Need help with 455 Quick Hitch Adjustment - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 01-22-2011, 09:43 PM   post #1 of 8
455
MTF Junior Poster
455's Avatar
MTF Member # 54790
Default Need help with 455 Quick Hitch Adjustment
Hi All,
Needed a resource for an issue I'm having, found this forum, thought I'd give it a try. Have a JD455 with a JD Quick Hitch (4 way hydraulics) with a JD 54" blade.
During the last few days of plowing snow the left angling of the blade has been reducing a good amount with the right angling seeming to become more pronounced. Vertical hydraulics are working fine.
I have the original manuals for everything, but didn't readily find mention of how to correct this.
Thanks for any help any of you can offer. On a separate note, I think I'll be looking to purchase a snow thrower implement for the quick hitch next season. Any recommendations for where to purchase something used?
Thanks again!
455 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 01-22-2011, 09:56 PM   post #2 of 8
andyb
Diesel Power
andyb's Avatar
MTF Member # 32157
Garage
Default Re: Need help with 455 Quick Hitch Adjustment
I had a quickhitch with a blade on a 445 and found that snow would pack and freeze around the angling cylinder limiting the travel of the blade. That shouldn't affect the angling to the right though. The only other thing I can think of is the diverter valve, or lockout valve, that limits hydraulic fluid flow to the cylinder that raises and lowers the mower deck. If it isn't closed all the way it could affect the speed of the angling cylinder.
__________________
2010 John Deere x748
3 point hitch
rear PTO
54" blade
62" deck
284.4 hours and counting
http://www.youtube.com/watch?v=h1dzMX49NC0
____________________
1994 John Deere 445 sold
andyb is online now   Reply With Quote Quick reply to this message
Old 01-22-2011, 10:07 PM   post #3 of 8
SonnyT
Hoosier Born & Raised!
SonnyT's Avatar
MTF Member # 21893
Images: 26
Garage
If you need easy Picture help
Be sure to Register for Your State/!
__________________
SonnyT is online now   Reply With Quote Quick reply to this message
Old 01-22-2011, 10:27 PM   post #4 of 8
Mike X485
The Welcome Wagon Mod
Mike X485's Avatar
MTF Member # 47023
Images: 7
Garage
455, Welcome to the forum. Need more info on whats going on with the blade. Is it not moving far enough to the left? Or not staying there?
__________________
JOHN DEERE X748
Mike X485 is offline   Reply With Quote Quick reply to this message
Old 01-23-2011, 12:07 AM   post #5 of 8
Jfoi
Way Out Here
Jfoi's Avatar
MTF Member # 48661
Quote:
Originally Posted by 455 View Post
Hi All,
Thanks again!
The same thing happened to me last year... do not and i repeat do not force it. the line that is connected to the angling has a 90 degree elbow that broke cause i had the same thing happen... your best bet is to get a little heater and heat the snow up and let it melt. what happens is the snow gets compacted and it wont let it get to full angle
__________________
John Deere x320
48" xtra cutting system
44" front blade
John Deere 455
60" commercial belly mower
54" quiktach dozer blade
Jfoi is offline   Reply With Quote Quick reply to this message
Old 01-23-2011, 06:14 AM   post #6 of 8
slkpk
USMC
slkpk's Avatar
MTF Member # 37
Images: 21
Also check your hydraulic fittings on the cylinder as they may have loosed up and be catching on the frame. slkpk
__________________
1964 JD RF110 Restored
2004 Ingersoll 318LGT @ the church doing the Lord's work
2007 JD 2305
It's too late to worry about it now!
slkpk is offline   Reply With Quote Quick reply to this message
Old 01-23-2011, 01:52 PM   post #7 of 8
JDFANATIC
9K+ Poster
JDFANATIC's Avatar
MTF Member # 41
Images: 1
Garage
Welcome to the forum! Good advice above.
__________________
Cheers
JDFANATIC
JD2210, loaded tires, 62C MMM, 210 Loader, 47" Snowblower, York Rake, PTO Spreader, Heated Cab, JD Plug Aerator, FIMCO Sprayer, Wheel Spacers, FEMCO Folding ROPS, JD Cart, Stihl MS170 and HT101, Wallenstein BX32 PTO Chipper
JDFANATIC is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 01-23-2011, 06:14 PM   post #8 of 8
455
MTF Junior Poster
455's Avatar
MTF Member # 54790
Thanks for your feedback everyone. Snow had frozen in the angling hydraulic relief. Removed it and all's well again. Luckily, the elbow hardware wasnt damaged. Got some before and after pics I'll upload later of this. Maybe that'll be helpful for someone else down the line!
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
