Question About Fluid Filled Tires - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Backyard Round Table - L & G Tractor Related Topics Lawn and Garden Tractor Related Topics General Discussion Board
Reply
Thread Tools Display Modes
Old 05-02-2005, 08:47 PM   #1
rria1965
MTF Member
MTF Member # 222
Default Question About Fluid Filled Tires
I have a newbie question about fluid filled tires. Doesn't the washer fluid rust the rims from the inside out? I'd be curious to hear from anyone who has had fluid filled rims for an extended period of time.
I would think antifreeze, other than the cost, would be less prone to rusting.
Thank you in advance.
RRIA
rria1965 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 05-02-2005, 08:53 PM   #2
USN_ED
Old Fart
USN_ED's Avatar
MTF Member # 49
Images: 1
Default Re: Question About Fluid Filled Tires
Yep, eventually, washer fluid will rust out a wheel from the inside out. It may take 20-years but it will eventually happen. A lot of guys put tubes in and fill the tubes with fluid but the fluid filled tires will cause condensation between the tube and rim and the rim will still rust out. Antifreeze will kill your animals if it should leak out.
__________________
ED
NEVER FORGET "The Battling Bastards of Bataan" !!! We owe them much.
MTD Yard Machines "GOLD"
Craftsman GT5000
**** MTF 5 Year Sponsor ****
Sears "Chevron Tires" SKU # 71-24167 (Two AG tires mounted on steel rims with valve stems).
USN_ED is offline   Reply With Quote
Old 05-02-2005, 09:04 PM   #3
Argee
5000 Strong & Climbing
Argee's Avatar
MTF Member # 5
Images: 11
I figure washer fluid to be a good alternative to Calcium Chloride.
__________________
Randy G
Argee is offline   Reply With Quote
Old 05-02-2005, 09:14 PM   #4
ducati996
Proud Member of the 1K Club
ducati996's Avatar
MTF Member # 39
Quote:
Hey USN,
You paint the bleakest picture - poor guy never had a chance
Honestly loading (filling tires) is the most cost effective way of adding weight.
Its done all the time with excellent results. Some folks use CaCl in tubes in their machines ( myself) and others for years without problems. If I wasnt going to use CaCl or if I started over I would look for a product called "Rim Guard below
http://www.ballaststar.com/rimguard_spec.php
Window washer fluid doesnt provide the weight properties (specific gravity) of CaCl or Rimguard and antifreeze is a toxic waste (to man and animal) of time, material and expense...
Get the Rimguard and you dont have to be scared straight ever again by people likes USN_ED
Ducati
ducati996 is offline   Reply With Quote
Old 05-02-2005, 10:14 PM   #5
Argee
Argee's Avatar
MTF Member # 5
Images: 11
Where do they sell this Rimguard?? I did a 80 mile search for a dealer from the largest town 20 miles from here and received no hits.
__________________
Randy G
Old 05-02-2005, 10:30 PM   #6
Archdean
Archdean's Avatar
MTF Member # 31
Send a message via AIM to Archdean Send a message via Yahoo to Archdean
As usual I'll be one the other side of the discussion!!
If you want to add weight to the rear of your Tractor Permanent or Temporary the best method is :
Wheel weight!
Reason being it does not change it's iniertia, does not corrode, cause undue stress on axel or bearings and can be removed at will !!
All other methods pale in comparison!!
Archdean is offline   Reply With Quote
Old 05-02-2005, 10:32 PM   #7
Argee
Argee's Avatar
MTF Member # 5
Images: 11
Quote:
Originally Posted by Archdean
Wheel weight!
I think I read some where that filled tires put the least amount of stress on the axles and put the weight closest to the ground.
__________________
Randy G
Old 05-02-2005, 10:33 PM   #8
Argee
Argee's Avatar
MTF Member # 5
Images: 11
Are there any engineers out there that can prove or disprove this ???
__________________
Randy G
Old 05-02-2005, 10:42 PM   #9
JDFANATIC
9K+ Poster
JDFANATIC's Avatar
MTF Member # 41
Images: 1
Garage
Argee, RimGuard is sold through a network of dealers. Probably the "blue" dealer you're familiar with is one. I loaded the rear tires of my 2210 last year and am really happy with the results. That said, the smaller tires of my sub-CUT can only hold ~ 120 lbs per tire. Even still, that makes for an amazing difference compared to the stock 2210. However, I still would have like a couple of hundred pounds more. RimGuard is non-corrosive, non-toxic, and it's density nears that of calcium chloride (about 12#/gal). Some posters will prefer wheel weights, and though they have valid points, I chose to go with the RimGuard. I would also like to point out, that, as tractors are more competively manufactured, and as worldwide pressures proliferate, the trend is to lighten (cheapen) them; and as such, a tractor loses it's very best friend: heft and weight.
BTW, USN ED, Oreo says hello!
Cheers
JDFANATIC
JD2210
JDFANATIC is online now   Reply With Quote
Old 05-02-2005, 10:51 PM   #10
Archdean
Archdean's Avatar
MTF Member # 31
Take your pick !
Be My guest It's not difficult to rationalize!
It's a solid, non rolling (sloshing) forward or backward!
It is mounted on the rim , cannot corroed the interior part of the tire mount!
It applies the weight directly to the ground trough the rim and tire, thereby not transferring it through the axel or bearings!
It can be removed a lot quicker then you can drain a filled tire which makes repair a lot eaiser for tire repair or replacement!!
What's to prove???
Yes I have a Degree in Engineering but not in tractor Weight!
Old 05-02-2005, 10:57 PM   #11
Archdean
Archdean's Avatar
MTF Member # 31
Rim Guard is Squeezed Beet Juice and the very best fluid for those that want to fill their tires NO QUESTION ABOUT IT , but should you need to repair one the charge will be astronomical!!
Old 05-02-2005, 10:58 PM   #12
JDFANATIC
9K+ Poster
JDFANATIC's Avatar
MTF Member # 41
Images: 1
Garage
Archdean,
All of your arguments are valid and worth consideration. What I do not like about wheel weights are the added width the tractor requires to add the necessary weight.
Cheers
JDFANATIC
JD2210
Old 05-02-2005, 11:00 PM   #13
Archdean
Archdean's Avatar
MTF Member # 31
Incidently in this area most that want their tires filled use liquid Methane (highly flamable) mixed with water!! Is it heavy you bet , is it for me, NO!!
Old 05-02-2005, 11:02 PM   #14
Archdean
Archdean's Avatar
MTF Member # 31
Quote:
Originally Posted by JDFANATIC
Archdean,
Cheers
JDFANATIC
JD2210
If you recall I said it was the best method not the only method , for you it makes sense and Cheers to you also!! I still think you have a very nice property!!
Sponsored Links
Advertisement
Old 05-02-2005, 11:12 PM   #15
ducati996
ducati996's Avatar
MTF Member # 39
Wheel weight!
Your kidding right ? wheel weight is a direct force on the axels therefore causing stress on both axel and bearings.....you forgot to mention the most expensive option
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
