Looking for some parts 68' 2110 or 2112 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 02-07-2011, 05:17 PM   post #1 of 12
LoggerLee
MTF Member
MTF Member # 55294
Default Looking for some parts 68' 2110 or 2112
Hey there,not sure this is the place to post this or not,I'm still new here.
I'm looking for some parts for my new to me 2110 (at least I think its a 2110,that's what the tag says,though the guy I bought it from thought it was a 2112,don't know what the difference is)
I'm needing the panels for the sides,next to the battery and steering gear,and left side piece that go on the side of the grill,it's painted white and goes over the support.
I'd like to find a lower low gear for it somehow too,for tilling.
Also need the little cap thing that you adjust the drag link end with,mine is missing,it's slotted for a cotter key.
And any other information a person thinks I need would be handy,this is a neat machine and I'm going to be keeping it for quite some time.
Thanks,
Lee
LoggerLee is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 02-07-2011, 06:28 PM   post #2 of 12
Burntime
Proud Member of the 1K Club
Burntime's Avatar
MTF Member # 22443
Default Re: Looking for some parts 68' 2110 or 2112
2110 is a 10hp. He may have repowered it with a 12hp so now its a 2112?
Burntime is offline   Reply With Quote Quick reply to this message
Old 02-07-2011, 06:32 PM   post #3 of 12
LoggerLee
MTF Member
MTF Member # 55294
Hmm,how would I know the difference between the 10 and 12 hp engine?
Old 02-07-2011, 07:12 PM   post #4 of 12
Burntime
Burntime's Avatar
MTF Member # 22443
The numbers on the shroud of the motor. 24 is a 10hp I believe. It will be a number larger then 24 if it is 12 or up... 32 is a 14-16hp. I do remember that.
Old 02-07-2011, 09:15 PM   post #5 of 12
ACmowerguy
ACmowerguy's Avatar
MTF Member # 22929
Images: 2
Best place to get those parts would be eBay.
__________________
SIMPLICITY- 700, 3410 3psd, 3410S, 3410H, 17GTH-L, 727, 7116H 75th anny Sovereign, '98 Landlord, '99 Landlord DLX
Allis-(2) B-10's, B12, (2) B110's, B-207, (2) B210's, B212, HB212, Homesteader 8, 416H, 710, 912H, 914S
Massey-MF12 and MF16
Sears- 1971 HT14 hydro
JD - 110, 345 w/48C, 345 w/54"
ACmowerguy is offline   Reply With Quote Quick reply to this message
Old 02-07-2011, 09:21 PM   post #6 of 12
LoggerLee
MTF Member
MTF Member # 55294
Do you guys know if the variable drive from a 1969 Landlord will go into mine?
There's a fella that has one for sale,but he does not know if it will work,I'm thinking it will,but I'd rather not spend the money on something I can't use.
The Variable drive will enable the machine to go slower right?
I know your right ACmowerguy,but it's sort of like this,I have about 5 70-something ford pickups that I'm never going to do anything with,except maybe take them to the scrap man,so if anyone wanted some of the stuff I'd sell it cheap,or give it away,I was hoping there was someone here who was the same way with parts for old tractors,I don't mind to pay what's fair,and I'll check ebay,I'd just rather pay one of us that didn't dig it out of grandpa's shop and part it out.
(not being at all onery here,just explaining myself)
Old 02-07-2011, 09:41 PM   post #7 of 12
Burntime
Burntime's Avatar
MTF Member # 22443
Your better off changing out the rear pulley when you use the tiller. Variable drives are problematic at best. The more wear on the pivots the worse they get.
Old 02-07-2011, 09:44 PM   post #8 of 12
LoggerLee
MTF Member
MTF Member # 55294
I'll plan on changing to a bigger pulley then,any idea how big a pulley I can get away with?
Do not buy the variable cause' it won't work then?
Old 02-08-2011, 01:57 AM   post #9 of 12
RailmanJD318
MTF Member
MTF Member # 53645
Lee,
The std rear drive pulley (behind clutch) is 6.75" (21.20" circ.). If you were to go to a
9" (28.26" circ), you'd get a .75 reduction. Std low gear is rated at 1.6 mph. If you went to a 9" that would result in .75 x 1.6 = 1.2 mph, or about .4 mph reduction. That's about a 25% reduction in mph. That's assuming you can get a 9" pulley on the rear. From looking at my B110, it looks like it might work. You'd have to look closer to see if you can go bigger, or for that matter, if a 9" would clear.
I use to do quit a bit of tilling with my B110 in low gear, but it was a little tricky, & had to use the clutch quit a bit. The dirt I was tilling was very hard, & at times was clay.
There is one more thing to consider when using the tiller though. You need to limit the travel of the strong arm catch by putting a bolt through the last hole. If you let it fall off the end, you will end up going for a joy ride, riding on the tiller instead of the rear wheels. It's quit a thrill when this happens! It's difficult at best to release the catch once this happens.
Good luck with your project,
Joe
RailmanJD318 is offline   Reply With Quote Quick reply to this message
Old 02-09-2011, 09:34 PM   post #10 of 12
LoggerLee
MTF Member
MTF Member # 55294
HAHA,I could see how that could be a thrill Railman!
I've got a bolt in there,thanks for the ideas as far as the belt,might be able to put a slightly smaller pulley in the front too,though the one that's on there looks about as small as I'd like to use.
Old 02-11-2011, 02:14 PM   post #11 of 12
timflury
What happened?
timflury's Avatar
MTF Member # 33250
Larger rear pulley = slower ground speed.
990238 is the model number for the kit. Go to http://www.simplicitymfg.com/manuals for an online book.
I bought an 8" pulley and the proper belt.
Mu 2110 is bedded down for the winter. I'll post results in the spring at plowin' and tillin' time.
The pulleys require a 3/4" hole.
Pulley kits are available at TSC.
A 2110 is model 990432 for manual lift and 990433 for hydrolift.
A vari-drive will not work on your tractor as the BGB output and transaxle input shafts are not long enought for the kit to fit.
The Briggs 10 hp engine is a 243431-0123.
The difference between 10 and 12 hp??? 2
Most likely a different bore and stroke combination.
timflury is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 02-11-2011, 10:00 PM   post #12 of 12
LoggerLee
MTF Member
MTF Member # 55294
Mine has a fairly big pulley on it,looks like a 10" will fit.
Haha,timflury,I know it's 2 hp,I was wondering if there was a way to tell if it was a 10ph or 12ph without pulling the head off the engine to check the bore and stroke
Thanks for the numbers,I'll check it tomorrow.
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
