753
You do NOT use stabilizer bars with a plow. (moldboard plow) It should be able to move left or right as needed to allow the tractor to make small corrections in steering. With stabilizer bars, the plow would hold the tractor in a straight line like a boat with the rudder locked in place. A well adjusted plow will track behind the tractor in the proper alignment.
I do NOT use stabilizer bars when using a 3-point mounted disc for the same reasons.
MF Poor is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 04-06-2011, 04:43 PM   post #12 of 12
Ken N Tx
Retired MTF Admin
Ken N Tx's Avatar
MTF Member # 117
Images: 60
Garage
__________________
Ken N Tx is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
