Quick Question - Reverse threads on mower deck blade bolts? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 02-19-2011, 02:20 PM   post #1 of 13
taltimus
Senior MTF Member
taltimus's Avatar
MTF Member # 54177
Default Quick Question - Reverse threads on mower deck blade bolts?
Are the bolts holding on the blades on my 54" deck (for a 445) reverse thread or normal? I've having one helluva time getting any of them off...
__________________
~Tim
-- 2000 John Deere 445 2WS
-- 54" deck
-- 54" blade
-- 40 Loader
-- Ruegg 0/1 Combo 3pt
-- Cat 1 Super Heavy Hitch
taltimus is online now   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 02-19-2011, 02:33 PM   post #2 of 13
davidg
The Travelin' Mod
davidg's Avatar
MTF Member # 807
Images: 2
Default Re: Quick Question - Reverse threads on mower deck blade bolts?
never dealt with a 445, but my L130 and my X500 are both regular thread. try tapping with a hammer as you attempt to turn them, they do tend to stick tight.
__________________
Check out our new HOMEPAGE
davidg is online now   Reply With Quote Quick reply to this message
Old 02-19-2011, 02:41 PM   post #3 of 13
8086bruce
4K Poster!!!!
8086bruce's Avatar
MTF Member # 49980
Garage
They do stick the last time I took mine off my old jd one was stuck so back I broke my ratchet.
__________________
2012 John Deere X720SE
54"MMM
54" Quick hitch blade
47" Quick hitch blower with side plates
8086bruce is offline   Reply With Quote Quick reply to this message
Old 02-19-2011, 05:28 PM   post #4 of 13
taltimus
Senior MTF Member
taltimus's Avatar
MTF Member # 54177
Yeah, I almost broke my 3/8 drive ratchet as well, it slipped out of the gearing, I thought it had broke... soooo, I went to Sears and bought myself a 1/2 drive flex/breaker bar and a set of 1/2 drive sockets. I still had to put a piece of 1" pipe over the handle to get the bolts loose.. yowsers!
Anyway, thanks for the info. I did get them all off, and without breaking anything :-)
__________________
~Tim
-- 54" deck
-- 54" blade
-- 40 Loader
Old 02-19-2011, 05:33 PM   post #5 of 13
SARG
Brockway
SARG's Avatar
MTF Member # 31549
I always use a box end wrench and a brass mallet.
SARG is offline   Reply With Quote Quick reply to this message
Old 02-19-2011, 05:46 PM   post #6 of 13
TennesseeJim
Me
TennesseeJim's Avatar
MTF Member # 55103
Try some PB Blaster from the auto parts store or hardware store. If you are still having trouble. Tap it lightly with a small hammer after soaking let it work it's way in.
That stuff really penetrates well................
TennesseeJim is offline   Reply With Quote Quick reply to this message
Old 02-19-2011, 05:51 PM   post #7 of 13
SonnyT
Hoosier Born & Raised!
SonnyT's Avatar
MTF Member # 21893
Images: 26
Garage
They should all be standard thread or they would have a tendency to loosen when running.
__________________
SonnyT is online now   Reply With Quote Quick reply to this message
Old 02-19-2011, 07:29 PM   post #8 of 13
bvp2000
Senior MTF Member
bvp2000's Avatar
MTF Member # 28946
Make sure you put in new bolts and coat them with anti sieze...I never reuse those bolts...
__________________
bvp2000
JD 455/40 Loader
JD 425 and JD 7 Cart
JD's not hidden from the wife well enough!
JD 425, JD 425AWS, JD 322, JD 318, JD 317, JD 425
JD G100, JD 318, JD 445, JD 445, JD 265, JD 455, JD 332, JD 455, JD 430, JD 318, JD 777, JD 425, JD X495, JD345 and JD 755.
bvp2000 is offline   Reply With Quote Quick reply to this message
Old 02-19-2011, 08:12 PM   post #9 of 13
LakeRat1
MTF Junior Poster
MTF Member # 55703
I have a JD 445 the Treads are Right Hand, These are good size Bolts, if i remember right it takes a 15/16 socket, to make them come out with out so much trouble, put a little Never Seze on the threads before you reinstal the blades, what you need to do is get a short chain, like 1/4 in. about 3 or 4 ft. long, with a hook on one end, place the hook over the end of the blade and rap the chain around something to hold the blade, i put a 3/8 in. bolt through the chain end to keep the chain from slipping, now that you have the Blade where it wont turn, take a good 6 point socket on either a 1/2 impac or a 1/2 in braker bar with a short piece of pipe for a cheater bar, i have a piece of 1 in. pipe about 18in. long that i use, when you put the blades back on check in the owners manual they may have how much torque they need, if not just use the braker bar, but not the cheate bar, i bet the bolts were put in dry last time there were out, OR some one put them back on with a impac wrench and went WAY to TIGHT, I just went out to the shop and checked the Book, it calls for 83 FT. Lb of torque, i dont ever do that because i have worked of stuff enough to know, if you are not familar with things like this, best thing i can tell you to do is tighten them up about as tight as you would tighten the lug nut on a car tire, another Thing the heads of the bolts will ware, dont let them go to the point that your socket wont catch, i change my bolts about ever 3 years,
LakeRat1 is offline   Reply With Quote Quick reply to this message
Old 02-19-2011, 10:00 PM   post #10 of 13
PA318Guy
Winter returned!
PA318Guy's Avatar
MTF Member # 31960
Garage
on the never sieze compound. Save a lot of headaches taking them off!
__________________
Current Machine JD 322
Former Machines: JD 318, JD 216, JD 212, 1965 JD 110
My videos: www.youtube.com/user/tkelley16341
PA318Guy is online now   Reply With Quote Quick reply to this message
Old 02-19-2011, 10:02 PM   post #11 of 13
Engine_Tech
Proud Member of the 1K Club
MTF Member # 46741
Impact gun...
Engine_Tech is offline   Reply With Quote Quick reply to this message
Old 02-19-2011, 10:56 PM   post #12 of 13
JD X728
Senior MTF Member
JD X728's Avatar
MTF Member # 53888
Images: 1
Welcome to the forum!
I like the sound of your post. Keep up the good work!
JD
JD X728 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 02-19-2011, 10:59 PM   post #13 of 13
Reverend Blair
Senior MTF Member
MTF Member # 28811
Quote:
Originally Posted by Engine_Tech View Post
Impact gun...
My choice every time.
Reverend Blair is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
