Rejetting a 6.5 HP Duraforce - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Small Engines and Repair
Midwest Mower Pro
Reply
Thread Tools Display Modes
Old 11-16-2010, 07:12 PM   post #1 of 2
In2deep73
MTF Junior Poster
MTF Member # 52598
Default Rejetting a 6.5 HP Duraforce
I am going to rejet my 6.5 Duraforce Lawn Boy this weekend as per this article:http://forums2.gardenweb.com/forums/...233252156.html. Some people, as well as the lawn boy repair manual, suggest using loctite 242 blue to seal the jets. If I use this, will I be able to remove the jets for servicing? I have never used blue loctite, but I have used red loctite and know that it would probably result in a cracked carburetor trying to remove the jets. I'm not sure if the blue type is different, as in it won't "lock" it in as much or what. Any help is greatly appreciated. Thank you.
In2deep73 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 11-17-2010, 05:04 AM   post #2 of 2
Brad
MTF--A Step Above!
Brad's Avatar
MTF Member # 4571
Images: 28
Default Re: Rejetting a 6.5 HP Duraforce
I can't answer the Loctite question, tho the folks in the Walkbehind section may be able to help. Lots of info on rejetting down there. Some have also found that the Duraforces came out with the wrong throttle plate, causing a surge. My duraforce never surged for years, then started. I pulled out the jet (behind the small pc of tape on the side of the carb), sprayed it with cleaner, ran a fine wire thru it, and no more surge.
Good Luck, and like I mentioned, tons of info down in the Walkbehind section on this procedure.
__________________
MTF--Getting better, one new member after another!
It's a great place to spend some time every day!
Brad
Brad is online now   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
