John Deere 5425 needs dry clutch adjustment - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 03-14-2011, 04:16 PM   #1
Robert55
MTF Junior Poster
MTF Member # 56636
Default John Deere 5425 needs dry clutch adjustment
My JD 5425 4wd, 2005 model, purchased new, has a dry clutch with a cable to the clutch pedal that has been adjusted once at 50 hours(645 total hours) by a JD mechanic but even then the cable was too long. The cable needs further adjustment but cannot be made shorter, it has been shortened as far as it can go. When I step on the clutch pedal, the motor is not fully disengaged, and there is a whirring noise. What can I do short of taking the tractor to a dealer?
Robert
Robert55 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 03-17-2011, 09:47 AM   #2
Robert55
MTF Junior Poster
MTF Member # 56636
Default Re: John Deere 5425 needs dry clutch adjustment
I spoke with a John Deere service manager and I am taking the tractor in next Tuesday. He said he MAY to able to replace the cable, which would be the quickest fix. If not the tractor may have to be torn apart, and then see what happens. A throwout bearing could be involved, lets hope not.
Robert
Old 03-18-2011, 08:47 AM   #3
MF283
Proud Member of the 1K Club
MF283's Avatar
MTF Member # 33230
Here's hoping it's the cable as well, breakdowns can be costly.
Ronnie
MF283 is offline   Reply With Quote
Old 03-25-2011, 09:57 AM   #4
Robert55
MTF Junior Poster
MTF Member # 56636
Turns out the clutch is ok, still has 75% wear left. John Deere mechanic is replacing the clutch cable, but the whirring noise was from an input shaft bearing, which is also being replaced.
Sponsored Links
Advertisement
Old 04-08-2011, 01:47 PM   #5
Robert55
MTF Junior Poster
MTF Member # 56636
Turns out the carrier bearing was bad and the guide for the bearing was worn. The guide for the throw out bearing was worn. And the clutch cable had been stretched and was replaced. The cable may have been the incorrect one from day one.
R
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
