Tecumseh H60 linkage - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Small Engines and Repair
Midwest Mower Pro
Reply
Thread Tools Display Modes
Old 12-11-2010, 11:52 AM   post #1 of 6
GusGT18
MTF Junior Poster
GusGT18's Avatar
MTF Member # 35424
Default Tecumseh H60 linkage
Need help on the correct hookups for the spring and link on a tecumseh H60. When I got it the link was on backwards, so flipped it and it runs good now, but if anyone can verify the hole setup that would be great.
I sketched the hole pattern in the throttle. Right now I have it in the lower left hole.
Thanks,
Gus
__________________
Gus
1987 Craftsman II GT18 44"
1988 Craftsman II GT18
Accessories:
Craftsman II 14 Cu Ft. Dump Cart
Craftsman 40" Snowblower
Craftsman 48" Dozer\Snow Blade
GusGT18 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 12-11-2010, 12:34 PM   post #2 of 6
ranchkingron
The voice of reason !
ranchkingron's Avatar
MTF Member # 47639
Default Re: Tecumseh H60 linkage
Not sure because of the bracket but I can say if you give me the Engine number I can give you the linkage setup.
As near as I can tell you use the hole furthest out so you will get full throttle plate opening.
Ron
__________________
Sometimes a cigar is just a cigar. Sigmund Freud
ranchkingron is offline   Reply With Quote Quick reply to this message
Old 12-11-2010, 01:09 PM   post #3 of 6
GusGT18
MTF Junior Poster
GusGT18's Avatar
MTF Member # 35424
Thanks. The model number is H60-75264G
__________________
Gus
Accessories:
Old 12-11-2010, 11:05 PM   post #4 of 6
ranchkingron
MTF Member # 47639
Quote:
Ok this is what I found out 143.586012 - H60-75264G
Series 1 carb two different throttles on this one both have one hole which is out further than the rest and thats the one to use, so what I would do is is close the throttle to idle then hold the governor at it's lowest then see if it lines up with the hole on the outside of the throttle it should open all the way with movement from the governor.
As far as I can see you have it all in the proper locations.
Ron
ID:	133953   Click image for larger version
ID:	133954   Click image for larger version
__________________
Old 12-12-2010, 01:02 AM   post #5 of 6
GusGT18
MTF Junior Poster
GusGT18's Avatar
MTF Member # 35424
Wow. great info. Thanks again Ron.
__________________
Gus
Accessories:
Sponsored Links
Advertisement
Old 12-12-2010, 01:16 AM   post #6 of 6
ranchkingron
MTF Member # 47639
No problem, but if anyone else has a better grasp of the layout (linkages) I hope they chime in.
Ron
__________________
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
