craftsman LT1000 briggs & Stratton 18hp - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 02-10-2011, 10:03 PM   post #1 of 14
dano828
MTF Junior Poster
MTF Member # 55430
Default craftsman LT1000 briggs & Stratton 18hp
Hello all,
Im looking forward to your expertise.
Im trying to get some help with my craftsman LT !000 Im having starting problems, read a lot from some other forums, however, this one seems the most detailed and user friendly
Thanks
Dano828
dano828 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 02-10-2011, 10:06 PM   post #2 of 14
SonnyT
Hoosier Born & Raised!
SonnyT's Avatar
MTF Member # 21893
Images: 26
Garage
Default Re: craftsman LT1000 briggs & Stratton 18hp
If you need easy Picture help
Be sure to Register for Your State!
__________________
SonnyT is online now   Reply With Quote Quick reply to this message
Old 02-10-2011, 10:31 PM   post #3 of 14
truckguy
Senior MTF Member
truckguy's Avatar
MTF Member # 36112
What kind of starting problems are you having?
__________________
1940 Farmall H, 1947 farmall cub, 1958 David Bradley SP, 1964 cub cadet 70, 1965 Bolens 1000, 1966 cub cadet 123, 1973 Mf 12, 1993 Ranch King GT 18/46, 1970 Ford F-350, 1969 F-250 1968 F-350, 1968 F-250
truckguy is offline   Reply With Quote Quick reply to this message
Old 02-10-2011, 10:32 PM   post #4 of 14
The craftsman kid
Senior MTF Member
The craftsman kid's Avatar
MTF Member # 53467
welcome dano828 fell free to shoot any of us a post or message if you need help or have a question to ask about your tractor
__________________
MY Tractors
1981 John Deere 314-main mower
Craftsman 12.5/38
broken/sold/scrapped tractors
86 mastercut 12/36
1981 John Deere 212 restored
craftsman lt4000 v-twin
Craftsman 12/38 Tecumseh
Companion 12/38
gravely 1238g-woods/beater
gravely 1138g
Lawn chief 11/36
bolens 1050 w/plow blade
Murray 14/42
kgro powerpro lt1642
wheelhorse 210-5
craftsman lt4000 kohler
1988 craftsman gt6000
Craftsman II 12.5/42
The craftsman kid is offline   Reply With Quote Quick reply to this message
Old 02-10-2011, 11:36 PM   post #5 of 14
Fcubman
3K Poster!!!!
Fcubman's Avatar
MTF Member # 18953
Images: 5
Welcome, and if you give us more details, like model # and symptoms, we can be of some help.
__________________
Remember, I'm pullin' for ya! We're all in this together!
(Red Green)
Living in The Land Of The Free - because of The Brave!
Fcubman is offline   Reply With Quote Quick reply to this message
Old 02-10-2011, 11:48 PM   post #6 of 14
larrybl
5000 Strong & Climbing
larrybl's Avatar
MTF Member # 37470
Images: 32
Garage
Quote:
Originally Posted by dano828 View Post
Hello all,
Thanks
Dano828
Shot in the dark..... Easiest to hardest
Wire Connections, including grounds
Battery Condition
Safety Switches (Working)
Sylonid (Clicking)
Ignition Switch (Connector crosion)
Coil - Spark plugs (Getting Spark)
Fuel - Filter (Clean)
Carb - Float - jets (Clean)
larrybl is online now   Reply With Quote Quick reply to this message
Old 02-11-2011, 02:09 AM   post #7 of 14
dano828
MTF Junior Poster
MTF Member # 55430
Hello All,
And thank you for the warm welcome.
Here is my problem Craftsman LT 1000 18hp Briggs & Stratton. Problem started last summer, where after a mowing, the tractor would not restart. Would jump it but after running for a while seemed to drain battery. Replaced battery twice to no resolve. Recently replaced starter, terminals all look clean and non corroded. It seems to want to start, 1 or 2 1/2 revolutions per try until battery again drains. New battery again as of today, not starting. Garage is very cold, don't know if that can effect fuel filter etc.... disconnected seat safety switch, did not make a difference. I don't believe that the motor is seized being that it has started with a jump and try's to turn over with a recharged battery before draining battery.
Please help
Dano
Old 02-11-2011, 02:51 AM   post #8 of 14
monteman_73
Senior MTF Member
monteman_73's Avatar
MTF Member # 53585
You mentioned 1-2 1/2 revolutions per try untill the battery again drains. Are you saying that you only crank it 1-2 1/2 revolutions, or that is all the battery has power for? If it is you doing this, most likely it won't start. I have a Craftsman 17hp Briggs, in the summer time it usually starts on the second revolution. But this winter it usually starts on the fourth revolution. The only time I ever have a problem with the battery in the winter is that I don't let it run long enough. I'll start it to move it out of the way and shut it off. Then restart it to put it back in the garage and shut it off right away. It would probably be better if I had 5-30 or 10-30 oil. (It still has 30 weight.) If I use it to blow snow, it always starts the next time I want to use it. Is this an Over Head Valve engine? If so, maybe the rocker arms are too loose. (Rocker arms being to loose won't let the compression release open the valve enough or at all to overcome the compression.) Maybe the charging system is not working good enough or not at all. Please let us know about the cranking. (Are you only cranking it for 1-2 1/2 revolutions, or is this all the battery has power for?) We will need to know this information to accurately help you out. Welcome to MTF, and hope you enjoy your stay.
monteman_73 is offline   Reply With Quote Quick reply to this message
Old 02-11-2011, 03:43 AM   post #9 of 14
dano828
MTF Junior Poster
MTF Member # 55430
I will attempt to start it for approx. 10-15 minutes, the answer is I continuously try until the battery wont allow for it to do anything. If I turn the key all the to start it will only turn 1-2 revolutions then I have to try again. If I keep turning the key rapidly between rotations it will come closer to starting
thanks
Old 02-11-2011, 03:16 PM   post #10 of 14
Slow Crawler
Proud Member of the 1K Club
Slow Crawler's Avatar
MTF Member # 52174
Images: 1
Welcome to the forum, I'm sure you will find lots of help here.
__________________
66 Suburban 10
73 ST/10 For parts
73 ST/12 Frankinburban
77 Sears 16/6 twin
88 Craftsman III Sold
84,86 Murray 18/42 gt mowing tractors Sold the 86
85 Murray 18/42 The Slow Crawler
96 Craftsman 917.251560, 22.5 Hp 50" cut
03 Huskee, MTD 18.5/ 42
Slow Crawler is offline   Reply With Quote Quick reply to this message
Old 02-11-2011, 05:25 PM   post #11 of 14
Bill Kapaun
Circumflatulater
Bill Kapaun's Avatar
MTF Member # 6264
What's the Sears 917.xxxxxx # that's under the seat.
When's the last time the valves have been adjusted on the engine?
Briggs OHV engines require the valve lash to be set quite precise in order for the compression release to function.
Does it crank over OK with a freshly CHARGED battery?
__________________
Illegally Blind
Bill Kapaun is online now   Reply With Quote Quick reply to this message
Old 02-11-2011, 05:56 PM   post #12 of 14
rscurtis
MTF Member # 25367
You may also want to verify that your chargins system is working, as you seem to be plagued by dead batteries.
rscurtis is offline   Reply With Quote Quick reply to this message
Old 02-11-2011, 06:59 PM   post #13 of 14
Walt 2002
Senior MTF Poster
MTF Member # 1229
Welcome,
Well Bill does look ups by mower model number, I don't and to know what you problem might be, I need the model number of the ENGINE since there are 3 - 4 different B&S 18 hp engines, some vastly different.
IF I had the engine model number, I just might have "canned" detailed instructions to help, address below, put in proper format.
Walt Conner
wconner5 at frontier dot com
Walt 2002 is online now   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 02-11-2011, 09:32 PM   post #14 of 14
1050Bolens
Senior MTF Member
1050Bolens's Avatar
MTF Member # 34601
LT1000 with 18hp engine came with either a 18hp OHV Intek Briggs or a 18hp Opposed twin I/C II.
I'm betting it has the 18hp OHV Intek.Common problems on those were the carbs and Head Gaskets.
The Carb has a rubber seat under the float needle valve that either cracked or got hard.This causes gasoline to fill the crankcases full of gasoline.
Head gaskets blow on the 16-19.5hp OHV engines between the push rod cavity and the cylinder wall.And oil enters the combustion chamber,this raises compression atleast 2x.It's very common.
The correct starter for one of these engines (16-19.5hp) by the manual is one off of an opposed twin with the single cylinder top bearing plate.
The correct starter will run you $90-$120.The cheaper starters will bolt up but they will not have enough torch to start the engine.
It's not your battery that's dieing.It's the cheap starter trying to crank over an engine with higher than normal compression.
I have one of the rarer 19.5hp ohv singles here now that is in need of a new head gasket.It smokes for about 10 seconds after it's started.
It had the starter replaced 3 times so far before I got him the correct starter for it.
1050Bolens is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
