How hard will it be to fix the sloppy steering on my 140? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 01-08-2011, 09:06 PM   post #1 of 15
ggsteve
5000 Strong & Climbing
ggsteve's Avatar
MTF Member # 9436
Garage
Help How hard will it be to fix the sloppy steering on my 140?
My 1971 140H3 has about 180* of play in the wheel. It can be exciting when plowing! I'd like to fix it so, I need to know what is likely to be wrong, what to look for, where to look for it, and what am I in for as far as fixing it. Thanks for your thoughts, guidance and help in advance!
__________________
ggsteve
08 Craftsman Professional 24hp B&S ELS 42" deck 3 bin bagger Berco 44" blower & 48" blade OTC cab
68 JD 112H 47 deck 43 blade
69 JD 110H 37A blower 50 cart
71 JD 140H3 integral hitch 54" 4-way blade 46" deck cozy cab
71 JD 140H1
72 JD 110 parts
78 JD 316K 49 blower
81 JD 317 Onan JB Sr. 46" deck 80 Cart
84 JD 214 39 deck 43 blade
86 JD 318 3pt
Toro 212-5 36" blower
74 Concord (MTD) 990
12 cu. ft. poly cart, JD front dethatcher, plug aerator, drop spreader, box blade, 10" bottom plow, sweeper
ggsteve is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 01-08-2011, 09:15 PM   post #2 of 15
saleen49
Super Duper Member
saleen49's Avatar
MTF Member # 21045
Images: 2
Default Re: How hard will it be to fix the sloppy steering on my 140?
You can start by carefully jiggling the steering wheel right and left while watching each component of your steering system for slop. Manual steering columns have an adjustment for play if you have one of those. Tie rod ends usually wear out first.
__________________
1983 318.
2009 X729 with 54" deck & 54" blade, oh and 45 loader
__________________________________________________ __
"I have not failed. I've just found 10,000 ways that won't work." Thomas A. Edison
saleen49 is offline   Reply With Quote Quick reply to this message
Old 01-08-2011, 09:16 PM   post #3 of 15
PA318Guy
Winter returned!
PA318Guy's Avatar
MTF Member # 31960
Garage
ggsteve, those steeing units are like the ones used in the 110 and 212. Working on one in the tractor is a pain. I recommend pulling it out (not fun) to work on it or replace it. Below is the diagram and you can see that there aren't any "gears" you can work on. I just replaced the one in my 110 and 212 with units I bought off ebay. I suppose they can be fixed, but I'd bet you'd have more money into a repair than a replacement!
__________________
Current Machine JD 322
Former Machines: JD 318, JD 216, JD 212, 1965 JD 110
My videos: www.youtube.com/user/tkelley16341
PA318Guy is online now   Reply With Quote Quick reply to this message
Old 01-08-2011, 09:20 PM   post #4 of 15
tmaynard
Senior MTF Member
tmaynard's Avatar
MTF Member # 34476
It is easy or hard to fix depending on whether the bolt is worn or not, to tighten the steering you need to pull out the battery box and you will see the steering box, on the left side (from the seat) you will see a bolt with a slot on the end and a nut on it against the box, if you loosen the nut and adjust the screw in (I think) then tighten the nut you should be able to find a medium between loose and hard to steer.
__________________
-Tom
1968 John Deere 140 H3 54 4 Way Blade, 3 Point Hitch, Brass Tag 33 Tiller
1981 John Deere 400 54 4 Way Blade, 60" Deck
And a bunch more John Deere Garden Tractors
tmaynard is offline   Reply With Quote Quick reply to this message
Old 01-08-2011, 09:24 PM   post #5 of 15
saleen49
Super Duper Member
saleen49's Avatar
MTF Member # 21045
Images: 2
I agree they are a pain. Do they have the threaded adjusting plug on the bottom? Might be able to turn it in to take up some of the slop.
__________________
1983 318.
Old 01-08-2011, 09:26 PM   post #6 of 15
saleen49
Super Duper Member
saleen49's Avatar
MTF Member # 21045
Images: 2
Ah, steerring box! Mak e adjustments a quarter turn at a time and test it out. Thats how we adjusted them in our trucks back in the day.
__________________
1983 318.
Old 01-08-2011, 09:29 PM   post #7 of 15
PA318Guy
Winter returned!
PA318Guy's Avatar
MTF Member # 31960
Garage
Part 14 is the bolt that tmaynard is talking about. You can sometimes take up the slop by tightening # 19 as is pushes up on the lower bushing which should mesh the internals a bit tighter. Don't forget to grease it well when done! Try that before you opt to get a replacement. With the manual steeing I always kept a spare steering column around! They went out normally when snowblowing in deep snow, as far from the house as possible!
__________________
Old 01-08-2011, 09:40 PM   post #8 of 15
saleen49
Super Duper Member
saleen49's Avatar
MTF Member # 21045
Images: 2
Its been quite a while, but can't you add preload to 19? Doesn't 19 load a race 18 to a ball bearing 16? I know I've done one of these on a JD 100.
__________________
1983 318.
Old 01-08-2011, 10:44 PM   post #9 of 15
ggsteve
ggsteve's Avatar
MTF Member # 9436
Garage
Ok two questions: Is nut #19 something I can get at from beneath the tractor? I have the cab on so if I'm pulling the battery tray and going for the steering box I have to take the cab off. I know I can check the tie rods under there anyway. I'd just rather not pull the cab off until spring if I can help it.
Question 2: What does it mean to "preload" part #19? Thanks again for the help!
__________________
ggsteve
71 JD 140H1
72 JD 110 parts
86 JD 318 3pt
Old 01-08-2011, 10:46 PM   post #10 of 15
tedfx4
MTF Junior Poster
tedfx4's Avatar
MTF Member # 43204
On my 317 I had about the same amount of slop the steering box was fine. I just had to rebushing everything from the box to the front axel.
__________________
2010 x720se 54" deck, quick hitch, 54" snow blower,
3 pt
1990 185 46" deck and 38" snow thrower
2-317s one for parts one being restored
108 with snow thrower
tedfx4 is offline   Reply With Quote Quick reply to this message
Old 01-08-2011, 10:52 PM   post #11 of 15
deereboy55
close enuff works for me
deereboy55's Avatar
MTF Member # 19601
Garage
There is also a triangle shaped plate under the engine, that two tie rods and the steering drag link hook to.It has a tapered nut holding it in place ,and if it is loose will give you a lot of slop in the steering.
deereboy55 is online now   Reply With Quote Quick reply to this message
Old 01-08-2011, 11:05 PM   post #12 of 15
PA318Guy
Winter returned!
PA318Guy's Avatar
MTF Member # 31960
Garage
# 19 can be reached from under the tractor. Mine had a cotter key through the nut to hold it set where it was. I believe when they say preload they are referring to tightening it till it is has pressure back on the wrench (preload) then backing off slightly. Wish I still had my 110 or 212 manual! If I'm wrong on that someone with a manual correct it!
__________________
Old 01-08-2011, 11:28 PM   post #13 of 15
saleen49
Super Duper Member
saleen49's Avatar
MTF Member # 21045
Images: 2
Quote:
You are on the right track. I was able to remove a remarkable amount of steering slop from a JD 100 by adding preload to the jam screw at the bottom of the column, which would be were 19 is on the drawing. But, too much preload can cause damage to the mechanism.
__________________
1983 318.
Old 01-08-2011, 11:34 PM   post #14 of 15
tranks
Professional amateur!
tranks's Avatar
MTF Member # 36078
Images: 19
Garage
Quote:
that was the problem with my 112. i had a lot of play, i think it was almost a full turn. the triangle plate was about as loose as it could get. i tightened it up and replaced all 6 tie rod ends. steers great now!
there is a lock plate (?) that holds that tapered nut in place, my lock plate was bent and the nut was able to turn inside it. if you tighten it, tighten until the steering is tight, not the nut.
__________________
mike
building a steerable yard cart --- New video post #53
1971 John Deere 112--2000 New Holland LS55H
1985 John Deere 112L
tranks is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 01-09-2011, 12:08 AM   post #15 of 15
adamjd
Senior MTF Member
adamjd's Avatar
MTF Member # 47837
I did a thread on my 317 when I rebuilt the steering gear. It is called 317 Cleanup and Repair. I guess it is still on here if you do a search. Adam
adamjd is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
