Source on used Airplane Tires - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Trailers We have to pull our machines once in a while...
Reply
Thread Tools Display Modes
Old 01-16-2006, 11:08 AM   post #1 of 9
msmithla
MTF Junior Poster
msmithla's Avatar
MTF Member # 348
Images: 1
Default Source on used Airplane Tires
Hi guys,
I have a small trailer that I use to pull an ATV, and I use it behind the ATV in the yard. Great little home made trailer my dad built when in the Navy. (early 70's)
Anyway, since he was in the navy when he built it, he used pretty much what ever was laying around. He used airplane tires / wheels, built some custome hubs in the machine shop,etc.
The tires are now over 30 years old and the tread is comming off one of them. Due to the design, I have to stay with airplane tires. Does anyone know where I could pick up some used ones? I thought about going to the local airport and seeing what I could find. Tire Size 6.50 - 8
msmithla is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 01-16-2006, 11:12 AM   post #2 of 9
dirtybernie
Retired Mod
dirtybernie's Avatar
MTF Member # 381
Images: 1
Default Re: Source on used Airplane Tires
whats the difference (other than the load rating) is it the beads on the rim?
__________________
Lawn-Mower-Central.com
dirtybernie is offline   Reply With Quote Quick reply to this message
Old 01-16-2006, 11:14 AM   post #3 of 9
msmithla
MTF Junior Poster
msmithla's Avatar
MTF Member # 348
Images: 1
Yes, I believe so, checked once and I had to stay with that stlye tire. Rim size / bead
Old 01-16-2006, 12:11 PM   post #4 of 9
guest
Guest
Posts: n/a
msmithla,
I think this may be what you are looking for.
http://www.noflats.com/
These guys specialize in this area. Good luck!
Old 01-16-2006, 02:13 PM   post #5 of 9
Carm
Senior MTF Member
Carm's Avatar
MTF Member # 100
Images: 2
6.50-8 is used a lot by Cessna on their 310 series. I think its also used as a nose tire on some caravan models as well. Try looking at some airports wit general avaition repair stations. Not airline or military. They will probably have what you need. I can probably get them here on the field where I work.
__________________
Brute force and Ignorance
Carm is offline   Reply With Quote Quick reply to this message
Old 01-16-2006, 02:55 PM   post #6 of 9
msmithla
MTF Junior Poster
msmithla's Avatar
MTF Member # 348
Images: 1
Thanks Guys,
There are alot of small planes out at the local airport, hopefully I can find some there.
Carm,
If you run across some, please let me know. Thanks
Old 01-16-2006, 03:00 PM   post #7 of 9
Splicer
Splicer's Avatar
MTF Member # 1134
Images: 4
30 year old tiresand they still hold air and are just now falling apart? WOW ! Can't you google army surplus tires or something?
Splicer is offline   Reply With Quote Quick reply to this message
Old 01-17-2006, 09:19 AM   post #8 of 9
Carm
Senior MTF Member
Carm's Avatar
MTF Member # 100
Images: 2
will do msmith
__________________
Sponsored Links
Advertisement
Old 04-10-2006, 02:40 AM   post #9 of 9
Langoley
MTF Junior Poster
MTF Member # 1375
I think the no-flats ;ink will take you to Gensco corporation.They are in Houston Tx. and now also in Anniston, Al.They are the #1 supplier of airplane tires for aftermarket use.They have a real great method of cutting down the bead so you can get them mounted on a standard rim!They offer tires in just about any size and tread you can imagine,from used take-offs to newly recapped tires! Just do a goggle and give them a call!!
Langoley is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
