18 hp b&s twin problem - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Small Engines and Repair
Midwest Mower Pro
Reply
Thread Tools Display Modes
Old 03-09-2011, 09:36 PM   post #1 of 25
wolf-head
Owner of The Bandit #55
MTF Member # 48081
Default 18 hp b&s twin problem
Hey guys I have a MTD GT1846 with the 18 hp opposed twin briggs & stratton engine. I'll start at the beginning of the story so you get an idea. A while back when this lawn mower had the muffler on it, it was having some power troubles. Half the time it was only running on one cylinder (later found out it was the right cylinder) When I rev'd it up from just about any idle, it would only idle up on one cylinder then eventually the other one would kick in. When you engaged the mower, like any other lawn mower, it bogged down a bit but of course came back up to high idle with one cylinder firing then soon the other. So any time the engine would get bogged down some how, it would only run on that one cylinder. So a month or 2 ago, I decided to take the muffler off and put custom pipes on it so i could 1. Find which cylinder it was and 2. Because I didn't use the mower much so wanted it to sound "unique" So sure enough it was the right cylinder not firing half the time. I cleaned the spark plugs up and it was a little better. But when i was mowing last night, the spark plug wire on the left side (the side that ran OK) popped off and it was running on only the right cylinder and the pipe on the right side (i put duals on it), which was the only cylinder running, was shooting out flames like crazy. Pretty much every time it fired it shot out a flame. But it did not do this when i left the left wire plugged in and unplugged the right one. It shot no flames whatsoever. So it is the right side cylinder is the one with all the problems. Sorry for the long story but does anyone have an idea of what it might be? Any help would be appreciated. Thanks!
__________________
2000's Craftsman LT 1000
1980's MTD GT 1846
1970's Montgomery Ward racer AKA The Bandit #55
wolf-head is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 03-09-2011, 09:55 PM   post #2 of 25
larrybl
5000 Strong & Climbing
larrybl's Avatar
MTF Member # 37470
Images: 32
Garage
Default Re: 18 hp b&s twin problem
First off I'll welcome a fellow Texan. It really sounds like you have an exaust valve issue on that cyl. At low idle there is not enough compression to fire the cyl. At higher rpm the flames from the exaust are from the cyl firing and blowing by the exaust valve.
larrybl is online now   Reply With Quote Quick reply to this message
Old 03-09-2011, 10:05 PM   post #3 of 25
wolf-head
MTF Member # 48081
Thanks for the welcome. I will continue to look up on the issue and thanks for the info. What area of texas are you from?
__________________
1980's MTD GT 1846
Old 03-09-2011, 10:08 PM   post #4 of 25
SonnyT
Hoosier Born & Raised!
SonnyT's Avatar
MTF Member # 21893
Images: 26
Garage
Might be as simple as adjusting the valve clearance. Lots of threads on that procedure on here if you do a search.
Glad you joined! If you need easy Picture help
Be sure to Register for Your State!
__________________
SonnyT is online now   Reply With Quote Quick reply to this message
Old 03-09-2011, 10:10 PM   post #5 of 25
monteman_73
Senior MTF Member
monteman_73's Avatar
MTF Member # 53585
Sounds like the right hand cylinder is running lean. Start it up and let it idle, and spray WD 40 around the intake gasket at the right hand cylinder and see if the idle changes. If the idle does change, you may need to replace the intake gaskets. If that is ok, spray the intake runner from the right cylinder to the carb. Maybe the intake runner is cracked. Good luck in your venture.
monteman_73 is offline   Reply With Quote Quick reply to this message
Old 03-09-2011, 10:34 PM   post #6 of 25
Whirly
Whirly's Avatar
MTF Member # 29308
Images: 1
try this......take out both plugs....do a compression check on each cyl.....this will let u know if a valve is leakin...or maybe the rings r gettin bad...
does this engine burn any oil...(can b seen by a slightly blue tinted exhaust).. if it is usin oil....the weaker cyl rings may b bad....
then again...if it does use oil... i can also b seen on ur spark plugs too.....bad cyl will b blacker color on plug...may also have some deposits built uo on ur valvees & seats....not lettin them close tight
my guess ....10 to 1 that u got deposits built up on ur exhaust valve.....& it not closin right....remendy....remove valve.....clean to shiny look....clean seat too.....then do a LAP grind in seat...(this all requires removin the head) .... aftyergrindins....clean real good.....replace valve.....check valve LASH....& adjust if needed....replace head & restart engine when all put back togather
Whirly is online now   Reply With Quote Quick reply to this message
Old 03-09-2011, 10:39 PM   post #7 of 25
wolf-head
MTF Member # 48081
here is a video of it shooting the flames and a picture of my set up.
http://www.youtube.com/watch?v=fg4id4mq_TM
__________________
1980's MTD GT 1846
Old 03-09-2011, 10:50 PM   post #8 of 25
larrybl
larrybl's Avatar
MTF Member # 37470
Images: 32
Garage
Dang, I need to remember to turn the sound DOWN before clicking on a link of a running B/S Ran all the cats out of the shop, and I think I poped a speaker.
You know those straight pipes may be causing your problem. The engine needs some back pressure from the muffler to work properly.
Turn your sound down before viewing mine.
http://www.youtube.com/watch?v=VGe-z6GaZ34
I'm pretty sure if I turned off the lights, and with straight pipes I would see flames.
Old 03-09-2011, 10:53 PM   post #9 of 25
Walt 2002
Senior MTF Poster
MTF Member # 1229
It is fairly common for the valve seat to come loose in these engine if the cooling shroud and or cooling fins are dirty. IF the valve seat is coming out and you continue to run it, it will wallow out the block until it is not repairable.
Walt Conner
Walt 2002 is offline   Reply With Quote Quick reply to this message
Old 03-09-2011, 10:58 PM   post #10 of 25
larrybl
larrybl's Avatar
MTF Member # 37470
Images: 32
Garage
Quote:
Walt Conner
Walt knows a lot, he helped me on mine greatly. Much appricated Walt.
Old 03-09-2011, 11:00 PM   post #11 of 25
wolf-head
MTF Member # 48081
Thanks for all the comments i will start with the valves. And Larrybl it was running bad like this before i took the muffler off. Actually i think taking it off made it a little better lol. And when I check the spark plug it is always black, every time. Am I also having piston problems?
__________________
1980's MTD GT 1846
Old 03-09-2011, 11:10 PM   post #12 of 25
larrybl
larrybl's Avatar
MTF Member # 37470
Images: 32
Garage
I had (I think) rite side cyl issues with both of my opposed twins. Ended up boring both to .020 over and replaceing pistons rings and valves. Not sure if you want to go that far, or spend that much, about $350 per engine.
Here is the link to one of the builds, and a picture of what the Cyl looked like before.
http://www.mytractorforum.com/showth...hlight=hulk+ii
Name:	Cyl Score 1.jpg
Old 03-09-2011, 11:27 PM   post #13 of 25
wolf-head
MTF Member # 48081
here is a video (in the light ) of the engine running. You can hear it hesitate when i rev it up. TO NOTE: the flames in this video are NOT the ones i'm talking about, these are just back fire flames
http://www.youtube.com/watch?v=C2DdxnR0Dsw
__________________
1980's MTD GT 1846
Old 03-09-2011, 11:28 PM   post #14 of 25
larrybl
larrybl's Avatar
MTF Member # 37470
Images: 32
Garage
I went back and looked at the thread I posted about my 18HP rebuild, and relized why I did two of them. I really enjoyed rebuilding those motors. I hope yours turns into an enjoyable and learing experiance.
Good luck, and remember
Sponsored Links
Advertisement
Old 03-09-2011, 11:33 PM   post #15 of 25
larrybl
larrybl's Avatar
MTF Member # 37470
Images: 32
Garage
That actually looked and sounded pretty normal. I didn't see any smoke (a good thing). Start simple, Plugs, Clean and adjust the carb, And put a couple cheep bullet mufflers on.
Good luck, and keep us posted
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
