windshield washer fluid for filled tires - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 01-22-2011, 09:32 PM   #1
jerseymark
MTF Member
MTF Member # 51571
Default windshield washer fluid for filled tires
Does windshield washer fluid cause rusting or ruin the rim or tire when use to fill tires?
__________________
2007 John Deere 2305, 54" mmm, 200cx FEL
jerseymark is offline   Reply With Quote
Sponsored Links
Advertisement
Old 01-23-2011, 12:19 AM   #2
Luv2Q
Member of the 0.3k Club!!
Luv2Q's Avatar
MTF Member # 45441
Images: 3
Default Re: windshield washer fluid for filled tires
Quote:
No personal experience here using WWF but doing a "Google Custom Search" of MTF seems to indicate .. not much. Some folks thought it inhibited rust, others thought it didn't. The consensus seems to be that Rimguard (derivative of beet juice which is non-corrosive and is also heavier than water) is best followed by RV antifreeze (propylene glycol rather than the toxic ethylene glycol used in automotive antifreeze).
I'll be adding fluid to my tires one of these days and will likely use the RV A/F. Nearest place I can get Rimguard is in the Dallas area, about 150 mi away.
__________________
Regards, John
2010 Kubota B2320HSD w/ FEL, 54" MMM, 4' boxblade, 4' LP shredder, 5' LP rake, 6' blade
1958 Ford 601 Workmaster - Gone but not forgotten
1947 Ford 8N - Ditto
Troy-Bilt Model 13025 + 25 gal towed sprayer
Carolina Skiff J16 w/ Suzi 25
Luv2Q is offline   Reply With Quote
Old 01-23-2011, 06:07 AM   #3
TUDOR
5000 Strong & Climbing
MTF Member # 28463
Even air will rust the inside of a rim, if the paint job is substandard.
The most caustic fluid for tire loading is calcium. I can attest to the rusting out of rims in 12 - 14 years using this medium, ...... twice, ........ on the same tractor. Even straight water won't match that destruction. Don't worry about it.
__________________
Bob
Click for The Hydraulics Forum!
Sometimes you get on a roll, sometimes the roll gets on you.
In Service
MF GC2310, Husqvarna YTH20B42T
Down for Repairs
MF1655 w/ FEL, MF1655, MF12H, MF8H, MF7H
Spending too much time on MTF to work on my toys.
TUDOR is online now   Reply With Quote
Old 01-23-2011, 08:02 PM   #4
PA PLOW DAY
Plow Day Man!
PA PLOW DAY's Avatar
MTF Member # 21366
i've used windshield washer fluid, no problems, my good friend had his newest tractor filled with that rimguard stuff that was mentioned and the dealer swears by it.
__________________
Bryan Seward, Co-Founder of the PA Plow Day and Garden Tractor Show.
PA PLOW DAY is offline   Reply With Quote
Old 01-23-2011, 11:48 PM   #5
Wedgie
MTF Junior Poster
MTF Member # 36740
The most common tire fluid around my area is the chloride solution and there are also a lot of rusted-out rims as well. When I bought a new tractor several years ago I wanted to stay away from the salt so I asked what could be used as an alternative. They acted like there wasn't anything they could really think of.
I asked if RV antifreeze could be used. They guessed it could be but they weren't too thrilled about it. Still, I got some and had it installed. That was about 8 years ago and I have not had any problems at all. I would highly recommend it. I have heard some good things about RimGuard but it seems to be hard to come by in my area of Illinois.
George
Wedgie is offline   Reply With Quote
Old 01-24-2011, 01:16 PM   #6
silver hair deere
Old as Sin
silver hair deere's Avatar
MTF Member # 4257
Images: 4
Heres a question , the only thing holding air in my tires is plugs and slime , is filling them out ? or do i need tubes .
__________________
Silver Hair Deere
1989 Sears GT
1989 GMC 1500 , NEEDS BALL JOINTS
1996 MTD 695 , REBUILDER
1995 CHEVY LUMINA APV , NEEDS HALSHAFTS
1998 FORD RANGER
When one breaks down , i just drive another .
silver hair deere is offline   Reply With Quote
Old 01-24-2011, 11:02 PM   #7
Hugh-SS/16
Junior-Senior Member
Hugh-SS/16's Avatar
MTF Member # 31282
Images: 15
Garage
I put new tires on my SS/16 and loaded them with out tubes cause the rims and tires are mint.
You can load tubes, but you get less weight and it takes longer.
WWF is non corrosive, and usually will say so on the label
__________________
GT_80 Fan Club Member: #0001
'78 GT/19.9 Twin, '78 GT/18 Twin, '78 GT/18 Hydrodrive, '77 18/6 Twin, '73 SS/16 Twin, '65 Suburban 8
I'm 18 years old, and always looking to learn!
Hugh-SS/16 is offline   Reply With Quote
Old 01-25-2011, 12:02 PM   #8
wally2q
2000 Posts and climbing!!!
wally2q's Avatar
MTF Member # 45
The next best thing is sugar. Highly soluble in water (especially when the water is warmed up), and then causes the water solution to be heavier... like rimguard.... and totally not-corrosive.... AND totally not toxic.... but it may attract ants (and kids) if spilled out of your tire.
you can dissolve just over 200g of sugar in 100ml (100g) of water at 20 deg C.
Doing that, you can make sugar-water pretty thick... like syrup... and it's heavy as heck...
wally2q is offline   Reply With Quote
Old 01-29-2011, 09:15 AM   #9
x595
JD RULES
x595's Avatar
MTF Member # 23848
Images: 3
wally2q , the Sugar Solution you speak of might be Heavy , but I would think it will Freeze without an additive added ...
Later,x595
__________________
2005 JD X595 w/ HDAP Tires
54c MMM --- (SOLD)
62c MMM
54" Quick Hitch Front Blade
4x8 Utility Trailer - 1500# Axle
North Star 15,000 Watt Generator
Troy - Bilt Super Bronco Rear Tine Tiller
Troy - Bilt 2500 PSI Pressure Washer
22" Yard Machine Push Mower
SpeeCo SplitMaster 28 Ton - Horizontal/Vertical Log Splitter
STIHL 025 - 18" Bar
STIHL 025 - (Spare Parts Saw)
STIHL MS 290 FARM BOSS - 20" Bar
STIHL FS 45 Trimmer
x595 is offline   Reply With Quote
Old 01-29-2011, 03:11 PM   #10
Upper5Percent
Upper5Percent's Avatar
MTF Member # 8602
Quote:
Later,x595
Sugar will also precipitate out of solution...leaving just water to freeze if the temperature is low enough...
Take a glass of water, add sugar stir, then come back in a couple of hours...then put that glass in the freezer for night...
__________________
So Long, and Thanks for All the Fish
Upper5Percent is offline   Reply With Quote
Old 01-31-2011, 10:27 AM   #11
wally2q
wally2q's Avatar
MTF Member # 45
Yes - it may precipitate - hence the right (maximum) mixture is required.... also adding alcohol will lower the freezing point.... in other words - put sugar into plumbing antifreeze.
Separately, sugar/water solution has a lower freezing point than pure water in the first place (chemistry)....
Old 01-31-2011, 11:16 AM   #12
GT_80
Cranky Motorsports
GT_80's Avatar
MTF Member # 35886
Images: 32
Garage
WWS is the cheapest easiest solution to use. And, I have said this before, and stand by it, it may be toxic wheras RV antifreeze is not, however, antifreeze does not evaporate- if you spill wws, it evaporates because it is alcohol. And it gets all over the ground every time you wash your windows on your car anyway. My local supermarket sells it for $1.50 a gallon- if you can find me something that is THAT cheap, and environmentally friendly, I will use it. Otherwise, WWS all the way!
__________________
MTF Addict #35886
Tractors:
1963 David Bradley 725 (Ole' Blue)
1967 Suburban 10 (Jolene - For Sale)
1968 Super12 (Miss Emma Lee)
1976 SS18 (Trusty)
1977 18/6 (Chance)
My YouTubeMy Ebay
My Free manuals
Sears Manuals
GT_80 is offline   Reply With Quote
Old 02-01-2011, 03:00 AM   #13
TUDOR
MTF Member # 28463
I dunno, I tend to buy weight for loading my tractor tires, not volume. I loaded my tires with as much weight as others with WWF or RV antifreeze PLUS 50 lb. wheel weights. The calcium in each of my 26x12-12 weighed 160 lb. RimGuard is almost as heavy.
Loaded tire plus 40 lb. MF split wheel weights plus 15 lb. 2 link chains equals 253 lb. per tire, or 506 lb that the axle doesn't see.
Years ago, the 23x8.5-12 tires on my MF12 carried 65 lb. of calcium each, and the 16x8.5-8's on my Gilson carried 25 lb. each.
I have no idea how much volume, only the weight matters for traction.
__________________
Bob
In Service
Down for Repairs
Old 02-01-2011, 08:18 PM   #14
walterboatwright
Senior MTF Member
walterboatwright's Avatar
MTF Member # 21679
Images: 5
Any liquid weight is great. But if you puncture a tire it will most likely ruin it.Liquid is great but the fabric content in most round rubber cant contain the stress with a small hole.Myself I would stay away from the calcium chloride . The same stuff used to melt ice and make pickles. Try an alcohol baised additive.or maybe a vegtable oil weight .its heavier than water and its bio-degradable.
walterboatwright is offline   Reply With Quote
Sponsored Links
Advertisement
Old 02-02-2011, 01:56 AM   #15
TUDOR
MTF Member # 28463
Quote:
Absolutely correct! Unfortunately, RimGuard is a fairly recent product and was not available to me when I loaded my tires 15 years ago. The rims are now totally corroded from the calcium, for the second time in 29 years. That's why I recommend the beet juice.
My new rims will be loaded with the Canadian equivalent of RimGuard, which is also biodegradable and much heavier than the antifreezes. Vegetable oil tends to congeal into a solid lump at subfreezing temps making for a very rough ride, and like the antifreezes, is also lighter than straight water. Ask your wife as she's doing dishes.
Punctures are a normal fact of life with any pneumatic tire equipped vehicle, especially if you take it off road. I've had more punctures in my truck tires than my tractor tires in the last 35 years, and the trucks stayed on the road.
__________________
Bob
In Service
Down for Repairs
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
