Adding a winch to my JD 214 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Backyard Round Table - L & G Tractor Related Topics Lawn and Garden Tractor Related Topics General Discussion Board
Reply
Thread Tools Display Modes
Old 12-31-2010, 07:03 PM   post #1 of 36
ggsteve
5000 Strong & Climbing
ggsteve's Avatar
MTF Member # 9436
Garage
Default Adding a winch to my JD 214
I bought the bargain Harbor Freight 2000# winch before winter with the hopes of using it to lift and lower my Berco blower. It's just too large to fit anywhere convenient on my Craftsman such that it could be oriented to lift the blower. So I put it on a shelf for future use.
I originally wanted to mount it on the front of a tractor, like you would on an off road vehicle. It would then be in the way of blowers and blades, so that wouldn't work. Then today I got the idea of mounting it to the drawbar of my 214. I had to drill one 5/16" hole to run a bolt, but it fits nicely and I don't think it will interfere with tow behind attachments, except perhaps on a really sharp left hand turn.
Here is the winch bolted to the draw bar:
Here's what it looks like on the tractor:
I Since it is not a permanent installation (yet), I bought some wing nuts for the winch:
and the battery connections:
so that the remote power switch can be easily connected and disconnected. Here is the wiring running fore and aft from the switch. You can also see the cable in this picture:
Here's a picture of the switch. I would like to figure out a way to permanently afix the switch to the right fender of the 214 without too much damage. The switch has no brackets, tabs or holes for permanent mounting and drilling such would ruin it's waterproof properties. I'm not thrilled with the idea of drilling into my 214's fender either. How long do you think something like velcro would last?:
That's it. It works great. Tomorrow I'm going to use it to pull down the top of a tree that got hung up on a branch while falling, it's first real job. Then I might use it to pull the Toro 212-5 out of the woods and snow. More seat time!
__________________
ggsteve
08 Craftsman Professional 24hp B&S ELS 42" deck 3 bin bagger Berco 44" blower & 48" blade OTC cab
68 JD 112H 47 deck 43 blade
69 JD 110H 37A blower 50 cart
71 JD 140H3 integral hitch 54" 4-way blade 46" deck cozy cab
71 JD 140H1
72 JD 110 parts
78 JD 316K 49 blower
81 JD 317 Onan JB Sr. 46" deck 80 Cart
84 JD 214 39 deck 43 blade
86 JD 318 3pt
Toro 212-5 36" blower
74 Concord (MTD) 990
12 cu. ft. poly cart, JD front dethatcher, plug aerator, drop spreader, box blade, 10" bottom plow, sweeper
ggsteve is online now   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 12-31-2010, 07:40 PM   post #2 of 36
CrazyRoper
Senior MTF Member
CrazyRoper's Avatar
MTF Member # 33339
Default Re: Adding a winch to my JD 214
i got a winch on the back of my GT, theres a million and one uses for one of them
__________________
tractors:
1980 Turf Trac 16/44 (MTD 824) - rear side-by-side plow, rear snow/dirt blade, v-bar 4 link tire chains.
1982 John Deere 66 RER
1988 Roper YT16 hydro
other:
2006 Craftsman Push 6.5hp front wheel drive
1983 Princess Auto Mini Bike (in progress)
1967 Mercury (ford) half ton 240 3spd
1965 snow cruiser 360 opposed twin, 2 stroke, 14hp
operator of:
2010 John Deere 2320 mid mower, bagger and rear tiller.
2005 Grasshopper 60" front mount , bagger
CrazyRoper is offline   Reply With Quote Quick reply to this message
Old 12-31-2010, 07:40 PM   post #3 of 36
Deck_drive
Finally at 1k!
Deck_drive's Avatar
MTF Member # 34304
Images: 6
Garage
Velcro and double sided tape would work. Velcro is used in boats and stuff so I think it would work.
__________________
1968 Super 12
42in scissor lift deck
48in old style deck
3pt hitch
Gannon Earthcavator
1973 sears ST16
Craftsman GT6000
Deck_drive is offline   Reply With Quote Quick reply to this message
Old 12-31-2010, 07:44 PM   post #4 of 36
PA318Guy
Winter returned!
PA318Guy's Avatar
MTF Member # 31960
Garage
ggsteve, you will want to use doublelock Velcro tape. I used it on my electric box I made for my cab and it's holding great! You can find it at boat stores!
__________________
Current Machine JD 322
Former Machines: JD 318, JD 216, JD 212, 1965 JD 110
My videos: www.youtube.com/user/tkelley16341
PA318Guy is online now   Reply With Quote Quick reply to this message
Old 12-31-2010, 07:57 PM   post #5 of 36
=ZooT=
=ZooT='s Avatar
MTF Member # 53805
Thanks for sharing the details and the pix.
=ZooT= is offline   Reply With Quote Quick reply to this message
Old 12-31-2010, 10:16 PM   post #6 of 36
ben2go
MTF New Poster
ben2go's Avatar
MTF Member # 11920
Try to find velcro(aka hook and loop)with the 3M adhesive at least 1 inch wide.That's what we used when we reupholstered boats.Holds really well.May I ask a favor?Would you please,make a plastic or rubber cover for those winch terminals?They look a little to exposed hanging lower than the tractor.I made one out of a small plastic freezer box.It wasn't specific for a winch,but it was for a Ford solenoid.
ben2go is offline   Reply With Quote Quick reply to this message
Old 12-31-2010, 10:29 PM   post #7 of 36
ggsteve
ggsteve's Avatar
MTF Member # 9436
Garage
Quote:
Thanks to all for the tips about "marine grade" Velcro. That's a good idea about protecting the terminals. Once I have the switch mounted I will snake and zip tie the wiring under the fender pan. Perhaps I will use that heat shrink tubing on the terminals at that point, and maybe even cut off the extra threads so they don't get hooked on anything.
__________________
ggsteve
71 JD 140H1
72 JD 110 parts
86 JD 318 3pt
Old 12-31-2010, 10:30 PM   post #8 of 36
ben2go
MTF New Poster
ben2go's Avatar
MTF Member # 11920
Quote:
You're welcome.Keep us posted and put up some pics of the transformation.
Old 12-31-2010, 10:41 PM   post #9 of 36
ggsteve
ggsteve's Avatar
MTF Member # 9436
Garage
Does anyone know the purpose of this? The package called it a "hook strap" and I am instructed to hang the loop on the end onto the winch hook. Why I don't know.
__________________
ggsteve
71 JD 140H1
72 JD 110 parts
86 JD 318 3pt
Old 12-31-2010, 10:51 PM   post #10 of 36
CrazyRoper
Senior MTF Member
CrazyRoper's Avatar
MTF Member # 33339
when your manually pulling out the line, it is suppposed to be safer to grab that then the hook directly.
__________________
tractors:
other:
operator of:
Old 12-31-2010, 11:12 PM   post #11 of 36
PA318Guy
Winter returned!
PA318Guy's Avatar
MTF Member # 31960
Garage
I've heard that the strap is in case your line touches electric when pulling out you don't get shocked. Not sure that I buy that but I don't think they'd last too long. My BIL bought me a winch for Christmas, I'm trying to figure a method to use it front and rear on the 318 and on the trailer and truck. Some type of "universal" mount that I have an initial idea on! Looks like your already getting some use out of yours!
__________________
Old 12-31-2010, 11:16 PM   post #12 of 36
SonnyT
Hoosier Born & Raised!
SonnyT's Avatar
MTF Member # 21893
Images: 26
Garage
Velcro would work, but I made a holder for my Custom to hold it while using or I can easily take it out to use it. small flat strap and a peice of 2' sq tube.
__________________
SonnyT is online now   Reply With Quote Quick reply to this message
Old 12-31-2010, 11:20 PM   post #13 of 36
SonnyT
SonnyT's Avatar
MTF Member # 21893
Images: 26
Garage
Quote:
that is what it is for and also when rewinding you use it to put some tension on the line.
__________________
Old 12-31-2010, 11:23 PM   post #14 of 36
ben2go
MTF New Poster
ben2go's Avatar
MTF Member # 11920
That's what the Warn manual said for the winch I had.It's just a safety feature in case an idiot (like me) mounts it and doesn't put the electric solenoid cover back on.Baisicly,so they can say the operator was at fault for not following the supplied safety directions, when someone sues them(not like me).
Sponsored Links
Advertisement
Old 12-31-2010, 11:59 PM   post #15 of 36
nick 130
Proud Member of the 1K Club
nick 130's Avatar
MTF Member # 30413
thats a nice winch i was thinking of doing that i always seem to need one but never have it but once i get it ill prob never use it
__________________
2004 lt2000
1980 sears lt1036
1964 david bradley sears suburban 7.25hp
new englander medallian 18.5hp
1969 ariens
sears lt10/36
19?? allis chalmers 410
nick 130 is online now   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
