Snow plow wear bar - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 02-19-2011, 02:42 PM   post #1 of 7
bgosh
Senior MTF Member
MTF Member # 15986
Help Snow plow wear bar
What are you using to replace wear bar on your snow plow? Thank You Stan
bgosh is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 02-19-2011, 07:46 PM   post #2 of 7
AC716H
Senior MTF Member
MTF Member # 37862
Default Re: Snow plow wear bar
Most allow you to turn it over to put the unworn edge back down on the pavement.
AC716H is offline   Reply With Quote Quick reply to this message
Old 02-19-2011, 09:49 PM   post #3 of 7
bgosh
Senior MTF Member
MTF Member # 15986
Actually I never even thought about that. Thank You Stan
Old 02-20-2011, 01:04 AM   post #4 of 7
Justy37
Proud Member of the 1K Club
Justy37's Avatar
MTF Member # 55322
There is a local metal dealer here, he sells stuff like iron bars, plates, square tubing. Does little iron projects for people, welding and such. I just get a flat piece from him thats about 1/4 inch thick and take it home and place it on top of my old blade and mark holes, drill them out. Then I take my little 4 inch hand grinder and put a edge on it. I don't make it perfect because I know the cement will do most of that as I'm moving snow.
Justy37 is offline   Reply With Quote Quick reply to this message
Old 02-21-2011, 12:41 AM   post #5 of 7
RailmanJD318
MTF Member
MTF Member # 53645
I just cut a 4" x 48" for my 46" plow about a month ago. I just let it run 1" past each side. No need to wory about the finish edge, Plowing will clean/angle it up very fast. I just drilled the holes about .040"+- under the diagonal meas. of the stove bolts' square. It doesn't have to be a square hole. It'll pull right through. I drilled at the center of the 4", so I can flip when the 1st side wears down.
Joe
RailmanJD318 is offline   Reply With Quote Quick reply to this message
Old 02-21-2011, 10:44 PM   post #6 of 7
ACmowerguy
ACmowerguy's Avatar
MTF Member # 22929
Images: 2
I just bought new ones at the dealer for $40 each. Got one for each of my two 42" blades. The originals couldn't be flipped but the news ones can. I didn't have the time to make my own. I believe the factory ones are a hardened steel and last longer than regular mild steel bar.
__________________
SIMPLICITY- 700, 3410, 17GTH-L, 727, 75th anny Sovereign, '98 Landlord, '99 Landlord DLX
Allis-(2) B-10's, B12, (2) B110's, B-207, (2) B210's, B212, HB212, Homesteader 8, 416H, 710, 912H, 914S
Massey-MF12 and MF16
Sears- 1971 HT14 hydro
ACmowerguy is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 02-22-2011, 09:21 AM   post #7 of 7
Burntime
Burntime's Avatar
MTF Member # 22443
Acmowerguy, I think you are right. But for 6 bucks instead of 42 I made my own in 5 minutes. I only use mine in dirt and rarely on the driveway so it lasts and lasts. No idea how it would do on concrete. My buddy is a county worker and he has offered some of the stuff they take off when it wears too far. Its just so friggin heavy that I have not taken him up on it. Its something like 1/2 or 3/4 of an inch thick! I don't want to lug that much around the garage until I need it!
Burntime is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
