clearance on 8n compression test - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 01-26-2011, 08:00 AM   post #1 of 7
Kajun
MTF Member
MTF Member # 54912
Default clearance on 8n compression test
I tried to get my compression checker threaded in on my 8n but the gas tank is in the way....are there any tricks to this? do i need to remove the gas tank and hood to do it?
also which forum do I post question for a 1955+ hundred series ford in? this one or the ford/new holland board?
Kajun is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 01-26-2011, 10:25 AM   post #2 of 7
Steve (Magnolia, TX)
Retired - Veteran Mod
Steve (Magnolia, TX)'s Avatar
MTF Member # 251
Images: 13
Garage
Default Re: clearance on 8n compression test
Quote:
You shouldn't need to remove the gas tank... assuming that the gas tank is properly installed (we recently had a thread where the poster was having similar problems... only he was just trying to remove his spark plugs... and come to find out, he had either a "non-standard" gas tank... or his tank was improperly installed).
I'm not really sure what to tell you to help... other than to say that it IS possible to get a compression guage in there (assuming that you have a guage with a flex hose? and you're "remoting" the guage?).
Yes.
Either one.
The Ford/New Holland forum is really "designed" for the hundred series Fords... and we can move your thread over there, need be.
Steve (Magnolia, TX) is offline   Reply With Quote Quick reply to this message
Old 01-26-2011, 08:26 PM   post #3 of 7
JohnW
3K Poster!!!!
JohnW's Avatar
MTF Member # 1445
Images: 3
Garage
a gauge with a flex hose should have no problem at all.
JohnW is online now   Reply With Quote Quick reply to this message
Old 01-27-2011, 05:39 PM   post #4 of 7
Dan
Senior MTF Member
Dan's Avatar
MTF Member # 883
Images: 2
I get my cheapo Harbor Frieght flexible compression tester hose on all the time on my 8Ns with the gas tank in place.
Dan
__________________
Old Iron Addict
1948 8N Delilah
1954 NAA Rustbucket
1939 9N (Name to be forthcoming)
1952 8N Sampson - Gone but not forgotten
8N Acres
Dan is offline   Reply With Quote Quick reply to this message
Old 01-30-2011, 01:05 AM   post #5 of 7
Kajun
MTF Member
MTF Member # 54912
thanks..well i got my compression hose in there and was able to get a cold comp check...reading from rear to front cyls....90,105,100,80
what do ya think about that 80? i'm hoping after its warmed up and run some seafoam through it that it comes up.
Old 01-30-2011, 01:14 AM   post #6 of 7
2_Late_I_Won
Senior MTF Member
2_Late_I_Won's Avatar
MTF Member # 29025
Images: 3
Do a wet compression test that will tell you if it's your valves or your rings. If it's your rings seafoam won't do anything. If it is your rings or cylinder it's self maybe some engine restore would work or at least help. Good luck.
2_Late_I_Won is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 01-30-2011, 06:36 PM   post #7 of 7
JohnW
3K Poster!!!!
JohnW's Avatar
MTF Member # 1445
Images: 3
Garage
As said do a wet test, if it comes up then it is rings, if not then it is probably valves.
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
