#1 |
Senior MTF Member
MTF Member # 40681
I just replaced the head gasket on my suburban about 2 weeks ago and it was running great. While I had the head off, I cleaned the carbon build up off the head and top of the piston and checked everything which looked to be good and healthy. There was no scoring in the cylinder and the valves seemed tight, without taking the valve spring inspection cover off.
Today I noticed that it was leaking in the same spot again, just above the carb. I was degreasing the motor and sprayed some soap and thats when I noticed it was bubbling out. I tightened the head bolts down and it was still bubbling. I am going to pull the head off again tomorrow and check it again. Hopefully there are not any cracks anywhere.
__________________
![]() 65 Sears Suburban 8 HP w/ 10 HP repower (The Old Tractor) 72 Ford LGT125 (The Hydro) 74 Ford LGT100 (The Ford) Johnson FEL 48" Dozer 48" Mid grader 50" Mower 42" snowthrower 86 F350 1 tn PU 4x4 03 Dodge Durango 4x4 "There is a sickness worse than alcohol and dope, it is the tractor debt, and there is no cure in sight."
| Sponsored Links | |||
Advertisement | |||
#3 |
DEERE & SEARS CRAZY!!!
MTF Member # 5655
did you check the head and block with a straight edge? may need to resurface one or the other or both....most of the time it is just the head needs resurfaced.not hard to do.
#4 |
Collector of many tractors
Glue a sheet of sandpaper to a sheet of glass...
Rub head on paper... Any low or high spots will show it's self ...
__________________
#5 |
Senior MTF Member
MTF Member # 40681
I am going to try the sandpaper idea now. I'll let you know how I made out. Thanks Bob
__________________
#6 |
Senior MTF Member
MTF Member # 40681
Sandpaper worked on the head. It was all twisted and warped. I put the head back on sprayed some soap around the head gasket and cranked it over and it is still bubbling.
How do I resurface the cast iron block? I pulled the motor and am going to start cleaning all the built up oil and dirt off it. I am even thinking of repainting it.
__________________
#7 | |
Cranky Motorsports
Quote:
#8 | |
Senior MTF Member
MTF Member # 40681
Quote:
I'm going to have to pick some up. Thanks Bob
__________________
#9 |
Cranky Motorsports
#10 |
3K Poster!!!!
MTF Member # 31735
You can true up a small block using a big flat file. Just go slowly and hold the file good and flat to the block. I use a 2" wide by 16" long Mill Bastard that I got years ago for truing up castings. Having a good file brush will keep the file clean and sharp.
I'd suggest having the piston just below TDC and sealing it with grease. This will allow you to keep the filings from going down alongside the piston. What little grease is left between the piston and cylinder wall after the cleanup will dissipate shortly after startup. Mike
__________________
A gun and a parachute are much the same. When you need one nothing else will really suffice. |
#11 |
MTF Member # 5655
you have been given the same advice i would give.but ,i always use copper coat on my head gaskets i forgot to mention that in my last post. hope everything works out for you.
| Sponsored Links | |
Advertisement |
| Sponsored Links | |
Advertisement | |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | |
