Grave Yard Dead - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 03-03-2011, 12:33 AM   post #1 of 9
TinnerN
Senior MTF Member
TinnerN's Avatar
MTF Member # 27774
Help Grave Yard Dead
I was using my MF14 and pulled up to the house when it suddenly revved up and died. Tried to restart it but no go. Anyone have any ideas so I don't go around chasing my tail? Think I'll get a head gasket, points and plug, decarbonize it, and install points and plug. What else?????
On another note, GET READY FOR SPRING!! The last 3 days I've heard geese flying over headed north and the peach and plum trees are in bloom.
Oops, I meant to put this in the MF section.
__________________
Ronnie
TinnerN is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 03-03-2011, 12:48 AM   post #2 of 9
Steevo
2000 Posts and climbing!!!
Steevo's Avatar
MTF Member # 13492
Images: 3
Default Re: Grave Yard Dead
ran out of fuel, leaned out and revved up just before running out competely?
__________________
Steevo
_________________________________________
My GT Iron:1256-01(parts); 1476(parts); 1250 (future resto proj)
1886-01-repowered w/ Kohler Command 22HP V-twin
HT-20 (rebuild in progress); Johnson 14 loader (restored!)
Steevo is offline   Reply With Quote Quick reply to this message
Old 03-03-2011, 12:56 AM   post #3 of 9
davedejonge
Senior MTF Member
davedejonge's Avatar
MTF Member # 21717
I'd agree with Steevo... fuel issue...
had something similar happen on a Sears Suburban once... found it was rotted fuel line dropping rubber bits into the carb bowl and plugging things up.. it would start a few minutes later and run for 3 or 4 minutes then die again...
clean out the carb and replace your fuel lines... add a fuel filter if you don't already have one...
__________________
Ford LGT 145 - Franken mower.
Frame, fenders and seat from a 72 - Hood, grill and sides from a late 70's closed side - repowered k321 from around 1988 w/ 42 inch deck & 2 stage snow blower
davedejonge is offline   Reply With Quote Quick reply to this message
Old 03-03-2011, 03:30 AM   post #4 of 9
K108Cub
GrandPa
K108Cub's Avatar
MTF Member # 39881
Images: 10
Mine died suddenly yesterday. Thought was out of fuel, added some. Crank, crank, crank, crank. After a while opened hood to look, finally saw the plug wire had fallen out of the coil. Spread prongs,put back on. Took a while to start, as I had flooded it pretty good.
KennyP
__________________
KennyP
Proud Member of the 800 Posts Club
U.S. Army, RVN, 1968-1969
5th Battalion, 16th Artillery, Battery C
1971 Cub Cadet 108
1977 Ford LGT 165
1981 Craftsman GTV/16
198? Craftsman II
K108Cub is offline   Reply With Quote Quick reply to this message
Old 03-12-2011, 11:43 PM   post #5 of 9
dirtsaver
Senior MTF Member
dirtsaver's Avatar
MTF Member # 2980
Yep, first thing to check is fuel. Next,did it rev WAAAAAAY up or just increase rpm's a bit and die? If it Revved WAAAAY up before it died the governor may have broken. Then its time for an engine manual and teardown tools.
__________________
KG4ZAR
Radio active
dirtsaver is offline   Reply With Quote Quick reply to this message
Old 03-13-2011, 03:00 AM   post #6 of 9
TinnerN
Senior MTF Member
TinnerN's Avatar
MTF Member # 27774
Yep, it revved way up, beyond the little rev like when you run out of fuel. I've been busy putting in the garden and plowing the fall garden along with honeydo projects but hope to get into it soon. I did check for spark and try shooting a little starting fluid in the carb to no avail.
__________________
Ronnie
Old 03-13-2011, 05:21 PM   post #7 of 9
AMCJavelin74
Old Iron 1%er
MTF Member # 43316
Quote:
Well, at least it didn't throw a rod!
It's a good time to remove the balance shaft (known to fail on occasion and sometimes the weights swiss cheese the block), and have the crankshaft balanced if it's torn down that far. Look into some pulling sites/threads/internet search it to find out the exact details for your engine.
AMCJavelin74 is offline   Reply With Quote Quick reply to this message
Old 03-13-2011, 05:46 PM   post #8 of 9
K108Cub
GrandPa
K108Cub's Avatar
MTF Member # 39881
Images: 10
If you remove the balance shaft and gears, do you have to get the crank balanced?
__________________
KennyP
1971 Cub Cadet 108
1977 Ford LGT 165
198? Craftsman II
Sponsored Links
Advertisement
Old 03-15-2011, 07:42 PM   post #9 of 9
AMCJavelin74
Old Iron 1%er
MTF Member # 43316
Quote:
I think so, especially if you're rebuilding it anyway. If you just want to remove the balancers without disassembly (possible with the 12hp Kohlers) then I think it's okay to leave the engine otherwise alone, providing it's not used for tractor pulling.
See the link below for more information... scroll down a little bit, to the part about the 'dynamic balance system' and start there.
balancing the rotating assembly
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
