Bond plastic to metal - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Off Topic But not "Off Color" and no politics please
Reply
Thread Tools Display Modes
Old 02-11-2011, 12:03 PM   post #1 of 12
rfowler
Senior MTF Member
rfowler's Avatar
MTF Member # 46333
Images: 1
Garage
Default Bond plastic to metal
Has anyone found a product that really bonds plastic to metal? Thanks in advance.
__________________
2010 X728
Mulch kit
Rear Quick hitch
Rear weight bracket
6 Suitcase Weights
10P Cart
54" Blade w/ hydraulic angle
rfowler is offline   Reply With Quote Quick reply to this message
Old 02-11-2011, 06:08 PM   post #2 of 12
BillB
Pie R Round
BillB's Avatar
MTF Member # 36410
Default Re: Bond plastic to metal
JB Weld?
__________________
2012 JD 2320 w/FEL, 54D MMM, 54" Snowblower
2000 Craftsman GT 24HP, 50" Deck, 46" Snowblower
2001 Craftsman GT3000, 48" Deck w/mulch kit, 46" Snowblower, 42" Sweeper, 16 Cu Ft Dump Cart
1973 Cub Cadet 108, 42" Deck, Snow/Dirt blade and Dump Cart
BillB is offline   Reply With Quote Quick reply to this message
Old 02-11-2011, 06:50 PM   post #3 of 12
HydroHarold
10,000 +posts!
MTF Member # 82
Images: 1
Try this and let us all know!
http://miracleglue.com/
About 8 years ago or so I read an article in Model Railroader or RR Model Craftsman about a new glue that molecularly bonded anything to anything by penetrating the surface itself of both pieces. It was supposed to be for any material and it also was very expensive as there was a pre-treatment that had to be done to the areas to be bonded. Space age stuff... But, I don't believe I've ever seen it for sale since.
HydroHarold is offline   Reply With Quote Quick reply to this message
Old 02-11-2011, 06:53 PM   post #4 of 12
catdoo
Senior MTF Member
catdoo's Avatar
MTF Member # 27772
Images: 5
Try Crazy Glue
__________________
1975 FORD LGT 145 ,
Dump Cart, 42" Single Stage Snow Auger, 42" Mower Deck
2005 CRAFTSMAN DYT4000,
22 hp. B&S, 42" mower deck, 42" snow blade,
2006 FORD Mustang Pony Package Legend Lime (my green machine)
catdoo is offline   Reply With Quote Quick reply to this message
Old 02-11-2011, 07:44 PM   post #5 of 12
Kbeitz
Collector of many tractors
Kbeitz's Avatar
MTF Member # 86
Images: 4
I second the JB-weld...
But all plastics are different...
Some plastice are oiley and nothing sticks to them.
__________________
Kbeitz is online now   Reply With Quote Quick reply to this message
Old 02-11-2011, 09:21 PM   post #6 of 12
dmorrill22
Sears Fan
dmorrill22's Avatar
MTF Member # 38986
Images: 26
Garage
Super glue usually works well:
__________________
Doug
1966 Colt 2712 (Restoration in progress)
1969 Sears SS12 (Soon to be a dedicated grader!)
- Homemade snow plow (in progress)
- GM 3-wire alternator
- Duromax 16hp Repower
- Custom headlights
1972 Sears SS15 (Work in progress)
dmorrill22 is offline   Reply With Quote Quick reply to this message
Old 02-12-2011, 01:15 AM   post #7 of 12
HydroHarold
10,000 +posts!
MTF Member # 82
Images: 1
THIS is the stuff I had read about:
http://www.tech-bond.net/Debonders_A...tors_Gels.html
I guess it's in wide distribution now. I'm going to try and find some and see how it works on (ulp!) John Deere's miracle hood material "Zenoy". The website has plenty of info on bonding different materials on the left side menu.
Old 02-12-2011, 01:19 AM   post #8 of 12
rfowler
Senior MTF Member
rfowler's Avatar
MTF Member # 46333
Images: 1
Garage
I wanted it now so I used a 2 part epoxy that is specially made for plastic. I'll let you know how it works. Thanks much for the info! Sounds like you may have bigger problems though. Cracked hood?
__________________
2010 X728
Mulch kit
Rear Quick hitch
Rear weight bracket
6 Suitcase Weights
10P Cart
Old 02-12-2011, 02:51 AM   post #9 of 12
Beaumont
Senior MTF Member
Beaumont's Avatar
MTF Member # 36852
Best glue for metal to plastic?
SEE this BLOG (3 pages of comments, to review): http://www.advrider.com/forums/showthread.php?t=120409
I've been using Gorilla Glue, on a few house projects & it is darn good stuff. http://www.gorillaglue.com/glues.aspx
Clean both dissimilar surfaces - works on many:
- slightly damp one side / just a little moisture helps, bond strength
- apply a thin film of glue on the other side (clamp surfaces or tape together) http://www.gorillaglue.com/glues/gorillaglue/index.aspx
The gorilla product fully cures in 24 hours, is waterproof - but the glue does expand upon drying and leaves a hard & dry milky colored residue / to scrape off later.
Shelf life is good so far, but should be stored cool....Keep away from Oxygen & Heat, to keep bottle fresh.
When I use it, I take a few drops out of the container, and quickly put the lid on.....Then I store it in the fridge, until next time.
It seems to have a Crazy-Super Glue (in gel or liquid) strength - as long as it's given the recommended full day to cure / plus a better shelf life.
(when I check my old tubes of 15 second drying GEL, contents are all hardened up / so I reach for the GORILLA stuff now...right from the kitchen fridge storage)
FYI
For duck tape - nothing I've found beats this, hands down: gorilla tape http://www.gorillaglue.com/tapes.aspx
Both the glue & tape products - from GORILLA, I'm honestly impressed with.
Beaumont { :>)) www.petperfectexpress.com
Golden Rule - "he who has the gold, makes the rule"
http://www.mytractorforum.com/showthread.php?t=135838 Intro.
1992 JD 318 original paint w/484 hr. on P218g Onan & #49 snow blower / 1998 JD GT262 w/brand new Kawasaki OHV & 48" rebuilt deck
1965 Malibu S/S, 1985 Monte Carlo S/S original paint, 1987 Pontiac GTA original paint L98-TPI, 1966 Beaumont Custom original paint,
1967 Beaumont Custom, 1967 Beaumont Custom original paint, 1967 Beaumont 396-350HP Sport Deluxe M21-411's
- SOLD 1970 GTO Judge RAIII, original paint
Beaumont is offline   Reply With Quote Quick reply to this message
Old 02-12-2011, 07:44 PM   post #10 of 12
HydroHarold
10,000 +posts!
MTF Member # 82
Images: 1
Quote:
quote Rfowler: Sounds like you may have bigger problems though. Cracked hood?
Good Gawd y'all, not yet! I just want to be the guy that finds the answer to all the JD cracked hood questions we see on MTF. The guy that does will get a virtual parade, free Lean Cuisine dinners for a year and a "sticky" named in his honor.
Old 02-12-2011, 09:47 PM   post #11 of 12
rscurtis
5000 Strong & Climbing
MTF Member # 25367
There was a vendor at Cabin Fever selling a product like that, and he demo'd it for me. It seemed to work as claimed. The solvent for it is nitromethane.
When I worked for Malvese, they shot the ad for Eastman 910 adhesive for those of you who remember it, the one with the Ford tractor suspended from a crane. It was held up with a 2" diameter piece of bar stock that had been cut in half and glued back together.
rscurtis is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 02-13-2011, 12:14 AM   post #12 of 12
Beaumont
Senior MTF Member
Beaumont's Avatar
MTF Member # 36852
JUST SOME CRAZY / KRAZY trivia:
http://www.inventor-strategies.com/crazy-invention.html
Krazy Glue
This crazy invention bonded with anything it contacted. Harry Coover invented a glue while working for Eastman Kodak.
He was experimenting with various adhesives to make plastic lenses for rifle sights.
He created a substance that was impossible to work with because it stuck to everything.
It wasn't any good for making lenses but "cyanoacrylate" was an amazing glue. You could glue something instantly.
The bond was also very strong and permanent.
Other Uses
It was originally known as "Flash Glue" and then as "Eastman 910" adhesive. It was patented in 1958.
A cyanoacrylate spray was also developed and used during the Vietnam war to stop bleeding. A medical version of this spray is used in health care.
It was discovered that cyanocrylate could be used in forensics.
Fumes from the adhesive reacts with fingerprints and forms a white residue that reveals fingerprints on smooth surfaces.
These additional uses is a good example of how specific uses for an invention can be discovered after it has been patented.
Today, this popular and crazy invention is sold under the trade names "Krazy Glue" and "Super Glue".
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
