JD 170 Snow Blower - How do you remove auger from blower housing? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 12-21-2010, 04:17 PM   post #1 of 10
Freefall_Doug
MTF Member
MTF Member # 43654
Images: 1
Default JD 170 Snow Blower - How do you remove auger from blower housing?
I am breaking my JD170 blower down so I can remove the rust and repaint. The blower chute is going to get sand blasted, but I am going to wire wheel the blower housing because I would have to wait until the sandblasting place was doing an outside job.
I have everything removed except for the auger.
One on side of the auger there is the gear that drives the auger shaft. It had a set screw, but it is still stuck on there good.
There is also bearings assembleys on each side of the housing, one assembly is hiding behind the gear I just mentioned.
I am not sure what order I should be tackling this. I don't want to bugger up parts if there is a better procedure to break it all down.
Thanks!!!!
Freefall_Doug is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 12-21-2010, 06:00 PM   post #2 of 10
creekhed1
deerhed
creekhed1's Avatar
MTF Member # 50697
Images: 1
Default Re: JD 170 Snow Blower - How do you remove auger from blower housing?
I WAS gonna go the route you are describing but decided to "get in there" as best I could with an angle grinder and sandpaper with the auger still attached. In the end I painted it yellow and it turned out GREAT. Glad I passed on the dis/re-assembly...but if you are into it go for it (alas I have no real useful info here!).
__________________
Ingersoll 3012 w/ 38"Snowcaster.
SOLD:
Cub Cadet 2166 Cub Cadet 1554 Sabre 1538 John Deere GT275 with 42 Blower and 44" Plow John Deere 316 with 49 Blower
Ingersoll 3016 w/Hard Cab & Blower Case 224 Case 222 Case 222
Wheel Horse Lawn Ranger JohnDeere LX266
Simplicity Conquest John Deere GX345
John Deere 335 John Deere 345
John Deere 140H1 John Deere 140H3 w/Tiller
For Sale:
Cub Cadet 1525 Sabre 1742 HS
John Deere 316 Vid
Ingersoll 3016 Vid
creekhed1 is offline   Reply With Quote Quick reply to this message
Old 12-21-2010, 07:32 PM   post #3 of 10
KATT
5000 Strong & Climbing
KATT's Avatar
MTF Member # 34056
My buddy helped me take mine out.( well I mostly assisted) after unbolting the ends and shearbolt etc. there are 2 keyways to watch out for. Then we had to hit it with a sledge hammer ( busted a couple of 2X4's ) as cushions and used some " unclean words " the shaft finally moved !!
you need to support the auger as you remove the shaft.
Good luck and I feelit is a 2 man job at best !!!!!!
I'm sure you read my post and pics on my #38 reno
KATT is offline   Reply With Quote Quick reply to this message
Old 12-21-2010, 07:34 PM   post #4 of 10
Freefall_Doug
MTF Member
MTF Member # 43654
Images: 1
Just fitting sandpaper in wouldn't work. To much rust due to PO sucking up gravel on his driveway.
I got it all apart now except for the cutting edge. The cutting edge bolts are spinning. Will need to grind the heads off.
I am leaning towards having everything blasted if I can find a place that has a big enough cabinet.
Old 12-21-2010, 07:37 PM   post #5 of 10
Freefall_Doug
MTF Member
MTF Member # 43654
Images: 1
KATT yes I read your post but haven't reread it. It is a one man job with a 2 jaw gear puller, but you have to take your time!
Old 12-21-2010, 07:38 PM   post #6 of 10
KATT
KATT's Avatar
MTF Member # 34056
I had to grind ALL the heads off. the good news the PO never turned it around so I didn't have to buy a new one !!!!!
Old 12-21-2010, 08:34 PM   post #7 of 10
Freefall_Doug
MTF Member
MTF Member # 43654
Images: 1
Same here, I can reuse it. It will go back on this season, but I think plastic strip made of cutting board material might work well.
Old 12-21-2010, 08:49 PM   post #8 of 10
KATT
KATT's Avatar
MTF Member # 34056
Good idea don't know if you knew but the resto was for my Nephew.
He got all you see in the thread the restored 175 the restored #38 blower and the restored #38 mower. The good news his father my brother picked up the ( purchase) bills for nephews Christmas present. I supplied the labor and replacement parts as my contribution. and I keep Rusty for my trouble !!
I never got anything like that for any of MY Christmas'
Old 12-22-2010, 06:44 AM   post #9 of 10
lahkota
MTF Member
lahkota's Avatar
MTF Member # 12015
When I rebuilt the blower for my GT275 I ran into the same problem with the cutting edge bolts. I laid a board over top of a couple of bolt heads, clamped it down with a c-clamp, and was able to get the nuts off. Hope this helps, grinding off bolt heads ain't no fun.
lahkota is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 12-22-2010, 04:06 PM   post #10 of 10
Freefall_Doug
MTF Member
MTF Member # 43654
Images: 1
I only needed to grind two. The other ones I notched with a cut off wheel and used a big screw driver to hold the bolts still.
Dropped all the parts off for sandblasting, they should be ready sometime next week
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
