Mower deck removal on a JD 425... - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 12-11-2010, 10:20 PM   post #1 of 18
425Forever
Senior MTF Member
425Forever's Avatar
MTF Member # 52718
Default Mower deck removal on a JD 425...
Can someone please give me a step-by-step set of instructions on how to remove a 60" mower deck from a '92 JD 425? I need to take the deck off in order to move the tractor back to VA and have never had it off. Thanks.
__________________
2012 x729 - 48" deck, 3pt hitch, front fenders
1992 JD 425 AWS - Gone but not forgotten
42" Hydraulic Tiller
MC519 cart and Powerflow
Dump scoop
'65 model 80 cart with narrow wheels
Several old Wheel Horses
425Forever is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 12-12-2010, 06:53 AM   post #2 of 18
slkpk
USMC
slkpk's Avatar
MTF Member # 37
Images: 21
Default Re: Mower deck removal on a JD 425...
Start engine and raise the mower deck all of the way up.
Dial deck knob to lowest setting.
Turn your gauge wheels to the side.
Turn steering wheels a 1/4 of turn to the left.
Lower your deck all of the way down.
Pull your j pins and raise the arms up and lock the arms in place with the deck knob.
Slide the collar back off of the PTO shaft and lay across the top of deck.
Pull and swivel the front coupler and remove from deck and tractor frame.
slide deck out from right side of tractor. Thats how my 1997 worked.
The end. slkpk
__________________
1964 JD RF110 Restored
2004 Ingersoll 318LGT @ the church doing the Lord's work
2007 JD 2305
It's too late to worry about it now!
slkpk is offline   Reply With Quote Quick reply to this message
Old 12-12-2010, 07:50 AM   post #3 of 18
425Forever
Senior MTF Member
425Forever's Avatar
MTF Member # 52718
Thank you for the info slkpk. I have a technical manual but haven't found any mower deck removal/installation instructions. I wish JD would put this info in the operators manual. I do have a copy of that and printed it out.
__________________
Dump scoop
Old 12-12-2010, 08:11 AM   post #4 of 18
Visioneer
MTF Member
Visioneer's Avatar
MTF Member # 21391
Images: 3
Turn your steering wheel fully to the left and remove the mower from the right hand side. Pull the pins on your gauge wheels so the deck sits as close to the concrete as possible. Make sure your tires are fully inflated also. The AWS models have less ground clearance so the gear box will catch on the mower lift arms. Though it's not neccesary if you have a floor jack handy you might lift the back end a little to make the job less frustrating since you haven't done it before.
__________________
JD X729 425, 445 AWS, 47 Snowblower, 51 Broom, 54 Blade, 3 pt Slip Scoop
Previously Owned: JD 318, 425 AWS, JD 4300 MFWD HST,430FEL,48BH
Visioneer is online now   Reply With Quote Quick reply to this message
Old 12-12-2010, 09:39 AM   post #5 of 18
D-Dogg
The Magnificent
D-Dogg's Avatar
MTF Member # 20164
Images: 2
Garage
Quote:
They are probably in the deck operator's manual, rather than the tractor's.
__________________
D-Dogg is offline   Reply With Quote Quick reply to this message
Old 12-12-2010, 09:40 AM   post #6 of 18
jwill1776
Senior MTF Member
jwill1776's Avatar
MTF Member # 33215
The mower decks came with their own operators manual, thatís why you didnít find the instructions in the Tractor manual. Slkpkís instructions are probably more detailed than what came in the manual.
__________________
John Deere 425 Ė 54Ē Deck
Ruegg Cat 0 / Cat 1 Combo 3-Point Hitch
Brinly Cultivator
Brinly 12" Single Bottom Plow
Brinly 60" Rear Blade
jwill1776 is offline   Reply With Quote Quick reply to this message
Old 04-01-2014, 11:26 AM   post #7 of 18
InspectorFowler
MTF Junior Poster
InspectorFowler's Avatar
MTF Member # 191930
All right, the newb is resurrecting a super old thread. Better than starting a new one, right?
I got my deck off my 425 to install a 3 point hitch. All of that went really well, except for one step.
How, exactly, do I secure the lift arms in the fully upward position? I know I'll need to disconnect them from the hydraulic system, otherwise they continue to raise and lower along with the hitch, exposing themselves to damage. I can see the attachment on each arm that connects it to the hydraulic system, but how do I then secure the arms in the upward position? The deck knob mentioned above doesn't seem to have much effect on anything.
InspectorFowler is online now   Reply With Quote Quick reply to this message
Old 04-01-2014, 11:49 AM   post #8 of 18
JJW
Senior MTF Member
JJW's Avatar
MTF Member # 42685
You should not need to disconnect anything. There is a threaded rod on the left side of the hitch as you are looking at it from behind, raise the hitch & turn this rod until the hitch stays all the way up. This rod is to control the depth of the hitch. The 3PH is controlled with the same cylinder as the deck.
Maybe someone else will post a picture of it.
__________________
X748 (2011)
Johnny Bucket SR.
355D (2001)
XL Clycone Rake
JJW is offline   Reply With Quote Quick reply to this message
Old 04-01-2014, 11:52 AM   post #9 of 18
InspectorFowler
MTF Junior Poster
MTF Member # 191930
I was probably unclear.
I meant the two arms that raise and lower the mower deck.
If I detach them from the hydraulic system, they just hang loose.
If I leave them attached, they are definitely going to strike something on the ground.
How do I secure them in their highest position?
Old 04-01-2014, 12:06 PM   post #10 of 18
Diesel Powered
MTF mile high club member
Diesel Powered's Avatar
MTF Member # 69612
Raise the arms with the hydraulics, then wind the height adjustment knob (the one right in front of the seat) all the way to the end (so the depth stop is all the way up).
__________________
2011 JD X748
2004 JD 4410 TLB
1966 JD 110H
Diesel Powered is online now   Reply With Quote Quick reply to this message
Old 04-01-2014, 12:09 PM   post #11 of 18
InspectorFowler
MTF Junior Poster
MTF Member # 191930
Quote:
Ugh. I think my height adjustment knob may be out of whack, then. It doesn't seem to do anything at all, either to the arms or to the little meter next to it.
I'm about to head to sleep (night shift guy) but I'll report back after I've had a chance to get under the machine.
Old 04-01-2014, 12:24 PM   post #12 of 18
JJW
Senior MTF Member
JJW's Avatar
MTF Member # 42685
Sorry I misunderstood.
I used to have a 455 & I thought it showed somewhere in the owners manual that there was a way to lock those up but I am not sure. You may be able to download a manual online if you don't have one.
Did your depth control for the mower deck work before with the deck on? I remember having trouble with mine once on the 455 but I just turned it up & down a few times & it seemed to take hold.
__________________
X748 (2011)
Johnny Bucket SR.
355D (2001)
XL Clycone Rake
Old 04-01-2014, 01:18 PM   post #13 of 18
425Forever
Senior MTF Member
425Forever's Avatar
MTF Member # 52718
Since I started this thread, I might as well chime in. In order to secure the mower draft arms up out of the way, set your height control all the way up and lift the arms up all the way with the deck lift control lever (as others have said). Then if you look under the tractor, about in the middle of the draft arms, there should be "J" pins in the frame that fit into a nearby hole on the draft arms. Insert the pin in each hole of the draft arm, and that will hold them up out of the way.
I do this every spring when I attach my 42" hydraulic tiller in order to keep the draft arms out of the way.
__________________
Dump scoop
Old 04-01-2014, 05:08 PM   post #14 of 18
JJW
Senior MTF Member
JJW's Avatar
MTF Member # 42685
425FOREVER
Thanks
That is what I was trying to remember. I knew there was something about that in my 455 manual.
__________________
X748 (2011)
Johnny Bucket SR.
355D (2001)
XL Clycone Rake
Sponsored Links
Advertisement
Old 04-01-2014, 08:07 PM   post #15 of 18
InspectorFowler
MTF Junior Poster
MTF Member # 191930
I'll try to attach a photo of what I see when I look at the draft arms.
I get what you're saying but I'm not sure where the j-pins would be (I assume they would look similar to the ones you pull the remove the deck itself?).
Also, what about the actuators that are still attached to the hydraulics? Do they just sort of rotate freely?
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
