John deere x304 idle problem - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 11-20-2010, 04:53 PM   post #1 of 20
Lalmeida617
MTF Junior Poster
MTF Member # 47577
Default John deere x304 idle problem
My x304 idle's high then low and won't even out at low throttle.
I have installed the tune up kit oil, new air,oil and fuel filters and new spark plugs. It only has 60hrs on it.
If I push the lever to full throttle I can still hear a slightly unsteady idle.
Please Help Thanks!
Lalmeida617 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 11-20-2010, 05:14 PM   post #2 of 20
stladrill
Run ahead of the pack
stladrill's Avatar
MTF Member # 31914
Images: 4
Garage
Default Re: John deere x304 idle problem
Did it do that before you did the tune up on it?
__________________
Forum Rules
Welcome Canadians Sign in!!
(Click on the image to get there)
The information provided is without warranty of any kind. In no event shall I be liable for any direct, indirect, incidental or consequential loss, damage, liability or expense incurred or suffered, claimed to have resulted from use of this information.
stladrill is offline   Reply With Quote Quick reply to this message
Old 11-20-2010, 05:48 PM   post #3 of 20
Lalmeida617
MTF Junior Poster
MTF Member # 47577
Quote:
No not that I recall.
Old 11-20-2010, 05:55 PM   post #4 of 20
stladrill
stladrill's Avatar
MTF Member # 31914
Images: 4
Garage
Ok then
1. Make sure you install the fuel filter the right way.
2. You may have a defect spark plug.
3. Recheck all the work you done on it.
For the spark plug the easy way to determinate the defect one is to reinstall one used plug at the time.
__________________
Forum Rules
Old 11-20-2010, 06:04 PM   post #5 of 20
Lalmeida617
MTF Junior Poster
MTF Member # 47577
Stladrill I will look at it tommarow at the spark plugs. When I changed the oil I was not sure if I should check the level with the oil cap locked on or just placed to the top of the dipstick tube.
Old 11-20-2010, 06:11 PM   post #6 of 20
stladrill
stladrill's Avatar
MTF Member # 31914
Images: 4
Garage
Quote:
The top of the dipstick tube (unscrew) after running the engine for few minutes.
I'm sure you will find the problem.
__________________
Forum Rules
Old 11-20-2010, 06:17 PM   post #7 of 20
Lalmeida617
MTF Junior Poster
MTF Member # 47577
Could to much oil cause this?
Old 11-20-2010, 06:39 PM   post #8 of 20
stladrill
stladrill's Avatar
MTF Member # 31914
Images: 4
Garage
How much more?????
__________________
Forum Rules
Old 11-20-2010, 10:45 PM   post #9 of 20
Lalmeida617
MTF Junior Poster
MTF Member # 47577
Not even one extra line on the stick
Old 11-20-2010, 11:48 PM   post #10 of 20
stladrill
stladrill's Avatar
MTF Member # 31914
Images: 4
Garage
No it is not what cause your problem, but I recommend to drain it a bit of oil.
__________________
Forum Rules
Old 11-21-2010, 02:58 PM   post #11 of 20
Lalmeida617
MTF Junior Poster
MTF Member # 47577
Ok then
I checked the fuel filter and the arrow on it is pointing toward the carb (the fuel flow direction)
I replaced both spark plugs with the old ones.
And rechecked the oil level, it was on the money and the air cleaner and pre filter are clean.
I also checked the fuel pump vent and it doesn't seam dirty.
The tractor still idle's up and down
Could a small piece of dirt got into the carb when I changed the filter?
If so how do I get it out?
Should I pour some fuel system cleaner in the gas?
Old 11-21-2010, 05:33 PM   post #12 of 20
stladrill
stladrill's Avatar
MTF Member # 31914
Images: 4
Garage
Did you check the gas cap vent? try to unscrew it, if your hear a vacuum noise is a sign that the vent is blocked.
__________________
Forum Rules
Old 11-21-2010, 05:47 PM   post #13 of 20
Lalmeida617
MTF Junior Poster
MTF Member # 47577
I added fuel to the tractor while it was running and opening the cap did not change anything.
Old 11-21-2010, 06:00 PM   post #14 of 20
stladrill
stladrill's Avatar
MTF Member # 31914
Images: 4
Garage
Did you still have a warranty on it?
I'm out of idea.
It's maybe a governor trouble???
__________________
Forum Rules
Sponsored Links
Advertisement
Old 11-21-2010, 06:03 PM   post #15 of 20
rscurtis
5000 Strong & Climbing
MTF Member # 25367
Let us know which engine this uses and someone will come up with the procedure to clean the idle jet on the carburetor.
rscurtis is online now   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
