Another project coutesy of my BIL - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 11-19-2010, 11:40 PM   post #1 of 14
PA318Guy
Winter returned!
PA318Guy's Avatar
MTF Member # 31960
Garage
Default Another project coutesy of my BIL
Well, he visited last year for Christmas and was taken with the tractor and the "toys" I had for it! So he decided I just didn't have enough so now look what I got! Now I have to figure out how to mount is so it can be used front and rear on my tractor, and on my trailer! Maybe my sister didn't do so bad after all!!!!
__________________
Current Machine JD 322
Former Machines: JD 318, JD 216, JD 212, 1965 JD 110
My videos: www.youtube.com/user/tkelley16341
PA318Guy is online now   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 11-20-2010, 12:20 AM   post #2 of 14
TooManyGT
Proud Member of the 1K Club
TooManyGT's Avatar
MTF Member # 38585
Default Re: Another project coutesy of my BIL
Nice! I just got one of those for my little trailer, seems to work really well just has a little delay after you release the button.
What did you have in mind for a mounting system?
Brad
__________________
Kubota '10 B2620 w/LA364, Homemade bucket QA, Homemade Hyd. grapple bucket
Wheel Horse '93 520H 60" deck, 48" blade
Simplicity '64 Landlord, Mid-grader blade, 46" front blade, sickle bar, Hyd-lift, deck.
Case 444, 48" deck, 54" front blade, 41" tiller, 3pt
Simplicity GTH20 & Deutz 1920 Diesel (under construction)
TooManyGT is offline   Reply With Quote Quick reply to this message
Old 11-20-2010, 12:24 AM   post #3 of 14
PA318Guy
Winter returned!
PA318Guy's Avatar
MTF Member # 31960
Garage
I'm trying to figure out something I can drop into my front weight bracket, hook over my 3 pt hitch, and drop into the area behind the jack on my trailer! I'd like it to be simple with maybe a catch or pin arrangement on the bottom to keep it from "lifting". It should fit all three locations withoutany modification (interchangeable locations)!
__________________
Old 11-20-2010, 08:56 AM   post #4 of 14
TooManyGT
TooManyGT's Avatar
MTF Member # 38585
I can see the front weight braket and trailer being easy because you can make a matching braket for the trailer based on the weight bracket. The 3pt might require making an adaptor the the winch can pin onto. Sounds like a fun project. Can you post up pictures of the weight braket? Sounds like thats what the mounts are going to be based on.
Brad
__________________
Old 11-20-2010, 10:32 AM   post #5 of 14
PA318Guy
Winter returned!
PA318Guy's Avatar
MTF Member # 31960
Garage
Quote:
Brad
Here is the front weight bracket! It holds up to 8 suitcase weights so I figure it should do a good job of holding the winch in place. I'm thinking a plate with a couple of square posts in it that goes through this, then have adapters made for the 3 pt. and trailer to match. I'm also going to have to mount an electrical connection on the tractor and my truck that it can be plugged into (heavy duty exterior).
__________________
Old 11-20-2010, 12:01 PM   post #6 of 14
TooManyGT
TooManyGT's Avatar
MTF Member # 38585
Hmmm, looks like if you can copy the "hook" section of the suitcase weight and find a way to pin it in so it can't come back out by accident.
Brad
__________________
Old 11-20-2010, 05:52 PM   post #7 of 14
DMAC
MTF Member
DMAC's Avatar
MTF Member # 21642
Images: 39
PA318Guy
Very nice gift, trade BIL's?
On your 3 pt hitch, did you make a 2" receiver attatchment? If so you could add a 2" OD square tube to the winch and plug it anywhere there is a 2" receiver. This has worked great here; it plugs into the tractor front and rear, the truck in the rear and the front of the flatbed (to pull objects on to the bed) also the front of the truck. Loan it to a buddy with a 2" receiver etc.
DMAC
__________________
Cub Cadet 3204 with:
54" Dozer Blade w/carryall sides
45" Snow Thrower, Snow Cover, lights+weights
3 Point Hitch w/2" receiver
23" Rear Ag Tires, 18" Front, 4-Ply
Dual Lift front hitch w/Angle
Homemade: front bucket, dirt scoop, boom pole, york rake.
3 point ripper, winch, battering ram, hyd press, crane, etc. Front or Rear hookup
DMAC
DMAC is offline   Reply With Quote Quick reply to this message
Old 11-20-2010, 06:03 PM   post #8 of 14
PA318Guy
Winter returned!
PA318Guy's Avatar
MTF Member # 31960
Garage
Quote:
Originally Posted by DMAC View Post
PA318Guy
DMAC
DMAC, good idea! I guess I could rig up an adapter for the front weight rack to hold a 2" receiver too! Good thing is that Walmart stocks them so I've got some close buy! Do you have any pics of your setup you could share?
Thanks!
Tim
PS For the time being I'm keeping my BIL!
__________________
Old 11-20-2010, 06:36 PM   post #9 of 14
DMAC
MTF Member
DMAC's Avatar
MTF Member # 21642
Images: 39
The winch plugged into the tractor.
The winch welded on to the 2" square tube with a scrap plate that holds the controls and the electronics. Also the reveiver for the flatbed, it mounts 12" above the bed for a decent pulling angle.
DMAC
__________________
DMAC
Old 11-20-2010, 08:17 PM   post #10 of 14
PA318Guy
Winter returned!
PA318Guy's Avatar
MTF Member # 31960
Garage
DMAC, started working on one of my other projects for a while (they never stop), thanks for the pictures, looks like it works very well. This has a wireless controller so I'm going to have to see the range on that. Also, I'm going to have to check out an electrical store to see what kind of 2 wire heavy duty outside connectors they have. I want a simple quick connection!
__________________
Old 11-20-2010, 09:33 PM   post #11 of 14
Littledeere
Senior MTF Member
Littledeere's Avatar
MTF Member # 49602
Images: 45
Connectors used on jumper cables on tow trucks work great they plug right up and are made for a high amp pull and they are coated for protection.They look like the same thing they use on electric fork lifts to plug up the battery. Bought mine years ago from Snap on I will try to get you a pic
Littledeere is offline   Reply With Quote Quick reply to this message
Old 11-21-2010, 12:24 AM   post #12 of 14
lx176mainer
tiny tractor big interest
MTF Member # 5571
Quote:
Grainger stock those in a couple different sizes as well. Used a pair to quick connect the Amplifier leads in my motorcyle saddle bag
Adam
__________________
lx176mainer is offline   Reply With Quote Quick reply to this message
Old 11-21-2010, 12:41 PM   post #13 of 14
JRC0528
JRC0528's Avatar
MTF Member # 21688
Look up Anderson Connectors on feebay.... I bought a pack of 10 there, smaller 2 conductor sized for 8 AWG wire. I think they are rated 50A, but they work great for the RC winch!
Like DMAC, I also mounted my winch on a 2" square tube. I have receiver tubes on the front and rear of the tractor and the back of the truck. An Anderson connector is installed on the side frame of the tractor and in the bed of the truck for convenient power hook-up.
__________________
Jim C.
Many a man in love with a dimple makes the mistake of marrying the whole girl!
-- Stephen Leacock on the danger of infatuation
JRC0528 is online now   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 11-21-2010, 05:23 PM   post #14 of 14
PA318Guy
Winter returned!
PA318Guy's Avatar
MTF Member # 31960
Garage
Thanks for all the ideas on the electricals! I'll have to check them out!
__________________
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
