1970 Sears Suburban ignition questions - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 02-04-2011, 11:54 AM   post #1 of 14
TominCT
MTF Member
TominCT's Avatar
MTF Member # 42126
Default 1970 Sears Suburban ignition questions
Electrical noob questions:
My ignition has crapped out on both of my 1970 SS-12s. While I was at Lowes I came across a ignition set with key for $9 and bought it on a whim. As I know very little about the electrical's on the SS12 I have a few questions:
Can I use this ignition for the SS12. The original ignition I recall is a 4 prong and the one I bought is a 5 prong. Part number:OEM 725-0267A
If so, does anyone know what wire goes where?
If not any recommendations for which part# I will need to buy?
TIA
Regards,
Tom
__________________
1970 Sears Suburban SS12 (x3)
Disk Harrow
Rear Plow
Snow Plow
Mower Deck
Snow Blower
Cart
TominCT is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 02-04-2011, 12:09 PM   post #2 of 14
Small Fry
5000 Strong & Climbing
Small Fry's Avatar
MTF Member # 8155
Default Re: 1970 Sears Suburban ignition questions
This is the right replacement switch if you can find the one on the tractor now.
http://sears.pammar.net/switch.pdf
__________________
Small Fry is offline   Reply With Quote Quick reply to this message
Old 02-04-2011, 05:32 PM   post #3 of 14
Bill Kapaun
Circumflatulater
Bill Kapaun's Avatar
MTF Member # 6264
EVEN IF the switches have the same # of terminals, they can be wired VERY differently internally!
For example, if a switch was designed for an engine with coil/points type ignition, substituting a switch for a later engine is going to fry some wiring.
__________________
Illegally Blind
Bill Kapaun is online now   Reply With Quote Quick reply to this message
Old 02-04-2011, 06:12 PM   post #4 of 14
TominCT
MTF Member
TominCT's Avatar
MTF Member # 42126
Thanks for the help guys. Small fry the diagram you mentioned is perfect. I did also find a possible replacement on Ebay:
31-2942 - Roper/Sears 365401R Ignition Switch
Replaces Roper/Sears 365401R. Also replaces switch 74R, 2210R, 5797H, 7486H, 9541H, 21037, 71577, 72841 and 511404.
Replaces OEM #: 365401R
Price $14.30
Is the 365401R ok to use instead of 365401?
TIA
Tom
__________________
Disk Harrow
Rear Plow
Snow Plow
Mower Deck
Snow Blower
Cart
Old 02-04-2011, 07:03 PM   post #5 of 14
Small Fry
Small Fry's Avatar
MTF Member # 8155
I know the switch I listed does not have the 2 big post. It gives you some connectors to make it work.
The one you found looks like it does have the 2 big post. Maybe that's what the R means ? I think your tractor take's a 7486H witch is on that list. Going by what they are saying it will work.
You do have a Starter/Gen on that right ? These switches are for the starter/gen tractors.
__________________
Old 02-04-2011, 08:10 PM   post #6 of 14
TominCT
MTF Member
TominCT's Avatar
MTF Member # 42126
Thank you again SF as your input is always appreciated. Both tractors have the starter/gen. After 41 years with probably both tractors being constantly started and turning off the motor with the original ignition switches, I decided to go with new replacements. The diagram you posted is a huge asset too.
Kind Regards,
Tom
__________________
Disk Harrow
Rear Plow
Snow Plow
Mower Deck
Snow Blower
Cart
Old 02-14-2011, 06:24 PM   post #7 of 14
TominCT
MTF Member
TominCT's Avatar
MTF Member # 42126
Hooked up the new ignition switch (31-2942 - Roper/Sears 365401R Ignition Switch) and she starts when I hold the key on start but the moment I let go of the key it shuts off immediately. What would cause this? I'm thinking maybe a bad ground but would like thoughts before digging deeper.
Regards,
Tom
__________________
Disk Harrow
Rear Plow
Snow Plow
Mower Deck
Snow Blower
Cart
Old 02-14-2011, 06:44 PM   post #8 of 14
Small Fry
Small Fry's Avatar
MTF Member # 8155
I would have to ask, Are you sure it's hooked up right ? Why did you replace the switch to begin with ? Does your new switch look like the old switch,with the 2 big post ?
__________________
Old 02-14-2011, 07:59 PM   post #9 of 14
TominCT
MTF Member
TominCT's Avatar
MTF Member # 42126
Thanks SF for the quick response. I'll take a pic of the hookup with new ignition and post tomorrow. I think I did it correctly as I have 2 of the same tractors and used the other one as reference.
Regards,
Tom
__________________
Disk Harrow
Rear Plow
Snow Plow
Mower Deck
Snow Blower
Cart
Old 02-14-2011, 10:41 PM   post #10 of 14
Small Fry
Small Fry's Avatar
MTF Member # 8155
Sounds like either those switches won't work like the seller said they would, or you have a wire mixed up.
The M terminal is the kill wire. That wire goes to the lower front corner of the engine shroud. There is a little screw it hooks to. Make sure you have that M wire right on the switch.
You have to becareful you don't get them mixed up or you could burn up the solid state unit. $$$
http://www.mytractorforum.com/showthread.php?t=172963
__________________
Old 02-23-2011, 12:45 PM   post #11 of 14
TominCT
MTF Member
TominCT's Avatar
MTF Member # 42126
The ignition works perfect now. I rechecked the wires I originally connected and noticed that I indeed had installed them on the wrong prongs.
I bought the new ignition on Ebay for $14.95 + shipping if anyone is looking to replace their broken ignition switch. Ebay search 2942-365401R and you should find it.
Thanks again for the help.
Regards,
Tom
__________________
Disk Harrow
Rear Plow
Snow Plow
Mower Deck
Snow Blower
Cart
Old 02-23-2011, 02:09 PM   post #12 of 14
GT_80
Cranky Motorsports
GT_80's Avatar
MTF Member # 35886
Images: 32
Garage
Bravo! I love fixing wiring issues!
__________________
MTF Addict #35886
Hugh-SS/16 fan #0001
Tractors:
1968 Super12 "Miss Emma Lee"
1967 Suburban 12 "The 679"
1973 SS16/ 18/6 hybrid "Mighty Mongrel"
1976 SS18 "Trusty"
1978 GT18 with Hard cab - home again!
Attachments:As many as I can get
My YouTubeMy Ebay
Sears Manuals
GT_80 is offline   Reply With Quote Quick reply to this message
Old 02-23-2011, 04:48 PM   post #13 of 14
Small Fry
Small Fry's Avatar
MTF Member # 8155
Good to hear you having it working.
__________________
Sponsored Links
Advertisement
Old 03-03-2011, 07:23 PM   post #14 of 14
Captn. Crunch
MTF Junior Poster
Captn. Crunch's Avatar
MTF Member # 53550
I also am having an ignition issue with a suburban. I got a 64 7.25 DB and the switch fell apart. It has six terminals and a push button switch to the right of that. I can't find anything close to the switch and I am not sure what the button did - never pushed it. and it's broke too!
__________________
2 1965 Gravely Super convertables 7.6
1 1952 Wisconsin powered L
1 1964 David Bradley Sears Suburban 7.25 hp
1 Dump Cart
2 30 in. Brush Hogs
2 40 in. finish Decks
2 Rotory Plow
1 Rotory Cultivator
1 Reel Mower
1 Square Chute Snowblower
1 Sickle Bar Mower
1 Power Brush
1 Snow Blade
1 Sulky
Captn. Crunch is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
