Shear bolt size for 44" select series blower - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 12-16-2010, 09:33 AM   post #1 of 14
kirscp
MTF Member
MTF Member # 53140
Default Shear bolt size for 44" select series blower
The dealer never gave me the manual for my blower, so if anyone would let me know the size of the shear bolt for the 44" select series snow blower, that would be greatly appreciated.
Thanks.
kirscp is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 12-16-2010, 11:03 AM   post #2 of 14
Herd of Deeres
Certified Master Tinkerer
Herd of Deeres's Avatar
MTF Member # 32443
Default Re: Shear bolt size for 44" select series blower
Try the John Deere Parts Catalog
Probably need to start with your tractor and work your way through accessories.
__________________
Current Herd:
John Deere 175, 180 & 185
1983 JD 214 Hydraulic Lift
1963 John Deere 110
Deerely DeParted:
1969 JD 110 H DeereZilla
On to Greener pastures:
1969.5 JD 110H FrankenDeere
Herd of Deeres is offline   Reply With Quote Quick reply to this message
Old 12-16-2010, 04:40 PM   post #3 of 14
kirscp
MTF Member
MTF Member # 53140
Thanks, it comes up with 19M7834 - SCREW - M6 X 45
Old 12-16-2010, 06:12 PM   post #4 of 14
Markcuda
Banned!
MTF Member # 13642
Smile Re: Shear bolt size for 44" select series blower
If you bought the blower new, the 4 shear bolts and nuts come with it.
Edit=here is a manual.
http://manuals.deere.com/cceomview/O...dex.html?tM=HO
Markcuda is offline   Reply With Quote Quick reply to this message
Old 12-16-2010, 08:08 PM   post #5 of 14
KATT
5000 Strong & Climbing
KATT's Avatar
MTF Member # 34056
from the owners manual look under Part Numbers last page.
1 for auger shear bolt , 1 for nut, 1 for impeller shear, 1 for nut
__________________
" 09 " X520 with 48" Deck, #44 Snow Blower, Weather Enclosure, Wheel Weights, Chains, drift cutter, Brush Guard, #36 Tow Behind Spreader, Single bucket holder, #7 #80 and #50 Trailers,
Previous JD's
"86' 318 #44 Front End Loader, #49 Snow Blower. TY15380 Hard Cab, Wheel weights Chains Weight box ( 6 suitcases ) "99"LX279 Liquid Cooled /48"Deck."87"SX95 / Rear Bagger, 165 Hydro, STX38, LX188. Toy a 175 Hydro #38 snow blower #38 mower deck
and of course
"87" JD 175
- Rusty -
KATT is offline   Reply With Quote Quick reply to this message
Old 12-16-2010, 08:56 PM   post #6 of 14
jdaws
Senior MTF Member
jdaws's Avatar
MTF Member # 42666
Go to the hardware store and get some 6mm soft bolts and lock nuts.
jdaws is offline   Reply With Quote Quick reply to this message
Old 12-17-2010, 01:06 AM   post #7 of 14
HydroHarold
10,000 +posts!
MTF Member # 82
Images: 1
So would those "soft" bolts be scored properly to be used as a shear bolt? Shear bolts are just that, designed and machined with a weakened spot to give way long before any solid bolt will, and it will break in a manner where it will not damage either parts of the blower/auger. Hey, it's your stuff, It's just that I believe in using the proper safety valves on my equipment.
HydroHarold is offline   Reply With Quote Quick reply to this message
Old 12-17-2010, 01:18 AM   post #8 of 14
KATT
KATT's Avatar
MTF Member # 34056
Wait !! Mark and I gave him the on line manual and the page # for the right bolts WHY would you use anything else IMHO ??!!
Old 12-17-2010, 01:22 AM   post #9 of 14
Markcuda
Banned!
MTF Member # 13642
Replacing Shear Bolts
IMPORTANT: Avoid damage! Replacement shear bolts must be same as original shear bolts on attachment:
Softer bolts can shear too easily.
Harder bolts may not shear and attachment can be damaged.
NOTE: Four spare M6x45 auger shear bolts and M6 nuts are provided in the bag of parts.
Old 12-17-2010, 01:28 AM   post #10 of 14
KATT
KATT's Avatar
MTF Member # 34056
I keep the 4 in the tool holder next to the seat so they are with me, but even on my old #49 I only replaced 1 in 25 years. ( asphalt drive but I ran into the cement steps in a 3 foot blizzard oops !!) I didn't exactly say oops, but it did had a S in it !!
Old 12-17-2010, 04:03 AM   post #11 of 14
kirscp
MTF Member
MTF Member # 53140
My dealer was kind enough to assemble the blower and install it for me .... so I didn't get any bag of parts or the manual. The "shear" bolt that was currently in there was just a threaded bolt, threaded the entire way. I'm use to the shear bolts that are scored.
Thanks for the manual and I'll have to see if I can find the spare shear bolts.
Old 12-17-2010, 08:25 AM   post #12 of 14
Markcuda
Banned!
MTF Member # 13642
That is what my 4 bolts look like.
Old 12-17-2010, 08:25 PM   post #13 of 14
KATT
KATT's Avatar
MTF Member # 34056
Mine Dealer did too and gave me the Manual and bolts and anything else in the plastic bag from JD. They were there from JD in the crate !!
Same bolts as mine Mark Those are the correct ones !!
__________________
Previous JD's
and of course
"87" JD 175
- Rusty -
Sponsored Links
Advertisement
Old 12-17-2010, 08:29 PM   post #14 of 14
jdaws
Senior MTF Member
jdaws's Avatar
MTF Member # 42666
I took one of the original bolts that came with my blower and matched it with bolts from the hardware store. The number on the bolt head indicates the hardness. I have been useing these for the last 2 years, have sheared several and they work fine.
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
