Help!! Tecumseh backfires!! - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Small Engines and Repair
Midwest Mower Pro
Reply
Thread Tools Display Modes
Old 11-19-2010, 08:19 PM   post #1 of 8
In2deep73
MTF Junior Poster
MTF Member # 52598
Default Help!! Tecumseh backfires!!
Hello. I have a Tecumseh snow blower and it runs, but it sounds as if it is backfiring. If I slowly prime it while it is running, however, the problem gets better. I took the carburetor off and rebuilt it (took the welch plugs out, soaked in acid etc.), and it still does the same thing. The flywheel key is perfect, as well as the air gap for the magneto. What is the next step? Perhaps reseating the valves? Thank you for your help.
EDIT: It sounds like it may be a loud misfire possibly?
In2deep73 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 11-20-2010, 11:37 AM   post #2 of 8
Shryp
Senior MTF Member
Shryp's Avatar
MTF Member # 49725
Default Re: Help!! Tecumseh backfires!!
Have you tried adjusting the carb or it is one of those newer non adjustable ones?
Mine would backfire a little bit when I had it set too rich.
Shryp is offline   Reply With Quote Quick reply to this message
Old 11-20-2010, 12:59 PM   post #3 of 8
In2deep73
MTF Junior Poster
MTF Member # 52598
It is a non adjustable EPA crap carburetor. I tend to think it is running too lean because if I slowly prime it, the problem gets better, but maybe it is my imagination. I took the valves out last night they both look good. I'm going to reface the valves and see what happens. Thank you.
Old 11-20-2010, 06:16 PM   post #4 of 8
rscurtis
5000 Strong & Climbing
MTF Member # 25367
Save your time on the valves. If it starts OK, the valves are good. Locate the idle jet on the carb, it may be under a plastic plug. Remove it and clean the orifice on the end. Hopefully, that will solve your problem.
Keep in mind that a Tecumseh engine on a snowblower is not going to run like a Honda or Vanguard- they are noisy, tend to vibrate, and don't always run steadily, that's the nature of the beast.
rscurtis is online now   Reply With Quote Quick reply to this message
Old 11-20-2010, 06:20 PM   post #5 of 8
In2deep73
MTF Junior Poster
MTF Member # 52598
I checked the idle screw before I even rebuilt the carburetor and it was fine. I even checked the idle circuit etc. Maybe if I drill out the jet a little bit it might fix the problem??? These emissions carburetors are terrible...
Old 11-20-2010, 07:11 PM   post #6 of 8
Fcubman
3K Poster!!!!
Fcubman's Avatar
MTF Member # 18953
Images: 5
Try running it with the choke partially closed - an improvement will prove that it's running lean. If it gets worse, it's running rich.
I assume that your spark plug and ignition are in good shape.
__________________
Remember, I'm pullin' for ya! We're all in this together!
(Red Green)
Living in The Land Of The Free - because of The Brave!
Fcubman is offline   Reply With Quote Quick reply to this message
Old 11-20-2010, 07:12 PM   post #7 of 8
In2deep73
MTF Junior Poster
MTF Member # 52598
Wow, thats a great idea. Don't know why I didn't think of that lol. I'll try that.
Sponsored Links
Advertisement
Old 11-20-2010, 07:27 PM   post #8 of 8
Fcubman
3K Poster!!!!
Fcubman's Avatar
MTF Member # 18953
Images: 5
Quote:
No charge -
__________________
(Red Green)
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
