John Deere 425 Fuel Problem - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 01-09-2011, 08:40 PM   #1
Muley99
MTF Junior Poster
MTF Member # 54326
Default John Deere 425 Fuel Problem
I just acquired a 96 John Deere 425. Its not getting any fuel to the fuel filter. I hear a click when I turn the key which I assume is the fuel solenoid but no noise from the fuel pump. They only fuses I see are located on the board on the side under the steering, they are good. I understand the fuel pump is located in the fuel tank. Question is do I have to pull the seat and metal assembly to get to it and how likely is it the fuel pump is bad? I have a 52 Ford 8n that I've worked on quite a bit but with the electronics on this thing it's a whole new ball game.
Muley99 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 01-09-2011, 09:05 PM   #2
Engine_Tech
Proud Member of the 1K Club
MTF Member # 46741
Default Re: John Deere 425 Fuel Problem
Don't let the electronics spook you too much at this point. There is a fuel pump relay I believe, that could be the cause of the problem.
Since you sound more comfy with mechanical things than electrical, here's the most basic way to check w/o a schematic or probing things under the dash...
Pull the fenderdeck and check for power back there at the pump. I think all that holds it on are a couple bolts at the front and two under the seat. Then you can probe the power connector back there. If power, then it's the pump. If no power, then it's electrical - again, probably the relay.
You'll need the schematic to go much further...
Engine_Tech is offline   Reply With Quote
Old 01-09-2011, 09:21 PM   #3
Muley99
MTF Junior Poster
MTF Member # 54326
Thanks I'll pull the fender and give it a try. I noticed the bolts under the seat are gone only the two by the foot rest are still there.
Old 01-10-2011, 06:19 PM   #4
Muley99
MTF Junior Poster
MTF Member # 54326
Pulled the fuel pump today and the assembly was completely rusted! I'm getting 12v at the plug but the pump does not run. I think I'm safe saying the pump needs to be replaced. Are there any aftermarket pumps available or is OEM the best way to go? Does anyone know of a good online parts dealer?
Thanks for the help so far, it sure made things easier!!
Old 01-10-2011, 07:58 PM   #5
Mike X485
5000 Strong & Climbing
Mike X485's Avatar
MTF Member # 47023
Images: 7
Garage
Keeping it green.com is excellent for parts.
__________________
JOHN DEERE X485
Mike X485 is online now   Reply With Quote
Sponsored Links
Advertisement
Old 01-10-2011, 08:10 PM   #6
WNYTractorTinkerer
7K and climbin'!!
WNYTractorTinkerer's Avatar
MTF Member # 26264
Images: 13
Garage
Icon2 Re: John Deere 425 Fuel Problem
Check both sides of the circuit! Yyou're dealing with DC!! Check the ground @ the plug also!!
__________________
Experience is something we get.... right after we needed it!!
Can You see the Real me?
WNYTractorTinkerer is offline   Reply With Quote
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
