electronic ignition conversion (Omega electronic ignition) - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Small Engines and Repair
Midwest Mower Pro
Reply
Thread Tools Display Modes
Old 02-25-2011, 05:57 PM   post #1 of 7
ldlittsen
Senior MTF Member
MTF Member # 31741
Default electronic ignition conversion (Omega electronic ignition)
A friend told me about the Omega electronic ignition conversion kits for small engines and I was wondering if anyone here was familier with them? I'm working on a very old Briggs engine with Magnematic ignition. (The mag is mounted under the flywheel and the magnet is on a disc on the crankshaft rather than on the flywheel)) And rather than try and locate a used coil I would prefer to convert it to electronic ign. If anyone has done a conversion of this type I would sure appreciate any information. So far I havent been able to find out much about the Omega set-up. Thanks, Litz
ldlittsen is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 02-25-2011, 06:35 PM   post #2 of 7
Brad
MTF--A Step Above!
Brad's Avatar
MTF Member # 4571
Images: 28
Default Re: electronic ignition conversion (Omega electronic ignition)
There were some good articles on this down in the Walkbehind section. You may want to check there for some good posts. In the meantime I will try to look up the thread.
Here you go. This is a top-notch article. There just might have been another good article in this section, too, but don't know for sure.
http://www.mytractorforum.com/showth...ion+conversion
Enjoy!
__________________
MTF--Getting better, one new member after another!
It's a great place to spend some time every day!
Brad
Brad is online now   Reply With Quote Quick reply to this message
Old 02-25-2011, 06:48 PM   post #3 of 7
ldlittsen
Senior MTF Member
MTF Member # 31741
Brad, Thank you for the info!! Litz
Old 02-26-2011, 01:32 PM   post #4 of 7
littlechicago
Senior MTF Member
littlechicago's Avatar
MTF Member # 51405
I convert all older points engines over to electronic. All I have ever had to do is get a newer electronic coil, mount it, and works like a charm.
Just make sure you have the right coil, like 2HP-4HP briggs are the same, 5-6HP, them 7HP-18HP I think are the same. You'll know because the bolt holes will be different.
Dont try to drill thru coils, its a headache. Old electronic coils that work are easy to find for less than $10.
littlechicago is offline   Reply With Quote Quick reply to this message
Old 02-26-2011, 03:09 PM   post #5 of 7
GB in MN
2000 Posts and climbing!!!
GB in MN's Avatar
MTF Member # 38891
Images: 5
Quote:
Hi Litz, I've had limited success with the Omega system, they seem to work on some of the Briggs engine have had no success on Tecumseh engines, but if your problem is the coil the Omega will not work the Omega is a points / condenser eliminator only nothing to do with the coil you must have a good working coil to make it work. Good luck with your project.
GB in MN
GB in MN is online now   Reply With Quote Quick reply to this message
Old 02-26-2011, 08:24 PM   post #6 of 7
ldlittsen
Senior MTF Member
MTF Member # 31741
Thanks for the info GB. I couldn't find out much about the system anywhere. Your info. helps, Litz
Sponsored Links
Advertisement
Old 02-26-2011, 08:40 PM   post #7 of 7
Mickeymotormount
Proud Member of the 1K Club
Mickeymotormount's Avatar
MTF Member # 20928
Images: 12
Litz, check the other post you started about the Briggs without spark. I posted a link to a cheap fix you may find interesting.
__________________
John
Ford and Gravely Nut
Mickeymotormount is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
