Bolens 1050 keyswitch ? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 01-17-2011, 08:06 PM   post #1 of 11
farmerall
Proud Member of the 1K Club
farmerall's Avatar
MTF Member # 35756
Images: 11
Garage
Default Bolens 1050 keyswitch ?
The other day I was trying to start my 1050 and one of the poles broke broke off of the back of the switch. It is the switch that has three poles on it. One for ingnition, one for the starter and one for the battery. I tried to find one at the local Napa but the only three poled switchs they had were for magneto ignition. Does anyone know were I can get a new one or a part number so I can take it to Napa to have them look it up.
Thnaks Matt
farmerall is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 01-17-2011, 08:12 PM   post #2 of 11
New2Bolens
MTF Junior Poster
New2Bolens's Avatar
MTF Member # 54512
Default Re: Bolens 1050 keyswitch ?
Try thhttp://www.psep.biz/store/troy_bilt_...ical_parts.htm
is site
__________________
New2Bolens is offline   Reply With Quote Quick reply to this message
Old 01-17-2011, 11:15 PM   post #3 of 11
BOLENSBOY60
BOLENSBOY60's Avatar
MTF Member # 37707
that sounds like the wrong ing switch for the 1050- does it have a push button starter switch on it? should be 5 spades on the back i `m pretty sure
BOLENSBOY60 is offline   Reply With Quote Quick reply to this message
Old 01-18-2011, 05:30 AM   post #4 of 11
teapot
Senior MTF Member
teapot's Avatar
MTF Member # 28869
I have been layed up with a new hip and a bad knee, but I will see if I can get the part number for the switch. I also think it a 5 bladed switch. What does the wiring diagram show?
thanks teapot
teapot is offline   Reply With Quote Quick reply to this message
Old 01-18-2011, 06:32 AM   post #5 of 11
67bolens"ek10"
sam
67bolens"ek10"'s Avatar
MTF Member # 54568
Images: 1
my 1050 has a 3 terminals on the switch an its all original.
67bolens"ek10" is offline   Reply With Quote Quick reply to this message
Old 01-18-2011, 10:18 AM   post #6 of 11
farmerall
farmerall's Avatar
MTF Member # 35756
Images: 11
Garage
I believe that it is the original switch since the tractors wiring seems to be untouched or modified. Also my 850 has the same switch in it and the wiring is original to it.
Old 01-18-2011, 11:39 AM   post #7 of 11
BOLENSBOY60
MTF Member # 37707
i think it depends if your engine is a tr-10d or a TRA-10D
Old 01-18-2011, 03:26 PM   post #8 of 11
gray wolf
3K Poster!!!!
MTF Member # 40073
I have a tr 10d .the switch has 5 poles but I only use three poles to make run.
gray wolf is online now   Reply With Quote Quick reply to this message
Old 01-18-2011, 03:38 PM   post #9 of 11
67bolens"ek10"
sam
MTF Member # 54568
Images: 1
i have a tra-10d in my 1050. my 850 is a s-8d and i think it has the same switch. pretty sure the 650 does also an that has a b&s.
Old 01-18-2011, 07:53 PM   post #10 of 11
29 Chev
Senior MTF Member
29 Chev's Avatar
MTF Member # 4733
Images: 2
Attached are the wiring diagram for a 1050 Bolens ignition switch with battery ignition and the Napa cat page of two switches which will probably work but you would have to change the wire ends from eye to spade terminals and only use the B,I, and S terminals - 7-01854 and 7-01892 -(diffferent diameter mounting stem - 9/16" or 5/8"). At the bottom of the wiring diagram page it shows the connections of the orignal switch in each position ( I=ignition B=battery S=solenoid) off - no connection, on - connection from battery to ignition, and start - connection from battery to ignition and solenoid. Double check with an ohmmeter to verify the circuits work the same before buying or installing - hope this helps
29 Chev is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 01-18-2011, 11:45 PM   post #11 of 11
farmerall
farmerall's Avatar
MTF Member # 35756
Images: 11
Garage
Thanks for all of the help. I got a switch with 5 posts and plan to only use the three I need.
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
