anyone make a wood frame snow cab ?? Post the pics ! - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Backyard Round Table - L & G Tractor Related Topics Lawn and Garden Tractor Related Topics General Discussion Board
Reply
Thread Tools Display Modes
Old 12-03-2010, 07:05 PM   post #1 of 7
cvcman
Proud Member of the 1K Club
cvcman's Avatar
MTF Member # 21833
Default anyone make a wood frame snow cab ?? Post the pics !
I was thinking of building the cab from pt 2 x 4 's and using the clear plastic that Walmart sells by the yard and maybe a plywood roof. Like to see some of the ones you guys made other than welded pipe styles
__________________
Cub Cadet 126 gear drive with QA42A snow thrower
cvcman is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 12-03-2010, 07:18 PM   post #2 of 7
ben2go
MTF New Poster
ben2go's Avatar
MTF Member # 11920
Default Re: anyone make a wood frame snow cab ?? Post the pics !
That may be to heavy on the fenders.What about pvc pipe instead?
ben2go is offline   Reply With Quote Quick reply to this message
Old 12-03-2010, 08:33 PM   post #3 of 7
case222
Senior MTF Member
MTF Member # 39167
heavy= extra weight for traction
case222 is offline   Reply With Quote Quick reply to this message
Old 12-03-2010, 08:34 PM   post #4 of 7
NYrobbie77
Senior MTF Member
NYrobbie77's Avatar
MTF Member # 41904
my grandfather built one for the bolens 1250 that i now own. it was out of plywood and 1x i think. it was pretty kewl and held up well. unfortunately my dad tossed it a few years ago and i can't find any pics.
NYrobbie77 is offline   Reply With Quote Quick reply to this message
Old 12-03-2010, 09:33 PM   post #5 of 7
Danco
Senior MTF Member
Danco's Avatar
MTF Member # 34712
Images: 15
Quote:
Check out this great link from another Member.
http://www.mytractorforum.com/showthread.php?t=101286
__________________
JD - 318
JD - 54" Hydraulic Angle Front Blade
Fabricated - 48" Front Scoop
JD - Deck and MCS
JD - Smile
Sears Suburban 12
Sears Snow Thrower
Sears Plow
Support MTF
Danco is offline   Reply With Quote Quick reply to this message
Old 12-03-2010, 10:34 PM   post #6 of 7
engine2quarters
5000 Strong & Climbing
MTF Member # 24003
I was thinking of fabbing up a 'cover' using 1" PVC piping and flanges. They have base flanges that can be screwed to the fenders or foot rests. They also got the fittings for the corners. PVC could be threaded or cemented. Plywood roof, 1/4 inch, made water resistive. One moveable door with a simple square type frame using a (or a couple) piano hinge(s). Was thinking about using that flexible HD clear plastic they use for marine seat covers, or 1/8 inch plexiglass. Control feed thru ports using sliced innertubes or canvas. Windshield would be the stickler, either 1/4 inch plexiglass or plastic sheeting. Glass might be too heavy for the PVC frame. Windshield wiper, maybe manual, not electric. Roof thick enough to support a couple white lights, front and rear.
Project put on back burner until I find some room in the garage to work on it. Which really means, a couple tractors have to be put out in the cold. NO WAY!
engine2quarters is online now   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 12-03-2010, 10:47 PM   post #7 of 7
stladrill
Run ahead of the pack
stladrill's Avatar
MTF Member # 31914
Images: 4
Garage
Thanks Danco
Here's an old plan for a wood cab from Popular Mechanics.
ID:	132673   Click image for larger version
__________________
Forum Rules
Welcome Canadians Sign in!!
(Click on the image to get there)
The information provided is without warranty of any kind. In no event shall I be liable for any direct, indirect, incidental or consequential loss, damage, liability or expense incurred or suffered, claimed to have resulted from use of this information.
stladrill is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
