How do I test the fuel shut off solenoid? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Small Engines and Repair
Midwest Mower Pro
Reply
Thread Tools Display Modes
Old 12-19-2010, 05:57 PM   post #1 of 20
SnowMower
Senior MTF Member
SnowMower's Avatar
MTF Member # 1058
Images: 1
Default How do I test the fuel shut off solenoid?
Hi guys, how do I actually test the solenoid itself?
I have confirmed I have power where the solenoid plugs into the harness connector.
So, I will remove the solenoid.
1) Do I need to ground the solenoid for it to actuate?
2) And is there a particular part of the solenoid I need to ground in order to make it actuate. Any particular part I should NOT ground for fear of electricuting myself or ruining the part?
Thanks
Snowmower
Oh ya, this is on a 25hp Kohler in a craftman GT5000.
__________________
Gravity. It's not just a good idea ... it's the LAW!
SnowMower is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 12-19-2010, 07:15 PM   post #2 of 20
monteman_73
Senior MTF Member
monteman_73's Avatar
MTF Member # 53585
Default Re: How do I test the fuel shut off solenoid?
After you remove the actuator, see if it moves freely by hand. If not, replace it. If it is free, plug it back in, turn the key on, and I would try to touch some type of ground where the "nut" part of the actuator is. I would try not to touch ground where the threads are on the actuator as not to cause a pit on the threads by arcing to ground. Don't touch the power side of the actuator. It is like a miniture coil and may give you a small jolt when you remove it from ground or pull the power away. Good luck in your venture.
monteman_73 is offline   Reply With Quote Quick reply to this message
Old 12-19-2010, 09:17 PM   post #3 of 20
38racing
Proud Member of the 1K Club
MTF Member # 25899
you can test with a 9volt battery. Positive to the positive lead and negative to the body or negative lead (if there is one)
38racing is offline   Reply With Quote Quick reply to this message
Old 12-20-2010, 12:25 AM   post #4 of 20
rayjay
2000 Posts and climbing!!!
MTF Member # 53093
Make sure you have rinsed all the gasoline out of the thing before you test it. A little spark might cause a surprise.
rayjay is offline   Reply With Quote Quick reply to this message
Old 12-20-2010, 09:53 AM   post #5 of 20
SnowMower
Senior MTF Member
SnowMower's Avatar
MTF Member # 1058
Images: 1
Thanks guys. So if I read this right, the threaded part of the solenoid is what i need to ground.
Appreciate the help. Will give it a try next weekend once all of the Christmas hubbub comes to an end.
Bill
__________________
Old 12-20-2010, 11:39 AM   post #6 of 20
draddogs
draddogs's Avatar
MTF Member # 4
Images: 6
You should be able to hear it when you turn the ignition on..It will click showing you that your solenoid is working...Possible some crud in your float bowl plugging the main jet which the solenoid closes on at shut down.
__________________
Handle every Stressful situation like a dog.
If you can't eat it or play with it,
Pee on it and walk away.
draddogs is offline   Reply With Quote Quick reply to this message
Old 12-20-2010, 12:11 PM   post #7 of 20
Walt 2002
Senior MTF Poster
MTF Member # 1229
Many of these now days have a duplex plug and one wire is a ground. Get a shock from 12 V DC??
Walt Conner
Walt 2002 is offline   Reply With Quote Quick reply to this message
Old 12-20-2010, 12:17 PM   post #8 of 20
Fcubman
3K Poster!!!!
Fcubman's Avatar
MTF Member # 18953
Images: 5
Quote:
Walt Conner
The coil of wire in the solenoid acts just like an ignition coil - when you break the connection, it produces a voltage spike, one you can definitely feel. There are gag items that give the "victim" a jolt, and they run on 3 volt batteries. So yes, it's quite possible to get a jolt from low voltage DC.
__________________
Remember, I'm pullin' for ya! We're all in this together!
(Red Green)
Living in The Land Of The Free - because of The Brave!
Fcubman is offline   Reply With Quote Quick reply to this message
Old 12-20-2010, 08:46 PM   post #9 of 20
wilber
Senior MTF Member
wilber's Avatar
MTF Member # 49462
Just put your hand on it without removing it turn ign on and off you will feel it function.
Why do you want to test it ??
W
wilber is offline   Reply With Quote Quick reply to this message
Old 12-21-2010, 09:35 PM   post #10 of 20
SnowMower
Senior MTF Member
SnowMower's Avatar
MTF Member # 1058
Images: 1
Quote:
W
Cause my tractor won't go. And the snow is piling up.
I've confirmed spark, I have confirmed air, and I have confirmed fuel - as far as the fuel pump. This looks like the reason my baby won't go. If I put fuel directly into the carb, the engine will run until that fuel is used up.
I am trying to figure out if the solenoid is shot, or if something in the carb is stuck. (Hope it is just something sticky, as I hear these parts cost a pretty penny).
Thanks
Bill
__________________
Old 12-21-2010, 09:52 PM   post #11 of 20
Fcubman
3K Poster!!!!
Fcubman's Avatar
MTF Member # 18953
Images: 5
You can replace that solenoid with a bolt. There is a thread around here somewhere that gives the size. It's a hardware store item, nothing special. You might even have one on hand, although I think it's a fine thread.
Worst that can happen is it will afterfire when you shut it down.
__________________
(Red Green)
Old 12-21-2010, 10:54 PM   post #12 of 20
rayjay
MTF Member # 53093
If the solenoid is no good then take some side cutters and cut off the plunger and screw the thing back into the carb. Don't hook the wire back up, tape it somewhere out of the way if you decide to replace the solenoid in the future.
Old 12-23-2010, 07:32 AM   post #13 of 20
DTLMG
Master Service Technician
MTF Member # 42277
Images: 2
There are also some diodes in the wire harness that can cause some grief...Ill try to find a pic and get back to you...
__________________
DTLMG
Make sure your red wire goes to positive, and your black to ground
Master Senior Service Technician
30+yrs in Outdoor Power Equip Industry
DTLMG is offline   Reply With Quote Quick reply to this message
Old 12-26-2010, 02:19 PM   post #14 of 20
DTLMG
MTF Member # 42277
Images: 2
Default Video Test of Fuel Solenoid
This out to clear up any misunderstandings. Please not that this is a Kawasaki Fuel Solenoid that needs to be PRELOADED when testing.
http://www.youtube.com/watch?v=2n8xfcnqy9U
(See Eugene...you thought I was asleep at Kawasaki school last month!)
__________________
DTLMG
Sponsored Links
Advertisement
Old 12-26-2010, 11:38 PM   post #15 of 20
38racing
MTF Member # 25899
Does kawi work opposite? on briggs the plunger would be extended and applying current draws it down. He is pushing it down and then current is pushing it out.
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
