snow blower shear bolts - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 11-16-2010, 08:34 PM   post #1 of 5
kahuna33811
MTF Junior Poster
MTF Member # 29318
Default snow blower shear bolts
I am looking for the shear bolts for the snow blower on my 4514 honda. The small one on the second stage for sure. Northern has no parts for this snow blower anymore. Thanks
kahuna33811 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 11-16-2010, 10:03 PM   post #2 of 5
black88mx6
Senior MTF Member
MTF Member # 18766
Default Re: snow blower shear bolts
Easy enough. Boats.net
(1) 72998-0076 small (2nd stage) $.72 each
(3) 72998-0027 5/16 x 2 large (auger and input shaft) $1.57 each
Other wear items;
(2) 72998-0031 Skid replacement
(1) 72998-0077 scraper bar / cutting edge
You can also try to match them up at tractor supply, but don't know if you get the correct bolt grade or shear rating.
black88mx6 is offline   Reply With Quote Quick reply to this message
Old 11-16-2010, 10:28 PM   post #3 of 5
hunky57
MTF Member
MTF Member # 8736
I get mine at the local hardware store
__________________
"93"5518,48" box blade,48"3point rake,54" snow blade,42"blower And now a home made log skidder. Works Great
hunky57 is offline   Reply With Quote Quick reply to this message
Old 11-16-2010, 10:35 PM   post #4 of 5
black88mx6
Senior MTF Member
MTF Member # 18766
Quote:
I don't know enough about breakage tolerances and metal grades for this unit to match them up properly. Do you have those number? I have just had to replace one gearbox because of the wrong bolts that resulted in a damaged brass gear.
Sponsored Links
Advertisement
Old 11-17-2010, 07:47 PM   post #5 of 5
Brocephus
MTF Junior Poster
MTF Member # 50660
The shear bolts for my Honda SB1013B are, as per Honda specs, as follows:
On the auger - 5/16" x 2" (grade 5)
On the driveshaft into the reduction box from the fan, it specifies the same bolt. However, that particular bolt has a groove, near the head, machined into it.
www.okcpropower.com still stocks many parts for the SB1013B. I can't imagine the shear bolts will be very different, if at all, between the SB1013B and the SB800. Call 'em up, ask for Kyle or Les in the Parts department, and tell 'em "John from New York" sent you.
Brocephus is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
