R/T tractor - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Home Made Tractors, Implements and Accessories For you guys handy with a blow torch, welder or a wrench.. show us what you can do....
Reply
Thread Tools Display Modes
Old 11-02-2010, 04:24 PM   post #1 of 9
jdcrawler
Lindeman crawler fan
jdcrawler's Avatar
MTF Member # 10122
Default R/T tractor
While I'm waiting for the new gas tank for the Ridemaster cart to show up, I'm going to go back to work on the R/T tractor.
When I built the tractor, the rear axle turned out to have a 12 to 1 gear ratio and the rear tires are about 2 or 3 inch smaller diameter than the original tires.
I have used the tractor a little but the combination of the gear ratio and smaller tires makes it really slow.
About a month ago I was able to get a rear axle with the 5 to 1 gear ratio.
So I'm going to bring the tractor back in and swap out the rear axle.
I've also decided to take the front end loader off of it.
I have played with it a few times and it works just fine for what it is.
The problem is that I have been spoiled with the FEL on the Lindeman crawler.
The crawler weighs almost 6,000 pounds and has traction that is unquestionable.
It will go thru snow, mud and loose sand with out and problem.
The 1,500 pound tractor on rubber tires can't even compete with that.
So I said to myself: "Self, why are you carrying the bucket around all the time if you're never going to use it?"
Today I got the FEL off the tractor and took it out side and took some photos so I can put it up for sale.
Here's the tractor with the FEL removed and ready to start on switching the rear axle.
This is the other rear axle that I picked up.
__________________
Ray
1945 John Deere Lindeman ( modified )
1949 Agricat crawler
1947 FMC Bean Cutler ( flat belt drive )
1948 Bolens Ridemaster - 35AA01 Ser#230
1948 Bolens Ridemaster - 35AA01 Ser#457
1948 Bolens Ridemaster - 35AB01
1953 Bolens Ridemaster 35AB03 ( modified cart )
1937 Shaw Du-All tractor conversion
"R/T" home made tractor
http://www.youtube.com/watch?v=-1aD1wn7yNE
jdcrawler is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 11-02-2010, 04:57 PM   post #2 of 9
evo803
Senior MTF Member
evo803's Avatar
MTF Member # 39797
Default Re: R/T tractor
What about taking the bucket off and making some type of other attachment like a grapple , forks or something , seems a shame to pull it off and sell it after all that beautiful work you did. Don't make this decision hastily, you will wake up one night with a briiliant idea on how to customize it to make something you really need . Just my 2cents .
__________________
Chris
" Friends don't let friends drive stock ! "
evo803 is offline   Reply With Quote Quick reply to this message
Old 11-02-2010, 07:29 PM   post #3 of 9
jdcrawler
jdcrawler's Avatar
MTF Member # 10122
I have a 4-wheel drive fork lift for anything that I need to move or lift.
My initial reason for building the tractor was for using the 3-point hitch inplements to maintain the drive and for towing a trailer around.
The FEL idea came along later as something that I thought I would use but I ended up still firing up the crawler to move dirt because it has more power and just works better.
__________________
Ray
Old 11-02-2010, 07:43 PM   post #4 of 9
Tencubed
3K Poster!!!!
MTF Member # 31735
Consider the times you may want to use a FEL around the yard. I've mentioned a couple of times my wife's reaction to my bringing a crawler into the front yard to remove a stump. Those rubber tires would be a lot gentler on grass and other landscaping.
Your machine and you know your needs way better than anyone else.
Mike
__________________
A gun and a parachute are much the same. When you need one nothing else will really suffice.
Tencubed is offline   Reply With Quote Quick reply to this message
Old 11-02-2010, 08:10 PM   post #5 of 9
Dominqiue01149
MTF Junior Poster
MTF Member # 47896
Even though your FEL was well built and all, I preferred the look of your tractor without it.
You could always build a little 3pt bucket for the back for light duty stuff around the yard.
Dominqiue01149 is offline   Reply With Quote Quick reply to this message
Old 11-03-2010, 05:17 PM   post #6 of 9
jdcrawler
jdcrawler's Avatar
MTF Member # 10122
Was able to get the tractor all stripped down today.
__________________
Ray
Old 11-10-2010, 12:00 PM   post #7 of 9
ben2go
MTF New Poster
ben2go's Avatar
MTF Member # 11920
I dunno how I missed this one.OK now I am caught up.
ben2go is offline   Reply With Quote Quick reply to this message
Old 01-01-2011, 04:12 PM   post #8 of 9
123maxbars
MTF Member
123maxbars's Avatar
MTF Member # 51227
where did your new transaxle come from/what size tractor/make/model?
123maxbars is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 01-01-2011, 11:09 PM   post #9 of 9
jdcrawler
jdcrawler's Avatar
MTF Member # 10122
Quote:
The new rear axle is from a Economy Jim Dandy tractor the same as the original rear axle.
The only difference is the gear ratio is a 5/1 instead of a 12/1.
__________________
Ray
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
