flywheel magnet..can it go bad?..get too weak to make the spark?? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 03-09-2011, 01:59 PM   post #1 of 5
ericwest
Senior MTF Member
MTF Member # 38975
Default flywheel magnet..can it go bad?..get too weak to make the spark??
I have a question for you guys....I have a tiller with no spark...(I talked about it in another post)...but I am curious...can the flywheel magnet go bad?...I realize it could crack ...or get physically damaged...but assuming its intact...can it over a period of years grow weak??...and no longer produce spark??...
ericwest is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 03-09-2011, 04:43 PM   post #2 of 5
Walt 2002
Senior MTF Poster
MTF Member # 1229
Default Re: flywheel magnet..can it go bad?..get too weak to make the spark??
I have seen warnings from B&S to not hit the flywheel hard with a hammer or it might result in magnets losing their strength but I have never run across it actually happening.
You should be able to check the pull against a known good magnet. I didn't read your other post but are you sure the condenser & points are good? Condenser being the most likely culprit.
Walt Conner
Walt 2002 is online now   Reply With Quote Quick reply to this message
Old 03-09-2011, 04:48 PM   post #3 of 5
Slow Crawler
Proud Member of the 1K Club
Slow Crawler's Avatar
MTF Member # 52174
Images: 1
I have never see one go bad. But I have seen the magnet fly off the fly wheel.
Floyd
__________________
66 Suburban 10
73 ST/10 For parts
73 ST/12 Frankinburban
77 Sears 16/6 twin
88 Craftsman III Sold
84,86 Murray 18/42 gt mowing tractors Sold the 86
85 Murray 18/42 The Slow Crawler
96 Craftsman 917.251560, 22.5 Hp 50" cut
03 Huskee, MTD 18.5/ 42
Slow Crawler is offline   Reply With Quote Quick reply to this message
Old 03-09-2011, 07:03 PM   post #4 of 5
DIRT Dog
Sears/Craftsman Owner
DIRT Dog's Avatar
MTF Member # 35516
Images: 20
The magnet is not a real permenant magnet.They will go bad if broken or chipped.If it holds a scredriver good then it's probably ok.Check the pick up gap and see if it's tolerances.Might be a bad pic up coil do you know if there is any resistance on the coil?
__________________
77 18/6 twin,electric 3 point hitch,disc harrow ,cultivator,10" mold board plow,draw bar,Sears box blade,& sickle bar (Haban).
97 Craftsman GT 50",Craftsman front scoop,48"dozer blade.
79 GT18(parts doner),42"deck,2 manual 3 point
hitches.
74 ST-16,42"deck
DIRT Dog is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 03-09-2011, 08:34 PM   post #5 of 5
Kbeitz
Collector of many tractors
Kbeitz's Avatar
MTF Member # 86
Images: 4
I got a kohler engine that wont spark...
If I put the coil in my coil tester it sparks but not in my engine.
Gotta be the magnet...
__________________
Kbeitz is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
