TerraGrip rubber traction belts - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 02-06-2011, 12:36 PM   post #1 of 12
Capt.Redbeard
MTF Junior Poster
MTF Member # 54741
Default TerraGrip rubber traction belts
Hello new to the forum with a question.
I just recently purchased a set of Terragrip rubber traction belts (http://www.shopgreendealer.com/terra...tionbelts.aspx) for my x300 with 44in blade. I installed them and went out to attempt to get the 5 inches of snow off the 3 inches of solid ice. The minute I left the dry garage floor my wheels started spinning. Pushed the Deere down a ways onto the light fluffy snow. Again started to spin. I came back into the house to read the importance of making them tight, reinstalled, round 2.
Round 2 was worse then round 1. I almost had to push all the way back to the garage. I can not make these belts any tighter, both latches use up all the links to the next belt the inside hook is just 1 short, on each. I even tried the deflate and re-inflate tire for tightening. All of this spinning and I haven't even dropped the blade.
Am I doing something wrong or do these things just not work so well on pure ice? I felt like my standard tires worked on the ice better, but slippage on even the fluffy stuff?
Any help from the knowledgeable members for the forum would be greatly appreciated.
Capt.Redbeard is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 02-06-2011, 12:40 PM   post #2 of 12
stabulus
MTF Member
MTF Member # 53538
Default Re: TerraGrip rubber traction belts
How much weight you got on?
stabulus is offline   Reply With Quote Quick reply to this message
Old 02-06-2011, 12:41 PM   post #3 of 12
wizzo
MTF Tractor Nut
wizzo's Avatar
MTF Member # 32657
Sorry, but I haven't seen any reviews on them yet. Sounds like only a set of tire chains is going to help you out on ice like that.
__________________
2010 John Deere X500
  • 48X w/ Mulch Kit, Gators & HDAPs
  • Brinly Plug Aerator, JD Spreader & 10p Cart
  • 48" Front Blade, Wheel Weights & Suitcase Weights
  • 30" Mechanical Tiller
1994 John Deere 14SB
2000 John Deere JX75
Stihl KM 90R Kombi System
2005 Lawn Boy 10684 Insight Mower
wizzo is offline   Reply With Quote Quick reply to this message
Old 02-06-2011, 12:51 PM   post #4 of 12
Capt.Redbeard
MTF Junior Poster
MTF Member # 54741
Quote:
I have not tried any weight yet, short of my own. My wife feels like I keep putting money into a supposedly low purchase that has slowly been growing.
And yes it is pure ice. We got hit with that freezing rain/sleet then snow then more freezing rain. My neighbor's kid was ice skating on the front lawn.
Old 02-06-2011, 01:18 PM   post #5 of 12
stabulus
MTF Member
MTF Member # 53538
You are probably going to need some weight and go to chains as wizzo suggested. I have 150# of weight plus chains and ice doesn't pose a problem for me.
Old 02-06-2011, 01:23 PM   post #6 of 12
snoyes
2000 Posts and climbing!!!
snoyes's Avatar
MTF Member # 31936
I agree with the others, you may want to try and get some additional weight on the tractor. I haven't seen these Terragrip rubber traction belts, but my guess is on pure ice your only really good option is either studded tires or chains.
__________________
John Deere X748, 54 inch snowplow
John Deere 3720, 300CX Loader
Stihl MS362, Yard Boss, FS 45 trimmer, BG 86 blower
snoyes is offline   Reply With Quote Quick reply to this message
Old 02-06-2011, 01:27 PM   post #7 of 12
D-Dogg
The Magnificent
D-Dogg's Avatar
MTF Member # 20164
Images: 2
Garage
Junk those things, get some weight and chains.
__________________
D-Dogg is offline   Reply With Quote Quick reply to this message
Old 02-06-2011, 06:12 PM   post #8 of 12
slkpk
USMC
slkpk's Avatar
MTF Member # 37
Images: 21
Weight and real chains or try drilling some self tapping screws into the tread on your turfs. slkpk
__________________
1964 JD RF110 Restored
2004 Ingersoll 318LGT @ the church doing the Lord's work
2007 JD 2305
It's too late to worry about it now!
slkpk is offline   Reply With Quote Quick reply to this message
Old 02-06-2011, 06:18 PM   post #9 of 12
PA318Guy
Winter returned!
PA318Guy's Avatar
MTF Member # 31960
Garage
Chains for ice, those rubber straps just aren't going to do the trick on solid ice!
__________________
Current Machine JD 322
Former Machines: JD 318, JD 216, JD 212, 1965 JD 110
My videos: www.youtube.com/user/tkelley16341
PA318Guy is offline   Reply With Quote Quick reply to this message
Old 02-06-2011, 09:15 PM   post #10 of 12
MXZRXP
3K Poster!!!!
MXZRXP's Avatar
MTF Member # 48748
like the guys have said, steel chains on the ice R best but you will even spin steel chains without added weight!
drop 4 suitcase weights on the rear end or wheel weights and give those rubber chains another shot!
even if they don't work you needed the extra weight for the steel chains!!!
(and if you need steel chains get the 2-link version)
good luck-
__________________
STX38 (yellow deck)
345 48C Deck, 42" Blower, Curtis Cab
Propane HEAT (sweet!)
Blower in action here:
http://www.youtube.com/watch?v=8dyoup-StaA
MXZRXP is online now   Reply With Quote Quick reply to this message
Old 02-06-2011, 09:21 PM   post #11 of 12
Jim_WV
Jim_WV's Avatar
MTF Member # 241
Images: 13
Garage
Gotta what the other guys are saying, get real chains and some weight .
Jim_WV is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 02-06-2011, 09:26 PM   post #12 of 12
61woody
Senior MTF Member
61woody's Avatar
MTF Member # 48163
I could see where they would work in snow but on ice your traction devise has to be able to cut into the ice, hence as was stated chains or studs.
__________________
1994 Craftsman 38" (died)
1998 LX176 (sold)
2004 LX280 (sold)
2010 X530
2016 X???
2022 Retired, pay someone else.
61woody is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
