Berco remote chute deflector seized - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Snow Removal Equipment Winter snow throwing, plowing, and removal forum. From snow blowers to snow shovels, you'll find them here.
Reply
Thread Tools Display Modes
Old 01-21-2011, 09:04 AM   post #1 of 3
ggsteve
5000 Strong & Climbing
ggsteve's Avatar
MTF Member # 9436
Garage
Default Berco remote chute deflector seized
I have a 2005 Berco Northeast 44" snow thrower (# 700374) that works great except for one thing. I purchased the remote chute deflector (# 700239) two winters ago, and from time to time since new the chute control has frozen up inside the telescoping mechanism inside the spring attached to the chute itself. The cable is fine. In the past I have been able to thaw it out either by using a hair drier or even just breathing on it for a few moments. Not anymore. For the last week it has been seized in place, even at temps well above freezing.
Anyone ever seen this or have any suggestions? I can't get at the telescoping rod without taking it all apart because the rod is inside the tension spring.
__________________
ggsteve
08 Craftsman Professional 24hp B&S ELS 42" deck 3 bin bagger Berco 44" blower & 48" blade OTC cab
68 JD 112H 47 deck 43 blade
69 JD 110H 37A blower 50 cart
71 JD 140H3 integral hitch 54" 4-way blade 46" deck cozy cab
71 JD 140H1
72 JD 110 parts
78 JD 316K 49 blower
81 JD 317 Onan JB Sr. 46" deck 80 Cart
84 JD 214 39 deck 43 blade
86 JD 318 3pt
Toro 212-5 36" blower
74 Concord (MTD) 990
12 cu. ft. poly cart, JD front dethatcher, plug aerator, drop spreader, box blade, 10" bottom plow, sweeper
ggsteve is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 01-21-2011, 11:16 AM   post #2 of 3
GrassMeUp
Senior MTF Member
GrassMeUp's Avatar
MTF Member # 45567
Default Re: Berco remote chute deflector seized
Other than taking it off and soaking it in anti-freeze or maybe lubricating it with low vis synthetic oil
however
this is now available
Haven't done one myself, kinda hard to justify since I live right on that snow/rain line for the past 4 storms
http://www.sears.com/shc/s/p_10153_1...6&blockType=G6
__________________
2010 Cub Cadet LTX1046
48" Bercomac Northeast snowblower
Past> 1994 indestructable Craftsman GT6000
Kubota BX2200D Loader
GrassMeUp is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 01-22-2011, 05:10 PM   post #3 of 3
ggsteve
ggsteve's Avatar
MTF Member # 9436
Garage
I figured it out. The outer sheath had bent a little bit. I straightened it and the inner sleeve can slide in and out now. It was binding before.
__________________
ggsteve
71 JD 140H1
72 JD 110 parts
86 JD 318 3pt
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
