Snowblower chute tilt control wth wires? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 11-08-2010, 09:46 PM   post #1 of 11
C2H8O
Proud Member of the 1K Club
C2H8O's Avatar
MTF Member # 24612
Images: 7
Default Snowblower chute tilt control wth wires?
I have searched the forums but have not been able to find a chute tilt control with wires
I am readying the Bolens snowblower attachment for the winter. I modified and mounted the chute rotation control. Now it would be great to control the chute tilt from the seat, and bicycle brake cables seem OK. I think electric actuators are too expensive for me.
__________________
DougL
C2H8O is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 11-08-2010, 10:42 PM   post #2 of 11
rhenning
3K Poster!!!!
MTF Member # 4880
Default Re: Snowblower chute tilt control wth wires?
This is what I used on a JD I used to own. Small linear actuator and home made brackets. Roger
ID:	128451   Click image for larger version
ID:	128452   Click image for larger version
rhenning is offline   Reply With Quote Quick reply to this message
Old 11-08-2010, 10:55 PM   post #3 of 11
lh7018
MTF Junior Poster
MTF Member # 4126
The Ariens blowers used on the GT and Grand Sierra tractors used a cable for positioning the deflector from the operators seat. It was a single cable, heavier than a bicycle brake cable though, and would lock in position with a quarter turn of the operators handle on the end. It mounts to the same bracket that holds the chute crank near the operator, and on the chute there is small angle bracket for holding the cable housing. The cable attaches to the deflector with a small tab welded to the deflector. A small drawing could be seen here - http://www.rcpw.com/lookup/?aribrand...QT/74HFlnnAA==
It would be very easy to make and attach the two little brackets on the chute and deflector to hold the cable. I've never tried a bike cable so I don't know if it would be strong enough for the push/pull but a cable assembly from an Ariens parts supplier (complete with handle, attaching nuts, and threaded pivot for attaching to deflector) runs about $70.00 or so.
I'm adding this to my Ariens tractor blower for this season. I haven't installed it yet so I can't get any pictures for you right now, but I'll have it done in a couple days and can take some pics if you're interested.
Just a thought.
lh7018 is offline   Reply With Quote Quick reply to this message
Old 11-09-2010, 10:18 AM   post #4 of 11
92merc
DGS 6500 - North Dakota
MTF Member # 18495
Here is the manual cable setup on my Bercomac. That dark black "rod" looking thing on the far left is actually a spring. There are some nylon washers that help the deflector move up and down easily. But it still takes the force of the snow to move the deflector up.
http://www.bercomac.com/images/fichi...0843090643.pdf
92merc is offline   Reply With Quote Quick reply to this message
Old 11-10-2010, 01:53 AM   post #5 of 11
kccraftswoman
kccraftswoman
kccraftswoman's Avatar
MTF Member # 33641
Images: 17
Smile Re: Snowblower chute tilt control wth wires?
i used a window motor for the rotate and might be using an electiric actuator that i am watching on ebay.if i don't get that motor, then i will go to plan (B) and use a window motor for the up and down and i am trying to find a circuit to run both motors by 1 joystick(that i bought off ebay cheap).when i find the circuit that will work i'll pass it along .i do know that there are at least 4 relays in the circuit for both motors. tootles . K.C.
kccraftswoman is offline   Reply With Quote Quick reply to this message
Old 11-10-2010, 01:19 PM   post #6 of 11
GT_80
Cranky Motorsports
GT_80's Avatar
MTF Member # 35886
Images: 32
Garage
a bike cable would only work if it had a spring return in one direction- they are menat to pull only not push- on the other hand a cable that is used for a Hurst or B&M shifter for a car would work well... Just a matter oh how and where to hook it up and how much travel you need... I just as soon get off the tractor to change the chute angle- it almost NEVER gets moved on my machine, and the chute rotates side to side with a rotating handle and cable assembly
B&M replacement cable
__________________
MTF Addict #35886
Hugh-SS/16 fan #0001
Tractors:
1968 Super12 "Miss Emma Lee"
1967 Suburban 12 "The 679"
1973 SS16/ 18/6 hybrid "Mighty Mongrel"
1976 SS18 "Trusty"
1978 GT18 with Hard cab - home again!
Attachments:As many as I can get
My YouTubeMy Ebay
Sears Manuals
GT_80 is offline   Reply With Quote Quick reply to this message
Old 11-11-2010, 09:05 PM   post #7 of 11
C2H8O
C2H8O's Avatar
MTF Member # 24612
Images: 7
The info and pictures helped, thanks! I agree a bike cable is not enough to push. I am going to try two cables in a pull-pull arrangement like the Craftsman units. JD has a single cable pull with a spring to rock the deflector the other way.
I will post pics showing how it goes or if it turns out totally ridiculous.
__________________
DougL
Old 11-14-2010, 12:07 PM   post #8 of 11
jaynut
Senior MTF Member
jaynut's Avatar
MTF Member # 36846
Images: 16
here's what I built with a cheap 12v motor, 1/4" drive socket universal joint, & some 1/2" threaded rod - I had a little trouble with it detting stuck at the ends though, so I put compression springs over the 1/2" rod on either side of the nut mounted on the chute & it works great now - just have to keep it lubed up
ID:	129280   Click image for larger version
ID:	129281   Click image for larger version
ID:	129282   Click image for larger version
jaynut is offline   Reply With Quote Quick reply to this message
Old 11-14-2010, 01:35 PM   post #9 of 11
LLigetfa
standard issue neuralyzer
LLigetfa's Avatar
MTF Member # 15283
Images: 2
I saw one that used a motor from a cordless drill. Most people have a few of those around that the battery has expired on.
If you want to go with steel cable, use two cables pulling in opposite directions, not one with a spring return. Water invariably gets inside the cable and it freezes. At least with two cables you have a chance to work it loose.
__________________
I don't suffer from insanity. I enjoy every minute of it!
LLigetfa is offline   Reply With Quote Quick reply to this message
Old 11-14-2010, 02:59 PM   post #10 of 11
C2H8O
C2H8O's Avatar
MTF Member # 24612
Images: 7
Here is the first functional design I came up with for the chute deflector. The cost was a $5 pack of bicycle cables and some scrap I had around. The Bolens deflector does NOT have a single pivot point, so it was more difficult to modify than other tractors. The handle is 1/2 of barbecue tongs.
I modeled the Ariens design. The return spring on most spring+cable systems is very weak; it depends on the blast of snow to lift it upwards so I used a little bungee cord. I also copied the cable lift control facing downward so water does not run into the cable sleeve
I really like the little 12v motor with a threaded rod. Very simple! I will try that if I can find a similar motor. Linear actuators are way overkill at $170.
I will let you know how well it works in snow!
ID:	129306   Click image for larger version
__________________
DougL
Sponsored Links
Advertisement
Old 11-14-2010, 09:46 PM   post #11 of 11
kccraftswoman
kccraftswoman
MTF Member # 33641
Images: 17
well that is using your head i like the reuse of the bbq tongs. keep up the good work.
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
